EcoFlow DELTA Pro + Extra Battery Bundle | EcoFlow South Africa
EcoFlow DELTA Pro + DELTA Pro Smart Extra Battery
R 68,099.00 ZAR
Regular price R 68,099.00 ZAR
Sale price R 68,099.00 ZAR Regular price R 109,998.00
Save R 41,899
This plug is equipped with European standard plugs. Adapters will be needed to use the product. To assist our customers, we offer a special code as an adapter subsidy.
DELTA Pro Adapter Subsidy Code: DPadapter
Colossal capacity DELTA Pro harnesses a staggering 3.6kWh capacity which can be expanded up to 25kWh. This combined with its direct integration with your home via the Smart Home Panel allows you to always keep the power on.
Power almost anything When it comes to AC output DELTA Pro is the industry leader. With 3600W, it’s easy to power heavy-duty appliances from microwaves to AC units. Looking for even more power? The EcoFlow Smart Home Panel allows you to pair two units together to hit a massive 7200W output.
Unparalleled charging speeds Enjoy the versatility of DELTA Pro with FlowCharge. With 6 different charging options from renewable energy sources to traditional wall outlets, you can charge anywhere, any time. It’s the first of its kind that can be charged from an EV station, and thanks to MultiCharge you can combine charging options to reach a 6500W charge.
Expandable capacity This add-on battery connects with a DELTA Pro to double total capacity to 7200Wh. Connect two of them to DELTA Pro for a staggering 10.8kWh to use off-grid.
Convenient recharging Recharging from solar panels, AC outlets, EV charging stations, or our Smart Generator is easy. Plug the Extra Battery into DELTA Pro and they will recharge and discharge in tandem.
Click here to learn more about DELTA Pro Smart Extra Battery.
Click here to learn more about DELTA Pro Portable Power Station.
EcoFlow DELTA Pro Bag
R 1,799 ZAR
EcoFlow DELTA Pro to Smart Generator Adapter
R 1,999 ZAR
R 68,099 ZAR R 109,998 -R 41,899
Pay over 3 EQUAL zero-interest instalments of R 22,699.66 with PayJustNow.
Find out how...
Payment method
Payment method
Payment method
Payment method
Introducing the world's first portable home battery with an expandable ecosystem for home backup, smart energy management, lower energy bills, and more. The EcoFlow DELTA Pro is the next leap in portable power technology, offering you power security and independence, wherever you are.
Expandable Capacity
Power Pretty Much Anything (3600W-7200W Output)
World's Fastest Charging (MultiCharge 6500W)
Home Integration
Power for any situation.
All the AC output you'll need.
A single DELTA Pro unit packs a 3600W AC output, which can be expanded up to 4500W with X-Boost technology. Power 99.99% heavy-duty devices at home, outdoors, or at work. You can even pair two units together to achieve 7200W with Smart Home Panel.
The world's fastest charging portable power station.
Fully charge in 1.9 hours.
EcoFlow's X-Stream charging technology isn't just fast, it's safe too. The battery management system ensures safety and longevity while you fully charge DELTA Pro from a standard AC wall outlet in 1.9 hours*.
Charge up at thousands of EV stations worldwide.
For the first time ever with a portable power station, you can charge up at thousands of EV stations worldwide. This unique charging method gives you up to 3400W fast charging on the go.
Go renewable with 1600W solar charging.
EcoFlow's suite of solar products give you a cost-effective renewable energy source to stay powered. You can use solar energy to charge DELTA Pro in just 2.8-5.6 hours. DELTA Pro has a wide voltage range from 11-150V, which makes it compatible with 90% of third-party solar panels with solar connectors. And when the weather gets unpredictable, the smart maximum power point tracking (MPPT) automatically adjusts, maximizing your solar generation at any time of the day.
Get emergency backup power with the EcoFlow Smart Generator.
