EcoFlow 220W Bifacial Portable Solar Panel | EcoFlow South Africa
EcoFlow NextGen 220W Bifacial Solar Panel
Regular price
Sale price Regular price
Save up to R 300
The NextGen Solar Panels have been discontinued. Explore our upgraded Lightweight Solar Panels with a 5-year warranty and improved portability. Learn More
  • Ultra-Light & Portable: Single panel weighs just 7kg+, making it easy to carry, set up, and store.
  • Versatile Applications: Ideal for home backup, off-grid cabins, and outdoor adventures alike.
  • 25% Solar Efficiency: Bifacial design captures sunlight from both sides for up to 25% more energy
  • All-Day Energy from One Panel: A full day of sun can cover your daily outdoor power needs.
Size
Accessories
EcoFlow Solar Extension Cable
R 399 ZAR
R 499 ZAR
XT60 | XT60i
R 499 ZAR
XT60 | XT60i
R 399 ZAR
Pay over 3 EQUAL zero-interest instalments of R 0.00 with PayJustNow.
Find out how...
Capture more energy with a dual-sided design
With a 220W primary side, and a 175W side on the back for ambient light, you can capture up to 28% more solar energy and charge your portable power station even faster.
Generate even more energy
With the portable solar panel industry's first use of TOPCon solar technology,
we've raised the bar on conversion efficiency, reaching 25%.
Charge faster with a more compact panel.
Capture more solar with an adjustable angle
With a newly integrated solar angle guide and stand,
adjust the angle of the panel by 30 degrees in seconds to get the most sunshine at all times.
Durable and waterproof
Built to weather the storm
With an IP68 waterproof rating, our NextGen 220W Bifacial Solar Panel maintains its high performance even when it's in contact with water. So you can recharge near a lake or take it out on your boat without worry!
Never too hot
Designed to withstand high temperatures while still ensuring high levels of solar generation.
Lightweight and portable
Generate solar energy anywhere with our compact-designed panels. Fold away to store in your van or closet, pull them out in seconds to start using.
EcoFlow Solar Panel Comparison
NextGen vs. Original
NEW
EcoFlow NextGen Portable Solar Panel
EcoFlow Portable Solar Panel
Cell Type
N Type TOPCon
monocrystalline silicon
P Type PERC
Conversion Efficiency
Weight
(5.1 kg-7.2 kg)
(5.6 kg-9.5 kg)
Stand Type
30-60° Integrated Adjustable Stand
Separate Kickstand Case
Additional Feature
Integrated Solar Angle Guide
No Solar Angle Guide
What’s in the box
XT60i Charging Cable
Quick Start Guide, Safety Instructions & Warranty Card
Rated Power
220W (±5W) Front/175W Rear
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25.00%
Weight (Solar Panel)
Approx. 15.4 lb (7.0 kg)
Unfolded: 24.2×84.8×1.0 in/615×2155×25 mm
Folded: 24.2×23.2×1.3 in/615×590×32 mm
Connector Type
Photovoltaic connectors
Warranty (US)
12 months
Open Circuit Voltage
21.5V (Vmp 18.4V)
Short Circuit Current
12.4A (Imp 11.9A) Front Side/ 9.9A (Imp 9.5A) Rear Side
Waterproof & Dustproof
Never miss a sale🎉
