EcoFlow NextGen 220W Monofacial Portable Solar Panel
Generate even more energy
With the portable solar panel industry's first use of TOPCon solar technology, we've raised the bar on conversion efficiency, reaching 25%. Charge faster with a more compact panel.
Capture more solar with an adjustable angle
With a newly integrated solar angle guide and stand, adjust the angle of the panel by 30 degrees in seconds to get the most sunshine at all times.
Integrated solar angle guide
Keeps sunlight at a 90° angle on the surface of your solar panel to capture the most energy possible.
Durable and waterproof
                            Built to weather the storm
With an IP68 waterproof rating, our NextGen 220W Solar Panel maintains its high performance even in extreme weather conditions, including rainfall. It's dust-resistant, too.
                            Never too hot
Designed to withstand high temperatures while still ensuring high levels of solar generation.
monocrystalline silicon
What’s in the box
     XT60i Charging Cable
     Protective Bag
     Quick Start Guide, Safety Instructions & Warranty Card
Rated Power
220W (±5W)
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25.00%
Weight (Solar Panel)
Approx. 15.9 lb (7.2 kg)
Unfolded: 23.6×83.6×1.0 in./600×2123×25 mm
Folded: 23.6×22.5×1.3 in./600 x 571×32 mm
Connector Type
Photovoltaic connectors
Warranty (US)
12 months
Open Circuit Voltage
21.5V (Vmp 18.4V)
Short Circuit Current
12.4A (Imp 11.9A)
Waterproof & Dustproof
