EcoFlow 220W Lightweight Portable Solar Panel | EcoFlow ZA – EcoFlow South Africa
Regular price R 4,599.00 ZAR
Sale price R 4,599.00 ZAR Regular price R 6,099.00
Save up to R 1,500
  • Lightweight and portable for easy setup and transport
  • Up to 25% conversion efficiency with a bifacial design
  • Built-in 2.5m XT60 cable for easy storage and power station connection
  • 30–60° adjustable support stand with an integrated solar angle guide
  • IP68-rated for reliable protection against water and dust
  • Backed by a 5-year warranty for extra peace of mind
Note: Extension cables and parallel/series connection accessories for lightweight solar panels will be available later in 2026.
Type
Accessories
R 4,599 ZAR R 6,099 -R 1,500
Pay over 3 EQUAL zero-interest instalments of R 1,533.00 with PayJustNow.
Find out how...
Capture More Energy with Bifacial Design
With primary and rear-side panels for ambient light, output power reachesup to 243W under BNPI test conditions, generating more power from the same amount of sunlight compared to traditional monofacial panels. With industry-leading TOPCon solar technology, the portable solar panel achieves a top-level conversionrate of up to 25%,recharging your power station even faster.
Ultra-Portable Design
Engineered with advanced lightweight materials, this next-gen solar panel weighs 5.1 kg, 46% lighter than the 220W Bifacial Portable Solar Panel, enabling effortless transport and compact storage.
Built-in XT60
The integrated XT60 cable makes it easier to store and connect to portable power stations for a faster setup.
Built-in XT60
Built-in XT60
Integrated Solar Angle Guide
Keep sunlight at a 90° angle and concentrate the sun's rays onto the surface of your solar panel to get the most light at all times.
Suitable for Various Environments
The folding integrated bracket offers a convenient and compact design. Adjustable from 30°-60°, it's ideal even for most high-latitude areas.
*If you need to hang solar panels for extended periods, please use rigid solar panels. Lightweight portable solar panels are not recommended for this scenario.
Durable and Water-Resistant
Built to weather the storm
With an IP68 water-resistance rating, our 220W Lightweight Portable Solar Panel maintains its high performance even when in contact with water. You can safely recharge in wet conditions, such as seaside or on a boat.
No Overheating
Designed to withstand high temperatures while still ensuring high levels of solargeneration.
5-Year Warranty
What’s in the box
Rated Power
STC 220W/ BNPI 243W
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25.00%
Weight (Solar Panel)
5.1kg±0.3kg
2270mm*598mm*26mm
Folded: 603mm*598mm*36mm
Connector Type
XT60
Built-in cable length: 2.5m
5 years
Open Circuit Voltage
21.4V(Vmp: 18.8V)
Short Circuit Current
STC Isc 12.2A (Imp 11.7A)
BNPI Isc 13.5A (Imp 12.9A)
Waterproof & Dustproof
Never miss a sale🎉
