DELTA Pro 3 Solar Generator (2×400W Rigid) | EcoFlow ZA – EcoFlow South Africa
EcoFlow DELTA Pro 3 Solar Generator (2×400W Rigid Solar Panels)
R 60,099.00 ZAR
Regular price R 60,099.00 ZAR
Sale price R 60,099.00 ZAR Regular price R 79,998.00
Save up to R 19,899
The DELTA Pro 3 (European Plug) features EU‑standard AC output sockets. Product images are for reference only; actual interfaces vary by version. Adapters are required for European Plug products.
  • Complete Solar Setup: Includes DELTA Pro 3 and two 400W Rigid Solar Panels for premium fixed backup.
  • Home & Business Backup: Suitable for homes, small businesses, workshops, and fixed backup points.
  • High-Capacity Power: 4kWh capacity and 4000W output can power larger appliances and demanding essentials.
  • Solar Recharge: Recharge DELTA Pro 3 in approx. 6.4 hours with two 400W rigid panels.
  • Fixed Solar Design: Rigid panels are better suited to longer-term placement and fixed solar setups.
  • Built for Outdoor Use: 23% conversion efficiency and IP68 protection support fixed outdoor installations.
Note: The Solar to XT60 Charging Cable is excluded and needs to be purchased separately. Mounting accessories are sold separately; each 400W rigid panel requires one mounting set.
Business Purchase? Save 7–15% with bulk orders. Learn More >
EcoFlow 50” Tilt Mount Bracket (2 Sets)
R 3,998 ZAR
For Angled Installations to Optimize Sun Exposure
R 3,998 ZAR
R 60,099 ZAR R 79,998 -R 19,899
Pay over 3 EQUAL zero-interest instalments of R 20,033.00 with PayJustNow.
Find out how...
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Choose the Product That Suits You Best
Energise Every Moment That Needs Electricity
For Home Use
For RV Use
For Off-grid Use
To help save electricity bills
Frequent load shedding in South Africa disrupts daily life and business operations. The EcoFlow DELTA Pro 3 provides a reliable, modular power solution designed to keep essential devices running during outages.
Most RVs rely on lead-acid batteries paired with noisy gas generators or limited solar setups. These systems often suffer from slow charging, short battery life, and inconsistent power delivery. The EcoFlow DELTA Pro 3 offers a smarter alternative—its modular lithium-based design delivers fast charging, higher efficiency, and long-lasting power. Whether you are upgrading an older RV or building a new off-grid setup, the EcoFlow DELTA Pro 3 provides seamless compatibility, clean energy, and true flexibility for life on the road.
For true off-grid living, power capacity and output are critical—and the EcoFlow DELTA Pro 3 delivers on both fronts. With support for up to 4 kWh of base battery capacity, the DELTA Pro 3 is ideal for powering everything from essentials to heavy-duty appliances.
With an 8 kWh daily solar input, the EcoFlow DELTA Pro 3 can power common household appliances like a fridge (100 W), TV (100 W), Wi-Fi router (10 W), laptop (75 W), and even a washing machine (averaging 800 W) simultaneously for about 7 hours. This capacity allows families to run essential devices off-grid without relying on expensive electricity from the grid or noisy generators. Thanks to its large battery and efficient solar charging, the DELTA Pro 3 offers a cost-effective, clean, and quiet energy solution—helping users significantly reduce electricity bills while maintaining comfort and convenience at home, especially in areas with unstable power supply or high energy costs.
Keep Your Home Running Smoothly
Ensure essential appliances keep working
4000W High Output
A comprehensive 10 ms UPS
A single DELTA Pro 3 unit has a 4kWh battery capacity, easily meeting the electricity needs of a household, providing peace of mind even in emergencies. Additionally, the capacity can be expanded to 12kWh*, allowing you to use the stored power in the DELTA Pro 3** even during several hours of a power outage.
Multiple high-power household appliances can be used simultaneously. EcoFlow's unique X-Fusion technology allows the DELTA Pro 3 to output 4000W, even when the input is AC230V 2900W. The more stable pure sine wave output ensures an enjoyable experience when using household appliances.
Ensures swift 10ms switch-overs, protecting your NAS systems, servers, and entertainment devices from power disruptions, keeping your technology safe and continuously powered.
State-of-the-art LFP Tech
Powered by ground-breaking X-Guard BMS
Revolutionizing Durable Construction
5 Years Warranty, Zero Worries
Crafted with automotive-grade LFP cells, the EcoFlow DELTA Pro 3 features the industry's first IP65-rated battery pack, resisting impacts, water, dust, and fire. With 4000 cycles to 80%, enjoy 11 years* of daily power. Dependable in any weather, ensuring peace of mind.
