EcoFlow 400W Rigid Solar Panel | EcoFlow South Africa
R 8,000.00 ZAR
Regular price R 8,000.00 ZAR
Sale price R 8,000.00 ZAR Regular price R 9,999.00
Save up to R 1,999
The solar to XT60 charging cable and mounting feet are not included with this product.
• A 23% conversion rate to sunlight
• Fast and Easy Installation
10-Year Workmanship Warranty
25-year 80% Power output warranty(Excluding charge controller and wire defects.
The power output will be measured under standard measurement conditions.)
Each 400W rigid solar panel requires one mounting set for proper installation.
As this product includes 2 panels, a total of 2 mounting sets are required.
You can choose the mounting option that fits your setup:
• Mounting Feet — for flat ground setups
• 50” Tilt Mount Bracket — for angled installations to improve solar performance
EcoFlow 50” Tilt Mount Bracket (2 Sets)
R 3,998 ZAR
For Angled Installations to Optimize Sun Exposure
R 399 ZAR
XT60 | XT60i
EcoFlow Solar Extension Cable
R 399 ZAR
R 399 ZAR
XT60 | XT60i
R 399 ZAR
XT60 | XT60i
EcoFlow Solar Angle Guide
R 399 ZAR
Keep Sunlight at A 90° Angle
R 8,000 ZAR R 9,999 -R 1,999
Pay over 3 EQUAL zero-interest instalments of R 2,666.66 with PayJustNow.
Find out how...
High Solar Energy Conversion
Made from highly efficient monocrystalline cells, the 400W rigid solar panel has an excellent efficiency rating of 23%, allowing you to charge faster than using similar-sized panels. Combine this panel as part of your existing PV system or Power Kits setup, and allow the integrated MPPT algorithm to optimize your solar input.
Waterproof & Durable
The 400W rigid solar panel is designed for the outdoors. With an IP68* waterproof rating and a robust anti-corrosive aluminum frame, the panel can withstand a wind speed of up to 130mph* and a significant snow load of up to 113lb* and continue to capture solar energy for years to come.
*Well-mounted solar panels can withstand a dynamic 2400pa wind pressure load (130mph wind speed) and a static 5400pa snow load (113lb per sq foot of snow).
Off-grid & On-grid Solution
This high-wattage panel works for both on-grid and off-grid solar-powered setups, storing energy for outages, reducing power bills, or powering an off-grid home.
Universally Compatible
EcoFlow solar panels use an all-inclusive solar connector, so you can even use them with your existing 48V power system. The 400W solar panel includes a 300mm charging cable that gives you plenty of space to mount multiple panels, maximizing solar input.
What's in the box?
1. 2×400W Rigid Solar Panel
2. User Manual and Warranty Card
*The solar to XT60 charging cable is NOT included in EcoFlow portable solar panels. Click here to get a solar to XT60i charging cable.
Installation Guide
Short Circuit Current
13.79A
Open Circuit Voltage
37.10V
Connector Type
Solar Connector
Efficiency
23%
Cell Type
Monocrystalline
Rated Power
400W
Maximum Operating Voltage
31.00V
Maximum Operating Current
12.90A
-0.38%/°C
-0.35%/°C
0.06%/°C
Maximum Fuse Current
25A
Maximum System Voltage
1500V DC (UL)
Dimension (inch)
67.8×44.6×1.38
Net Weight (kg)
21.8kg
Dimension (cm)
172.2×113.4×3.5
Net weight (lbs)
48.1lbs
How Can I Claim the Solar Panel Tax Rebate?
As of May 2023, individuals in South Africa can receive a rebate of 25% of the cost of new solar panels from their income tax liability, with a cap of R15,000. Only solar panels with 275W or higher are eligible. No tax write-offs are available for balance of system components like inverters or solar batteries. Learn more about the Solar Tax Incentive for Individuals and how to apply here.
How Much Can I Save on Solar Panels With the Solar Panel Tax Incentive for Individuals?
From May 2023, individual taxpayers in South Africa can claim a 25% tax rebate on purchases of new solar panels with rated power of 275W or higher. The maximum you can save is R15,000. For example, if you bought 8 x 400W rigid solar panels at a cost of R5,000 each for a total of R40,000, you would save R10,000. If you bought 16, you would save R15,000 due to the cap. Learn how to apply here.
Are mounting feet included with rigid solar panels?
No. Mounting feet are not included. A compatible mounting solution is required for installation.Each 400W rigid solar panel requires one mounting set. As this product includes 2 panels, a total of 2 mounting sets are required.You can choose the mounting option that fits your setup:
How many mounting sets do I need for Rigid Solar Panels*2?
Each rigid panel requires one mounting set. Since this bundle includes 2 rigid panels, we recommend using 2 mounting sets for proper installation.
Never miss a sale🎉
