EcoFlow DELTA 2 Solar Generator (PV220W) | EcoFlow South Africa
R 20,999.00 ZAR
Regular price R 20,999.00 ZAR
Sale price R 20,999.00 ZAR Regular price R 24,998.00
Save up to R 5,198
• Generates up to 3kWh daily.
• A 1800W AC output.
• Up to 23% conversion with a unique two-in-one bifacial design to guarantee a fast solar charging speed: 0-100% in 3 hours (2 sets) and 6 hours (1 set).
• IP68 dust and water resistance.
• Smart remote control with EcoFlow app.
• 5-year warranty for DELTA 2 and 24-month warranty for 220W Bifacial Portable Solar Panel.
Number of Solar Panel
EcoFlow Solar Parallel Connection Cable
R 399 ZAR
R 499 ZAR
XT60 | XT60i
R 20,999 ZAR R 24,998 -R 3,999
Pay over 3 EQUAL zero-interest instalments of R 6,999.66 with PayJustNow.
Find out how...
Payment method
Payment method
Payment method
Payment method
EcoFlow DELTA 2 Solar Generator is a must-have for any home that puts power security & comfort first. Ensure you're prepared with the power station made for almost any situation your family could find themselves in. All while staying green.
Make it a triple.
Expand capacity.
With a capacity of 1kWh to start with, you've got enough energy for your essentials for hours on end. Need even more? Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
Go green without sacrificing speed.
More energy
with a two in one bifacial design.
EcoFlow's 220W Bifacial Portable Solar Panel is two in one. With a 220W primary side, and a 155W side on the back for ambient light, you can capture up to 25% more solar energy and charge your portable power station even faster.
Built to last 6x longer.
Power pretty much anything.
A 1800W AC output means you can power more than 90% of your home appliances. That's your microwave, fridge, or even coffee maker covered in a blackout. Or, try plugging in up to 13 devices at once for when you're around the table with the family. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2400W thanks to X-Boost technology.
Control, monitor,
and manage your energy use.
Built to last.
The thin, one-piece tempered glass design of the 220W Bifacial Portable Solar Panel makes it five times tougher than comparable panels with half the thickness of traditional tempered glass. Capable of withstanding heat up to 300°F , it's safe to say it can resist the elements.
1. DELTA 2 2. 220W Solar Panel 3. AC charging cable 4. Car charging cable 5. DC5521 to DC5525 cable 6. User manual 7. App quick start guide 8. Warranty card
*The solar to XT60 charging cable is included only with purchase of EcoFlow portable solar panels.
Specs of DELTA 2
1024 Wh
Extra Battery
4 outlets, 1800W total (Surge 2700W)
2400W
2 ports, 5V, 2.4A, 12W Max
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A, 38W Max
AC Charging
1200W
11-60V, 15A, 500W max
Car Charging
Support 12V/24V battery, 8A
DC Charging
1100W
LFP (LiFePO4 battery)
Cycle life
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
27 lbs / 12 kg
Specs of 220W Solar Panel
Rated Power
220W Front Side/155W Rear Side
Cell Type
Monocrystalline silicon
Efficiency
22-23%
82*183*2.5cm (32.3*72.0*1.0 in)
Open Circuit Voltage
21.8V (Vmp 18.4V)
Short Circuit Current
13A (Imp 12.0A) Front Side/ 8.8A (Imp8.4A) Rear Side
Weight (Solar Panel)
Approx. 9.5kg
Never miss a sale🎉
