EcoFlow 110W Lightweight Portable Solar Panel | EcoFlow ZA – EcoFlow South Africa
Regular price R 3,999.00 ZAR
Sale price R 3,999.00 ZAR Regular price R 3,999.00
  • Lightweight and portable for easy setup and transport
  • Up to 25% conversion efficiency with a bifacial design
  • Built-in 2.5m XT60 cable for easy storage and power station connection
  • 30–60° adjustable support stand with an integrated solar angle guide
  • IP68-rated for reliable protection against water and dust
  • Backed by a 5-year warranty for extra peace of mind
Note: Extension cables and parallel/series connection accessories for lightweight solar panels will be available later in 2026.
Type
Accessories
R 3,999 ZAR
Pay over 3 EQUAL zero-interest instalments of R 1,333.00 with PayJustNow.
Find out how...
Ultra-Portable Design
Engineered with advanced lightweight materials, this next-gen solar panel weighs 3.3 kg (0.7 kg lighter than previous models) for effortless transport and compact storage.
Capture More Energy with a Bifacial Design
With a primary panel and rear-side panel for ambient light, output power reaches up to 122W under BNPI test conditions, generating more power from the same amount of sunlight compared to traditional monofacial panels. With industry-leading TOPCon solar technology, the portable solar panel achieves a top-level conversion rate of up to 25%, recharging your power station even faster.
Built-in XT60
The integrated XT60 cable makes it easy to store and seamless to connect to portable power stations for a faster setup.
Built-in XT60
Built-in XT60
Suitable for Various Environments
The folding integrated bracket offers a convenient and compact design. Adjustable from 30°-60°, it's ideal even for most high-latitude areas.
*If you need to hang solar panels for extended periods, please use rigid solar panels. Lightweight portable solar panels are not recommended for this scenario.
Integrated Solar Angle Guide
Keep sunlight at a 90° angle and concentrate the sun's rays onto the surface of your solar panel to get the most light at all times.
Durable and Water-Resistant
Built to weather the storm
With an IP68 water-resistance rating, our 110W Lightweight Portable Solar Panel maintains its high performance even when in contact with water, so you can safely recharge in wet conditions, such as seaside or on a boat.
No Overheating
Designed to withstand high temperatures while still ensuring high levels of solargeneration.
5-Year Warranty
What’s in the box
Rated Power
STC 110W(±5W) / BNPI 122W(±5W)
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25%
Weight (Solar Panel)
3.3kg±0.3kg
1944mm*413mm*26mm
Folded: 544mm*413mm*36mm
Connector Type
XT60I-F
5 years
Open Circuit Voltage
23.5V(Vmp: 19.5V)
Short Circuit Current
STC 6.1A(Imp: 5.9A)
BNPI 6.8A(Imp: 6.5A)
Waterproof & Dustproof
Never miss a sale🎉
