Check In & Earn Up to 1,400 EcoCredits Join Now>>
23% Conversion RateIP68
Existing user? Log in
DELTA 1300 has been discontinued. Discover the next-generation DELTA 2 960 here>>
This portable power station is equipped with International standard plugs. Adapters are required for use, and they are included in the package.
Charge from 0%-80% within 1 hour: EcoFlow patent X-Stream Technology empowers EcoFlow DELTA to recharge at 10 times the speed of most battery powered stations in the market.
6x AC Outlets (Total 1800W) & 1260Wh capacity: The large inverter load makes DELTA a power station for home appliances and heavy-duty DIY tools under 1800W (3300W Surge, Pure Sine Wave) with 1260Wh capacity. Learn more about DELTA >>
Two in one EcoFlow's 220W Bifacial Portable Solar Panel is two in one. With a 220W primary side, and a 155W side on the back for ambient light, you can capture up to 25% more solar energy and charge your portable power station even faster.
Tempered glass. Built to last The thin, one-piece tempered glass design makes it five times tougher than comparable panels, it can withstand heat up to 300°F too. Safe to say it can withstand the elements.
Compact. Portable It's a portable solar panel designed from the ground up to be compact. 10% smaller than comparable 220W panels, it saves space with thinner tempered glass, and less surface area required for the same input. Learn more about 220W Solar Panel>>
Adding product to your cart
Your shopping cart is empty
