The most powerful and compact portable AC
that can be used anywhere, anytime
"Best Portable Air Conditioning
Device at CES 2023"
——by MakeUseOf
Fastest cooling and heating
The world's first wireless portable AC with a heater.
EcoFlow's tailor-made compressor enables WAVE 2 to provide 5100 BTUs of cooling
and 6100 BTUs of heating. Prepare for ultimate comfort with WAVE 2!
* Drop 10℃ from 30℃ for 10m³ in 5 min with 5100 BTUs of cooling,and raise 10℃ from 20℃ in 5 minutes for 10m³ with 6100 BTUs of heating in optimal running performance.
Installation-free! Fits anywhere
The perfect air conditioner for any compact space! It is extremely simple to use, requiring no installation or drainage*. There are air duct adapters to fit any space. Enjoy the convenience of cooling and heating without any fuss.
* No drainage is needed in cooling mode when humidity is below 70%, but it is still needed in heating mode.
Using R290: A greener way to beat the heat.
At EcoFlow, eco-friendliness meets ultimate comfort. WAVE 2 uses R290, a natural refrigerant that's clean, green, and perfect for a relaxing cooling experience. With lower global warming potential and no ozone emissions, it's the ideal way to stay cool and comfortable compared to traditional refrigerants while reducing your carbon footprint.
WAVE 2 is just the start. Pair with an EcoFlow DELTA 2 / DELTA Max or their extra batteries and get an astonishing 7-14hr run time in Eco Mode. Compared to using other portable power stations, it's 28% more efficient. You can also use any portable power station with a 820W input to charge your WAVE 2.
What’s in the box
EcoFlow WAVE 2
Exhaust duct E
Exhaust duct D
Exhaust duct adapter cover C
Exhaust duct adapter cover A
Exhaust duct adapter cover B
Window vent board
Winder and Drain pipe
Safety Instructions, Quick Start Guide, and Warranty Card
* The type of AC charging cable that is pluggable or embedded varies according to local laws and regulations, please refer to the actual product.
AC Input
100/240V, 50/60Hz, 820W Max
Solar Charging Input
11-60V, 13A, 400W Max
Car Charging Input
96W/192W (12/24V, 8A Max)
Add-On Battery Power
700W Max
Approximately 14.5 kg
518 × 297 × 336 mm
Bluetooth
Wi-Fi
This product supports 2.4G Wi-Fi only
Noise Level
44-56dB
Refrigerant/Amount
R290/130g
No-Drain Function
Supported (in cooling state)
Cooling Area
≤ 10 ㎡ / 107.6 ft²
IP Rating
IPX4
Rated Cooling Input Power (AC/DC)
550W/495W
Max. Cooling Power (AC/DC)
820W/700W
Cooling Capacity
1500W/5100BTU
600W/540W
Max. Heating Power (AC/DC)
820W/700W
Heating Capacity
1800W / 6100BTU
24 months