The EcoFlow Smart Generator serves as an emergency option that integrates with your DELTA Pro ecosystem. It auto-starts when your DELTA Pro hits a low level of charge, re-charges your DELTA Pro, and stops the engine all by itself once your DELTA Pro hits a full charge. Compared to a traditional gas generator, the EcoFlow Smart Generator delivers less energy loss, faster charging and higher efficiency.
DELTA Pro sports a brand-new LFP battery with 6500 cycles, which means you can use DELTA Pro for years and years before your unit reaches 50% of the original capacity. EcoFlow's battery management system provides real-time analysis and regulation of voltage, current, and temperature. This unique protection mechanism makes DELTA Pro an incredibly safe and efficient home battery.
Multiple ways to control & monitor.
Control DELTA Pro either on the unit itself, using the remote control accessory, or unlock a ton of customization via the EcoFlow app. On the app, you can access your power settings, such as charging and discharging levels, AC charge speeds, control the Smart Generator and a whole lot more.
The world's first portable home battery ecosystem.
DELTA Pro's expandable ecosystem provides you with power during blackouts, customizable energy around the clock, and lower energy bills. How does it achieve all this? With a selection of extra batteries, smart generators, solar trackers, wind turbines, a smart home panel, and more. From backup power to reducing your reliance on the grid with green alternatives, the DELTA Pro ecosystem can be customized to your needs.
Introducing the EcoFlow Smart Home Panel.
The new EcoFlow Smart Home Panel is the heart of the DELTA Pro home battery ecosystem. It integrates up to two DELTA Pro units with 10 home circuits. Each DELTA Pro can be connected with extra batteries, solar panels, or smart generators, giving you uninterrupted power during blackouts, smart energy management for your critical loads, and lower energy bills.
Uninterrupted home backup.
With a fast 20ms switchover time, DELTA Pro and the Smart Home Panel can keep you powered on during a blackout. All the while, the EcoFlow app keeps you in the know, letting you select and modify your device priorities.
Smart Energy Management.
The EcoFlow DELTA Pro ecosystem stores energy day and night, reducing your reliance on the grid and lowering your energy bills by combating time-of-use rates. It integrates directly with your home using the EcoFlow Smart Home Panel. The EcoFlow app gives you a smart breakdown of your energy habits, and you can customize your energy usage for any type of situation.
RV living made easy.
With DELTA Pro, you can take home with you, wherever you go. It features wheels and a suitcase-esque extendable handle that makes transport easy.
Power that means business.
Not only does DELTA Pro provide home backup and off-grid power, it also gives you a secure power source for any type of professional work. Whether you're working at home or outdoors, from DIY to professional projects, DELTA Pro helps you get the job done.
1.DELTA Pro 2.AC Charging Cable 3.Car Charging Cable 4.DC5521 to DC5525 cable 5.Handle Cover 6.User Manual
When charging DELTA Pro and its extra battery together, you can reach 6500W max charging speeds by combining AC, solar and Smart Generator methods. For DELTA Pro single unit, you can recharge it at standard wall outlets (2900W max), at EV station (3400W max)/Smart Home Panel (3000W max).
It depends on the combined voltage and current of the solar panels you choose. It's fine as long as the solar panels use MC4 connectors and their combined voltage and current are within 11-150 volts and under 15 amps.
First of all, make sure your DELTA Pro is connected to the EcoFlow App using Internet mode. Secondly, go to the Firmware section in the Setting of the DELTA Pro you're looking to upgrade. Check for the latest firmware and follow the steps to finish the upgrade.
Approx. 99lbs/45kg
Dimension
3600Wh
Extra Battery
4500W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
Anderson Port
12.6V, 30A
AC Charging Input
2900W Max, 230V~12.5A
Solar Charging Input
1600W Max, 11-150V, 15A
Car Charging Input
Support 12V/24V battery, 8A
Connection
Wi-Fi, Bluetooth
Never miss a sale🎉
