EcoFlow 4kWh Power Kits | EcoFlow South Africa
R 120,997.00 ZAR
Regular price R 120,997.00 ZAR
Sale price R 120,997.00 ZAR Regular price R 120,997.00
• 4 Charging methods include up to 4800W solar, 1000W alternator, 3000W shore power, and 1800W Smart Generator input.
• Plug-and-play for simple assembly
• Compact, integrated design, all-in-one inverter hub
• Save space with stackable batteries
• 48V system, a safer, smaller power solution
• Real-time and remote smart controls
Model
R 120,997 ZAR
Pay over 3 EQUAL zero-interest instalments of R 40,332.33 with PayJustNow.
Find out how...
EcoFlow Power Kits are the world's first integrated, plug-and-play power solutions designed especially for tiny homes and RVs.
I want power for…
Customizable Kits for Any Van Size
Whether you’re replacing your van’s electrics or building a system from scratch, Power Kits plug-and-play system allows you to easily modify your hardware to fit your van and power needs.
Find the battery stack that fits your power needs
Powers All Your Essential Appliances
4 Charging Methods
You might be on the road, but there are plenty of ways to charge, and fast. We’ve designed a new range of rigid and flexible solar panels giving your van a solar input of up to 4800W*. Use your alternator to recharge with 1000W. Spending the night on a campsite? Then take advantage of shore power for an extra 3000W. Caught short? Rely on our Smart Generator for emergency backup.
*Tested using a production model in a closed environment with favorable conditions. Actual results may vary depending on environment, usage, and firmware version.
Watch the video
Setups Made Simple
Simple Assembly
We made our modular system plug-and-play so you can quickly customize your van power whenever you want. Simply stack a battery to increase capacity, or plug in a solar panel for faster charging.
We’ve got experts on-hand to guide you through the installation process or put you in touch with authorized and reputable installers.
Compact &
integrated Design
Unlike other RV power solutions, Power Kits combine five components into one Power Hub that deals with all your power needs, saving you space, money, and set-up hassle. Our 2 and 5kWh batteries securely stack in threes, giving you an expandable capacity of up to 15kWh.
Watch the video
Others
Power Hub
Space-Saving Solutions
To save your valuable space, we shrank down the traditional power kit, integrating components, using thinner wires, and creating a unique stackable battery. Conveniently conceal the Power Hub, batteries and other accessories so they’re out of sight, under seats or in a closet.
48V, a safer, smaller power solution.
Power Kits offer you a safe, 48V power solution for your van. A 48V system produces the same amount of power, but unlike 12Vs, only a quarter of the electric current passes through the wires, producing significantly less heat and power loss.
Smart Controls
Keep an eye on your energy at home and on the go with a whole host of setting options and real-time data tracking accessible from the app and Power Kit Console.
What's included in Power Kits
Learn More
Never miss a sale🎉
