EcoFlow DELTA 2 Solar Generator (PV400W) | EcoFlow South Africa
R 22,499.00 ZAR
🔥Black Friday
Regular price R 22,499.00 ZAR
Sale price R 22,499.00 ZAR Regular price R 26,499.00
Save R 4,000
EcoFlow DELTA 2 solar generator: Secure your power supply with an EcoFlow DELTA 2 solar generator bundle at home or on the go. Plug in 400W Portable Solar Panels and get up to 500W input to charge from anywhere in as fast as 3 hours. These bundles are ideal for home power security, camping, fishing, or any outdoor trips.
Expandable home emergency power 1-3kWh expandable capacity to grow your storage to your needs. Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
Rapid dual charging X-Stream tech means that DELTA 2 charges 7 times faster than the competition. That's 0–80% in just 50 minutes and 0-100% in 80 minutes with AC input.
Power multiple devices Power multiple devices 1800W AC output means you can power more than 90% of your home appliances. Or, try plugging in up to 13 devices at once. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2400W thanks to X-Boost technology. Learn more about DELTA 2 >>
Tempered glass. Built to last The thin, one-piece tempered glass design makes it five times tougher than comparable panels, it can withstand heat up to 300°F too. Safe to say it can withstand the elements. Learn more about 400W Portable Solar Panel >>
Number of Solar Panel
EcoFlow DELTA 2 Bag
R 999 ZAR
EcoFlow Solar to XT60 Charging Cable
R 399 ZAR
XT60 | XT60i
R 22,499 ZAR R 26,499 -R 4,000
Pay over 3 EQUAL zero-interest instalments of R 7,499.66 with PayJustNow.
Find out how...
EcoFlow DELTA 2 is a must-have for any home that puts power security & comfort first. Ensure you're prepared with the power station made for almost any situation your family could find themselves in. All while staying green.
With a capacity of 1kWh to start with, you've got enough energy for your essentials for hours on end. Need even more? Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
Use an extra battery to expand capacity. Great for extended power outages, long camping trips, or your RV.2kWh
with 1x DELTA 2 Extra Battery
3kWh
with 1x DELTA Max Extra Battery
DELTA 2DELTA 2 Extra BatteryDELTA Max Extra Battery
2kWh with 1x DELTA 2 Extra Battery
3kWh with 1x DELTA Max Extra Battery
Power pretty much anything.
A 1800W AC output means you can power more than 90% of your home appliances. That's your microwave, fridge, or even coffee maker covered in a blackout. Or, try plugging in up to 13 devices at once for when you're around the table with the family. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2400W thanks to X-Boost technology.
Pair with solar panels and charge in as fast as 3-6 hours with 1x400W, 2x220W portable solar panels. With its MPPT (Maximum Power Point Tracking) smart algorithm, DELTA 2 can actively detect the voltage and current in real-time to reach the maximum power point with >98% efficiency. That means a more efficient charge than other brands.
Pick from a range of solar panels to get the speed you need (110W, 160W, 220W, 400W). With that, you've got access to free energy anywhere.
Built to last 6x longer.
Finally… tech that's made to last. Get years of regular use until hitting 80% of its original capacity. That's down to its LiFePO4 battery chemistry giving you 3000+ full charge and drain cycles.
Safety first
Safety first
Ready for emergencies.
Control from anywhere.
1. DELTA 2 2. AC charging cable 3. Car charging cable 4. DC5521 to DC5525 cable 5. User manual 6. App quick start guide 7. Warranty card
*The solar to XT60 charging cable is included only with purchase of EcoFlow portable solar panels.
Specs of DELTA 2
1024 Wh
Extra Battery
4 outlets, 1800W total (Surge 2700W)
2400W
2 ports, 5V, 2.4A, 12W Max
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A, 38W Max
AC Charging
1200W
11-60V, 15A, 500W max
Car Charging
Support 12V/24V battery, 8A
DC Charging
1100W
LFP (LiFePO4 battery)
Cycle life
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
27 lbs / 12 kg
Specs of 400W Solar Panel
Rated Power
400W
Cell Type
Monocrystalline silicon
Efficiency
22.40%
41.7*93.1*1.0 in (105.8*236.5*2.4cm)
Connector Type
MC4
Open Circuit Voltage
48V (Vmp 41V)
Short Circuit Current
11A (Imp 9.8A)
Weight(Solar Panel)
Approx. 27.6lbs (12.5Kg)
Weight (with Kickstand Case)
34.2lbs / 15.5kg
Customer Reviews
Based on 4 reviews
25%
(1)
0%
(0)
0%
(0)
0%
(0)
75%
(3)
R
Ruan
Worst customer service and delivery - Update
So, after hours and hours of struggling to chat with people that don't even know what's going on in their own company. No one knows where my 400W solar panels is, not Ecoflow nor the courier company they use Buffalo logistics South Africa. No one seems to know where the solar panel got lost in translation, I can't reach anyone of these two companies via email, online live chat or by phone.... If you ask me this whole site is a scam and I have been scammed! The only replies I get from EcoFlow is from my reviews I write, nothing about the thousands of Rands worth of products I have bought! Worst, absolute rubbish service and I still don't have my product after 10 days with no reply!!!!!
R
Ruan
I have bought the Delta 2 solar generator, it includes the Delta 2 and a 400W portable solar panel. I eventually received my D2 after 9 days, they have even sent it to the wrong branches twice... After delivery I have found that there is no solar panel! Still waiting on a reply on email or to get hold of anyone! You would think that a company this big will have better service, but no just an automated reply and no online help. I'll be honest, I regret buying this product for so much money! Just imagine how the after service will be like....
I
Ion
100% recommend
Dealing with EcoFlow has been an absolute blast. From customer service to delivery time. Received the Panel one day after ordering and the Ecoflow itself 2 days after ordering (Based in Jhb). Have been using it for almost 2 months. Great products. Will recommend this for camping and a small backup at home for load-shedding.
R
R.H.
Worst Delivery and customer experience of all time!
I have bought a Delta2 and portable PV panel bundle more than a week ago. I have received an email the following day confirming my bundle has been handed over to the courier. A few days later only the portable PV panel was delivered. I tried to follow up via the email address provided as I was concerned that my entire order has not been delivered. I only received a generic automated response from Ecoflow. I then tried to contact the courier company who confirmed they would get back to me. I am still waiting for that phone call. I then followed up with Ecoflow again, who assured me they will have the problem solved, and that the Delta 2 will be delivered separately. I have from then followed up with Ecoflow and the courier company daily with zero results. Today marks a week and a day since I have placed my order with NO Delta2 Delivered. It is extremely concerning that buy a product in excess of R35k on an online purchase and you are never sure where your parcel is. I have bought items for R30 online and have been kept informed on the whereabouts of my parcel the entire route. It is shocking that you pay this kind of money, and there is almost ZERO after sales support from Ecoflow! If this is the kind of support given just to get the parcel delivered then I have major concerns with technical support in the future. I am on the brink of cancelling my order and buying from a supplier that actually cares about their customers and do not merely rely on the name of the product they sell to keep them in business. Customer retention lies in the relationship you cultivate, not merely in the product.
Never miss a sale🎉
