EcoFlow DELTA 2 Portable Power Station | EcoFlow South Africa
R 21,499.00 ZAR
Hot
Video
Hot
Regular price R 21,499.00 ZAR
Sale price R 21,499.00 ZAR Regular price R 21,499.00
This portable power station is equipped with South African standard plugs.
Level up with the EcoFlow PowerStream Balcony Solar System:
Pair with an EcoFlow PowerStream Microinverter and gain a grid-tied solar energy solution that powers your home day and night.
• 1-3 kWh Expandable capacity
• Huge AC output
• 7x Faster AC charging
• Built to last 6x longer
• Control from anywhere
• 5-Year warranty
Accessories
EcoFlow DELTA 2 Bag
R 999 ZAR
R 10,999 ZAR R 13,999 ZAR
EcoFlow Smart Plug
R 499 ZAR
Wi-Fi-Operated Plug
EcoFlow 400W Rigid Solar Panel
R 7,999 ZAR R 10,999 ZAR
23% Conversion Rate
EcoFlow Super Flat Cable
R 499 ZAR
R 8,999 ZAR R 20,999 ZAR
23% Conversion Rate
EcoFlow DELTA 2 Bag
R 999 ZAR
23% Conversion Rate
EcoFlow Solar to XT60i Charging Cable
R 399 ZAR
XT60 | XT60i
EcoFlow Smart Plug
R 499 ZAR
Wi-Fi-Operated Plug
23% Conversion Rate
R 499 ZAR
R 21,499 ZAR
Pay over 3 EQUAL zero-interest instalments of R 7,166.33 with PayJustNow.
Find out how...
A transfer switch is a device that switches a load between Grid Power and Backup Power, simply connect EcoFlow Portable Power Station to your main panel via a Transfer Switch for instant home backup (Transfer Time 1~2s).
*Picture for reference only, subject to our available products.
*AC Plug Cable is needed to connect Power Station with Transfer Switch, and be provided by the electrician.
Learn more about how to backup your home with our Portable Power Station and Transfer Switch: Whole-Home Backup Kit User Guide
EcoFlow DELTA 2 is a must-have for any home that puts power security & comfort first. Ensure you're prepared with the power station made for almost any situation your family could find themselves in. All while staying green.
With a capacity of 1kWh to start with, you've got enough energy for your essentials for hours on end. Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
Use an extra battery to expand capacity. Great for extended power outages, long camping trips,
or your RV.
Power pretty much anything.
A 1800W AC output means you can power more than 90% of your home appliances. That's your microwave, fridge, or even coffee maker covered in a blackout. Or, try plugging in up to 13 devices at once for when you're around the table with the family. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2400W thanks to X-Boost technology.
Want to know how long DELTA 2 can support your use?
Add up the wattage of the electrical appliances you supply at the same time.
(Click here to view the wattage of common-used appliances.)
W
Estimated comprehensive runtime
Appliances
Estimated Watts
EcoFlow DELTA 2
Wi-Fi router
10W (AC)
58 hrs
Phone
11Wh (Type-C)
89 times
Fan
40W (AC)
17 hrs
50" TV
110W (AC)
7.9 hrs
Refrigerator
120W (AC)
7-14hrs
Laptop
60Wh (Type-C)
16 times
PS5
200W (AC)
4.6 hrs
PC
500W (AC)
1.8 hrs
Coffee maker
1000W (AC)
0.8 hrs
Camera
16Wh (USB)
60 times
Light
10W (AC)
58 hrs
Light
10W (DC)
98 hrs
Washer
500W (AC)
1.8 hrs
Blender
500W (AC)
1.8 hrs
Drone
40Wh (Type-C)
25 times
Speaker
10W (AC)
58 hrs
CPAP
40W (AC)
17 hrs
Electric blanket
50W (AC)
14 hrs
Mini/Car fridge
60W (DC)
16-32hrs
Projector
65W (AC)
12 hrs
Electric blanket
120W (AC)
7 hrs
Baby food maker
300W (AC)
3 hrs
Pressure cooker
900W (AC)
1 hour
Rice cooker
1000W (AC)
0.8 hrs
Electric drill
1080W (AC)
0.7 hrs
Cutting machine
1100W (AC)
0.7 hrs
Electric grill
1150W (AC)
0.7 hrs
Electric frying pan
1200W (AC)
0.7 hrs
Electric hammer
1260W (AC)
0.6 hrs
Microwave
1300W (AC)
0.6 hrs
Circular Saw
1400W (AC)
0.6 hrs
Air fryer
1500W (AC)
0.5 hrs
Electric kettle
1500W (AC)
0.5 hrs
Hair dryer
1600W (AC)
0.5 hrs
Electric oven
1650W (AC)
0.5 hrs
Air conditioner
1800W (AC)
0.4 hrs
Induction cooker
1800W (AC)
0.4 hrs
Electric heater
2200W (AC)
0.4 hrs
If you want more battery life, you can get 3X battery life with an 2kWh extra battery at most
*This battery life is for calculation reference only, and the specific battery life may vary depending on the actual situation
Go green without sacrificing speed.
Pair with solar panels and charge in as fast as 3-6 hours with 1x400W, 2x220W portable solar panels. With its MPPT (Maximum Power Point Tracking) smart algorithm, DELTA 2 can actively detect the voltage and current in real-time to reach the maximum power point with >98% efficiency. That means a more efficient charge than other brands.
Pick from a range of solar panels to get the speed you need (110W, 160W, 220W, 400W). With that, you've got access to free energy anywhere.
