DELTA 3 Max Solar Generator | EcoFlow ZA – EcoFlow South Africa
EcoFlow DELTA 3 Max Solar Generator
R 29,099.00 ZAR
Regular price R 29,099.00 ZAR
Sale price R 29,099.00 ZAR Regular price R 31,999.00
Save up to R 2,900
  • Complete Solar Setup: Pair DELTA 3 Max with a 220W or 400W Lightweight Solar Panel.
  • Home & Work Backup: Power larger essentials such as fridges, TVs, routers, and office setups.
  • Reliable Stored Power: 2kWh capacity and 2400W AC output support higher backup power needs.
  • Recommended Solar Recharge: Recharge DELTA 3 Max in approx. 6.4 hours with the recommended 400W panel.
  • Easy Solar Setup: The 400W panel includes a built-in 3.5m XT60 cable and an adjustable stand.
  • Built for Outdoors: IP68-rated solar panel protection helps guard against water and dust.
R 29,099 ZAR R 31,999 -R 2,900
Pay over 3 EQUAL zero-interest instalments of R 9,699.66 with PayJustNow.
Find out how...
Payment method
Payment method
Payment method
Payment method
2400W Output— Powerful. Stable. Built to Handle It All
EcoFlow DELTA 3 Max (2048Wh) delivers 2400W AC rated output. With X-Boost™ 3.0 technology, it supports devices up to 3200W—effortlessly taking on your heavy-duty appliances. The inverter samples AC voltage and current every 33μs with high precision using a DSP chip, ensuring pure sine wave output with beyond grid-level stability—ideal for powering sensitive electronics reliably.
Kitchen
Kitchen
Living Room
Living Room
Office
Office
Garage
Garage
Laundry Room
Laundry Room
RV Camping
RV Camping
Kitchen
Living Room
Office
Garage
Laundry Room
RV Camping
4 Ways to Charge Up — Ready in Just 51 Mins
Remote charging control for added peace of mind.
Wall Charging
Wall Charging
Generator Charging
Generator Charging
Alternator Charging
Alternator Charging
Wall Charging
Generator Charging
Alternator Charging
500W Input, 0-80% in 3.43 hrs. Pair it with EcoFlow Solar Panels (25% high-efficiency) for reliable power during camping trips, van life, or off-grid living[6].
1800W Input, 0-80% in 51 mins[3]. EcoFlow’s exclusive Storm Guard Mode[4] monitors severe weather alerts and automatically triggers AC charging remotely using industry-leading X-Stream fast charging tech—so it can be ready long before a disaster hits.
With 2400W input, recharge to 80% in just 51 mins[1]. The EcoFlow Smart Generator 4000 (Dual Fuel) powers up DELTA 3 Max (2048Wh) for storms, outages, and off-grid living[5].
With the EcoFlow 800W Alternator Charger[7], get ready fast while on the move.
Built to Last
From battery chemistry to structural design, DELTA 3 Max (2048Wh) is engineered for extreme durability, environmental resilience, and whisper-quiet performance.
Smart, 24/7 Battery Protection
EV-Grade CTC Structure
Extreme Environment Resistance
Class B EMC Certification
25dB Whisper-Quiet Operation Under Loads [9]
EcoFlow’s advanced BMS uses a high-performance ARM Cortex chipset and intelligent algorithms to monitor your battery in real time. By tracking SOC, SOH, temperature, and more, it ensures peak performance, extended battery life, and worry-free operation.
Built with a cell-to-chassis (CTC) structure, DELTA 3 Max (2048Wh) is drop-resistant and shockproof—protecting against overnight condensation and off-road bumps during transport. You get stable power even in the most demanding conditions.
DELTA 3 Max (2048Wh) keeps your power flowing through freezing cold, scorching heat, humid environments (95% humidity tolerance), or coastal air—for reliable energy anytime, anywhere[8].
Certified to Class B EMC standards, it won’t interfere with TVs, Wi-Fi, or other home electronics.
Powered by X-Quiet™ 3.0, EcoFlow’s stepless fan control adjusts airflow smoothly to maintain precise thermal regulation—keeping your home or workspace peacefully quiet, even under heavy loads.
Power That Lasts All Day
With 2048Wh Capacity, EcoFlow DELTA 3 Max meets all your power needs in any scenario.
Home Backup
Home Backup
RVing & Outdoors
RVing & Outdoors
DIY Project
DIY Project
Home Backup
RVing & Outdoors
DIY Project
Compact, Portable, Lighter than Ever — Works Anywhere
Lightweight and easy to carry, DELTA 3 Max (2048Wh) fits into any setting—from home to the great outdoors. Weighing just 20.3 kg, it’s 13% lighter[10] for effortless portability while still packing serious power.
Monitor your energy usage and solar generation—all with one intuitive dashboard. Set timed charging/discharging missions so that you can charge during off-peak hours, discharge during peak rate periods to save costs.
Compatibility
*Compatibility note: Reverse charging and battery preservation modes rely on XT150 or 4+8 pin communication cables. DELTA 3 Max features an XT60 port only, making these functions unavailable.
What's In The Box?
1. 0-80% in 51 minutes was measured in optimal conditions using AC charging with X-Stream Fast Charging mode on.
2. Based on proper product usage, DELTA 3 Max (2048Wh) is estimated to have a lifespan of approximately 10 years, according to internal simulation test data. This information is for reference only; actual user experience may vary.
3. All charging speed data comes from EcoFlow Labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
4. Feature requires preset activation via the EcoFlow App.
5. EcoFlow Smart Generators are sold separately.
6. EcoFlow Solar Panels are sold separately.
7. EcoFlow 800W Alternator Charger is sold separately. The Alternator Charger XT60 Output Cable is required to connect the EcoFlow 800W Alternator Charger to the EcoFlow DELTA 3 Max. The cable is sold separately, but it is included when you purchase the DELTA 3 Max + 800W Alternator Charger bundle. When connected to a Alternator Charger, the DELTA 3 Max does not provide reverse charging to the vehicle’s battery.
8. Unless otherwise noted, all images, videos, and screen display contents about the product itself on this page are for reference only. Actual product effects (including but not limited to appearance, color, and size) and screen display contents (including but not limited to backgrounds, UI, and illustrations) may vary.
9. Noise levels measured at 1m under 25°C ambient: ≤25dB (600W) for charging/discharging.
10. Compared with EcoFlow DELTA 2 Max
20.3+0.4kg
Dimensions (HWD)
494mm×239mm×305mm
Rated Capacity
2048Wh
Cell Chemistry
LFP (LiFePO4)
230V~50Hz, 2400W Total, 10A Max per port(×4)
X-Boost
3200W
1×18W Max
1×100W Max
2×30W Max (Total30W)
Cigarette Lighter Output Port
12.6V, 10A, 126W Max
AC Input (Charge Only)
220-240V~10A 50/60Hz
Maximum PV Input Power(W)
500W
Charge Temperature
0°C-45°C (32°F-113°F)
Discharge Temperature
-10 to 45°C (14°F-113°F)
Operating Humidity
20%-95%
5-Year Warranty
Communication Method
Wifi 2.4GHz/ Bluetooth5.0
EMC
Class B
UPS
<10ms
Never miss a sale🎉