*Tested under controlled laboratory conditions with charging and discharging at 0.5C rate under 77°F conditions
X-Guard BMS monitors 40 safety indicators 24/7, app-managed for smart, secure energy.
CTC design, UL-certified 5VA fireproof shell fortify DELTA Pro 3, setting new standards for resilience.
5-year warranty, streamlined support for swift solutions, minimal downtime. Quality redefined.
Charge Up, Fast, and Everywhere
Introducing EcoFlow's groundbreaking X-Stream fast charging technology, setting a new industry standard. Charge from 0 to 80% in just 1 hr. With multi-charge combinations, enjoy up to 7000W of super-fast charging.
Effortless All-in-One Command with the EcoFlow App
Effortless Portability and Space-Efficient
Portable design for an ideal lifestyle. Boosts portability with its wide wheels, ergonomic handle, and compact design. Its magnetic sliding doors simplify access, optimising space and power for mobility without compromise. Ideal for dynamic lifestyles and maximising family space.
Multiple Using Scenario
Equipped with a portable home battery, ensuring peace of mind in emergencies.
Equipped with a TT30 port to power RVs.
Achieve off-grid capability with solar panels and the DELTA Pro 3.
With powerful output and expandable capacity, it's ideal for various high-power appliances.
6 unique and 18 combo charging methods to meet your charging needs anywhere, anytime.
Indoor: Dual-PV Charging
Indoor: AC Wall Charging
Backyard: With Gas
Generator
Outdoor: EV Charging
Piles
RV/Van: EcoFlow
Alternator Charger
Car: Cigarette Lighter
Charging
Fast Multi-Charging
Solutions
Quiet Comfort for Your Home and Neighbors, Too!
It's whisper-quiet with X-Quiet technology, ensuring a peaceful hum*, promising you a night of peaceful sleep even if you keep it beside your bed. It's so silent that you'll hardly notice it's there.
*as low as 30 dB, thanks to our X-Quiet tech
Compatiblity
What's In The Box?
EcoFlow DELTA Pro 3 has two PV input ports, which are for high-voltage PV port and low-voltage PV, respectively.High-voltage PV: 30-150V, 15A Max, 1600W Max. Low-voltage PV: 11-60V, 20A Max, 1000W Max.
Will EcoFlow DELTA Pro 3 automatically turn on if connected to solar panels while it is turned off?
Yes, it will.However, there are specific requirements for the light conditions. In weak lighting environments, it might not trigger the device to power on.
  1. EcoFlow 800W Alternator Charger
  2. EcoFlow Smart Generator (Dual Fuel)
  3. EcoFlow DELTA Pro to Smart Generator Adapter
  4. EcoFlow WAVE 2
Which EcoFlow products are compatible with EcoFlow DELTA Pro 3? (EcoFlow DELTA Pro series)
  1. EcoFlow DELTA Pro Smart Extra Battery
  2. EcoFlow DELTA Pro Remote Control
How long is the cycle life of the battery in EcoFlow DELTA Pro 3?
4000 cycles.After undergoing 4000 cycles at a rate of 0.5C/0.5C at 25°C (77°F), the battery maintains over 80% of its state of health (SoH).
Optimal operating temperature: 20°C-30°CCharging temperature range: 0℃-45℃Discharge temperature range: –10℃-45℃Recommended long-term storage temperature: 20℃-30℃
As the core component of the device, the safety and protection level of the battery pack is crucial. To better protect the battery pack and reduce the risk of short circuits and fires caused by water ingress, the EcoFlow DELTA Pro 3 battery pack is sealed. It has reached an IP65 waterproof and dustproof rating, effectively preventing dust from entering and resisting water spray.However, the EcoFlow DELTA Pro 3 main unit does not have a waterproof and dustproof rating (IP20). The device is suitable for use in well-ventilated indoor environments or sheltered outdoor environments to avoid the impact of rain and dust on the device. Please ensure that the surrounding environment is dry and clean during installation and use to ensure the device's normal operation and longevity.
EcoFlow DELTA Pro 3 is equipped with an internal GFCI ground circuit. Users can connect an external GFCI protector according to their needs. When an external GFCI protector is connected to EcoFlow DELTA Pro 3, the GFCI support switch must be turned on in the app for the external GFCI protector to function properly.
Never miss a sale🎉
