EcoFlow 400W Lightweight Portable Solar Panel | EcoFlow ZA – EcoFlow South Africa
Regular price R 8,499.00 ZAR
Sale price R 8,499.00 ZAR Regular price R 10,999.00
Save up to R 2,500
  • Lightweight and portable for easy setup and transport
  • Up to 25% conversion efficiency with a bifacial design
  • Built-in 3.5m XT60 cable for easy storage and power station connection
  • 30–60° adjustable support stand with an integrated solar angle guide
  • IP68-rated for reliable protection against water and dust
  • Backed by a 5-year warranty for extra peace of mind
Note: Extension cables and parallel/series connection accessories for lightweight solar panels will be available later in 2026.
Size
Accessories
Pay over 3 EQUAL zero-interest instalments of R 0.00 with PayJustNow.
Find out how...
Capture More Energy with Bifacial Design
With primary and rear-side panels for ambient light, output power reaches up to 445W under BNPI test conditions, generating more power from the same amount of sunlight compared to traditional monofacial panels. With industry-leading TOPCon solar technology, the portable solar panel achieves a top-level conversion rate of up to 25%, recharging your power station even faster.
Ultra-Portable Design
Engineered with advanced lightweight materials, this next-gen solar panel is 5.8 kg lighter than previous models for effortless transport and compact storage.
Suitable for Various Environments
The folding integrated bracket offers a convenient and compact design. Adjustable to 30°, 45°, and 60°, making it ideal for most high-latitude areas. Adjustable stand with 30°, 45°, and 60° positions
* If you need to hang solar panels for extended periods, please use rigid solar panels. Lightweight portable solar panels are not recommended.
Integrated Solar Angle Guide
Keep sunlight at a 90° angle and concentrate the sun's rays onto the surface of your solar panel to get the most sunshine at all times.
Durable and Water-Resistant
Built to weather the storm
With an IP68 water-resistance rating, our 400W Lightweight Portable Solar Panel maintains its high performance even when in contact with water. You can safely recharge in wet conditions, such as seaside or on a boat.
No Overheating
Designed to withstand high temperatures while still ensuring high levels of solar generation.
5-Year Warranty
What’s in the box
Rated Power
400W (±10W)
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25.00%
Weight (Solar Panel)
Approx. 10.2kg ± 0.3 kg
Unfolded: 2509 x 967 x 26 mm
Folded: 659 x 967 x 36 mm
Connector Type
XT60
5 years
Open Circuit Voltage
39.3V (Vpm 34.5V)
Short Circuit Current
12.2A (Ipm 11.7A)
Waterproof & Dustproof
Never miss a sale🎉
