EcoFlow DELTA Solar Generator (PV400W) | EcoFlow South Africa
EcoFlow DELTA 1300 Solar Generator (PV400W)
R 19,999.00 ZAR
Regular price R 19,999.00 ZAR
Sale price R 19,999.00 ZAR Regular price R 35,499.00
Save up to R 15,999
DELTA 1300 has been discontinued. Discover the next-generation DELTA 2 960 here>>
This portable power station is equipped with International standard plugs. Adapters will be needed to use the product.
EcoFlow DELTA Power Station represents the new standard of battery-powered generators. Compatible with a wide range of devices, you can stay powered for hours whenever and wherever.
The World’s Fastest Charging Power Station Charges at 2 to 3 times the speed of most portable power stations in the market. 0—80% in under one hour.
Power Almost Anything DELTA’s large inverter load can even support heavy-duty DIY tools up to 1800W (3300W Surge, Pure Sine Wave). That makes it the best portable power station at this size for output.
      Power 11 Devices At Once All the ports you’d ever need for your gear. Power up to 11 devices all at the same time via AC, DC or USB outlets. Ideal as a battery generator for blackouts.
      Fast Solar Panel Recharging The DELTA can be fully recharged from one EF 400W Solar Panels in 4-8 hours, depending on sunlight conditions. An MC4 to XT60 Solar Cable is included.
      Smart Solar Energy The EcoFlow 400W solar panel has a conversion efficiency of 22.4%, and when paired with an EcoFlow portable solar generator, can extract the most power throughout the day. The solar generator adjusts its efficiency using the Maximum Power Point Tracking (MPPT) algorithm, to deliver a constant power supply.
      Self-supporting The protective case conveniently turns into a stand that adjusts from 40-90° allowing the solar panels to capture the most rays.
      Size
      R 499 ZAR
      XT60 | XT60i
      EcoFlow Solar Parallel Connection Cable
      R 399 ZAR
      EcoFlow 50” Tilt Mount Bracket (2 Sets)
      R 3,998 ZAR
      For Angled Installations to Optimize Sun Exposure
      R 499 ZAR
      XT60 | XT60i
      R 19,999 ZAR R 35,499 -R 15,500
      Pay over 3 EQUAL zero-interest instalments of R 6,666.33 with PayJustNow.
      Find out how...
      Payment method
      Payment method
      Payment method
      Payment method
      Never miss a sale🎉