Built to last 6x longer.
Finally… tech that's made to last. Get years of regular use until hitting 80% of its original capacity. That's down to its LiFePO4 battery chemistry giving you 3000+ full charge and drain cycles.
Safety first
Ready for emergencies.
Control from anywhere.
What's in the Box
1. DELTA 2 2. AC charging cable 3. Car charging cable 4. DC5521 to DC5525 cable 5. User manual 6. App quick start guide 7.Warranty card
*The solar to XT60 charging cable is included only with purchase of EcoFlow portable solar panels.
What is the warranty for the Ecoflow transfer switch?
The EcoFlow transfer switch comes with a 1-year warranty.
How do you install the transfer switch?
What are the issues with installation of the transfer switch cost?
How much will the installation of the transfer switch cost?
Where can I find a licensed electrician?
Can I install the transfer switch myself?
Will it cause damage to EcoFlow Potable Power Stations when overloading in powering loads in the house?
How long does the transfer switch, switch a load from utility power to backup power when load shedding occurs?
What's the difference between Transfer Switch and Smart Home Panel?
1024 Wh
Extra Battery
6outlets, 1800W total (Surge 2700W)
2200W
2 ports, 5V, 2.4A, 12W Max
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A, 38W Max
AC Charging
1200W
11-60V, 15A, 500W max
Car Charging
Support 12V/24V battery, 8A
DC Charging
1100W
LFP (LiFePO4 battery)
Cycle life
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
27 lbs / 12 kg
Specs of Transfer Switch
Controller type
Type A controller
Operating voltage
AC185V~280V
Installation method
Integrated
Working position
2 working positions
Operating mode
Automatic operation, Manual operation
Generator control
Fire linkage control
Conversion mode
Self-throwing and self-reset
Transfer delay
Fixed 0.2 seconds
Return delay
Fixed 0.2 seconds
Customer Reviews
Based on 10 reviews
90%
(9)
0%
(0)
0%
(0)
10%
(1)
0%
(0)
R
Riaan Hollenbach
Worst Delivery and customer experience of all time!
I have bought a Delta2 and portable PV panel bundle more than a week ago. I have received an email the following day confirming my bundle has been handed over to the courier. A few days later only the portable PV panel was delivered. I tried to follow up via the email address provided as I was concerned that my entire order has not been delivered. I only received a generic automated response from Ecoflow. I then tried to contact the courier company who confirmed they would get back to me. I am still waiting for that phone call. I then followed up with Ecoflow again, who assured me they will have the problem solved, and that the Delta 2 will be delivered separately. I have from then followed up with Ecoflow and the courier company daily with zero results. Today marks a week and a day since I have placed my order with NO Delta2 Delivered. It is extremely concerning that buy a product in excess of R35k on an online purchase and you are never sure where your parcel is. I have bought items for R30 online and have been kept informed on the whereabouts of my parcel the entire route. It is shocking that you pay this kind of money, and there is almost ZERO after sales support from Ecoflow! If this is the kind of support given just to get the parcel delivered then I have major concerns with technical support in the future. I am on the brink of cancelling my order and buying from a supplier that actually cares about their customers and do not merely rely on the name of the product they sell to keep them in business. Customer retention lies in the relationship you cultivate, not merely in the product.
S
Steve Hefferman
Great Product!
We bought the Delta 2 after searching and weighing all of our options. EcoFlow seemed like a no brainer compared to the rest of the products available in South Africa. The charge time is great, we use it for our TV (50 inch) our wifi router as well as the work station which has a laptop a second screen and a printer. The 30ms switch time works like a charm, Wi-Fi and TV does not cut out at all and stays switched on. It lasts two hours and still has 60%+- battery left. We will be buying the River 2 to also add to the arsenal which will power our freezer and fridge. Delta 2 is recommended over the Delta 1 as the battery is far better and has 3000+ cycles guarantee on the battery compared to 800 on the Delta 1.
G
Gideon Swanepoel
Happy customer
Bought my Ecoflow Delta 2 in May, my wife is very happy! Good quality product and i will buy the Delta Max extra battery soon. Only one issue with the Delta 2, where can I buy the new sans 164-2 plugs that will fit the 2 x plug inlets at the back? I bought 2 x plugs from my local electrical supplier, the pins lign up but is slightly fatter and do not go in.
C
Customer
Disappointing Service
While EcoFlow has a good name around the world and produces a good product, after purchasing the Delta 2 in South Africa, it is difficult to get support for the product. The delta 2 rated at 1800 watts and 2400 watts on boost, is unable to run the microwave rated at 1350 watts. It only works now and then, running for long periods once going. You never know if it will start up or not. The support team is telling me that the microwave is too big for the Delta 2. That does not make sense and after spending so much money, it should be able to constantly do what it says it can do…. This is very disappointing. Here’s hoping someone will see this and help us.
M
Matt E.
Delta 2 is fantastic
I love my Delta 2, in fact so much that I bought the Delta 2 Extra battery as well. And with my solar panels hooked up to it, I almost rarely make use of grid power, even when boiling my kettle or using my microwave.
Lasts me an entire night watching TV, 55" or 65", running lights, fridge, electric blankets, bedside lamps, the occasional electric blankets for when it gets REALLY cold as well as my Air Purifier right through the night until my solar can take over again the next morning.
Just wished the Smart Generator would have been compatible with this unit for those emergency, VERY LONG lasting cable theft outages at night.
Never miss a sale🎉
