EcoFlow DELTA 2 Solar Generator is a must-have for any home that puts power security & comfort first. Ensure you're prepared with the power station made for almost any situation your family could find themselves in. All while staying green.
With a capacity of 1kWh to start with, you've got enough energy for your essentials for hours on end. Need even more? Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
EcoFlow's 220W Bifacial Portable Solar Panel is two in one. With a 220W primary side, and a 155W side on the back for ambient light, you can capture up to 25% more solar energy and charge your portable power station even faster.
3000+
Full charge and drain cycles
Finally… tech that's made to last. Get years of regular use until hitting 80% of its original capacity. That's down to its LiFePO4 battery chemistry giving you 3000+ full charge and drain cycles.
A 1800W AC output means you can power more than 90% of your home appliances. That's your microwave, fridge, or even coffee maker covered in a blackout. Or, try plugging in up to 13 devices at once for when you're around the table with the family. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2400W thanks to X-Boost technology.
| The thin, one-piece tempered glass design of the 220W Bifacial Portable Solar Panel makes it five times tougher than comparable panels with half the thickness of traditional tempered glass. Capable of withstanding heat up to 300°F , it's safe to say it can resist the elements. | ![]() |
1. DELTA 2 2. 220W Solar Panel 3. AC charging cable 4. Car charging cable 5. DC5521 to DC5525 cable 6. User manual 7. App quick start guide 8. Warranty card
*The solar to XT60 charging cable is included only with purchase of EcoFlow portable solar panels.
1024 Wh
4 outlets, 1800W total (Surge 2700W)
2400W
2 ports, 5V, 2.4A, 12W Max
1 port, 12.6V, 10A, 126W Max
2 ports, 12.6V, 3A, 38W Max
1200W
11-60V, 15A, 500W max
Support 12V/24V battery, 8A
1100W
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Wi-Fi & Bluetooth
27 lbs / 12 kg
220W Front Side/155W Rear Side
Monocrystalline silicon
22-23%
82*183*2.5cm (32.3*72.0*1.0 in)
21.8V (Vmp 18.4V)
13A (Imp 12.0A) Front Side/ 8.8A (Imp8.4A) Rear Side
Approx. 9.5kg
Subscribe to our emails and receive an R500 discount on your first order over R5,000.
Your R500 voucher is waiting in your inbox. Spend R5,000 and save R500!
*Note: EcoCredits can be redeemed for discounts and gifts. Learn More
