EcoFlow RIVER 3 Solar Generator
R 8,399.00 ZAR
Regular price R 8,399.00 ZAR
Sale price R 8,399.00 ZAR Regular price R 8,999.00
Save up to R 600
  • Complete Solar Setup: Pair RIVER 3 with a 45W or 110W solar panel.
  • Camping & Outdoor Power: Keep phones, lights, laptops, and small essentials powered during day trips.
  • Compact Power Storage: 245Wh capacity and 300W output suit small everyday devices.
  • Solar Recharge: Recharge RIVER 3 in approx. 2.6 hours with the included 110W panel.
  • Easy Solar Setup: The lightweight panel features a built-in 2.5m XT60 cable and a 30–60° adjustable stand for simple setup.
  • Built for Outdoors: IP68-rated solar panel protection helps guard against water and dust.
Note: Extension cables and parallel/series connection accessories for lightweight solar panels will be available later in 2026.
Product
EcoFlow RIVER Series Bag
R 999 ZAR
R 8,399 ZAR R 8,999 -R 600
Pay over 3 EQUAL zero-interest instalments of R 2,799.66 with PayJustNow.
Find out how...
An ideal starter battery that is compact yet delivers powerful performance
Compact design with powerful performance
Easily extend your outdoor stays and handle power outages with GaN
With groundbreaking X-GaNPower, RIVER 3 taps into superior energy efficiency to extend the operating time of low-wattage devices witha compact design and quieter running volume.
30% more compact for on-the-go use
RIVER 3 minimises heat loss, requires less cooling space, and supports a compact design. It easily fits into small spaces like closets, or a bag for easy storage and portability.
Up to 2x light and network runtime
RIVER 3 revolutionises energy efficiency, delivering double runtime for appliances under 100W, extending use at home and in the great outdoors.¹
< 30 dB whisper quiet for 24/7 backup
With X-GaNPower’s enhanced heat dissipation, RIVER 3 operates on a library-like quiet level, with a volume of less than 30 dB at a distance of 0.5 m.² You'll have peace day and night guaranteed, even when it's running nonstop.
AC charging
Solar charging
Car charging
Generator charging
RIVER 3 fast-charges in 1 hour with X-Stream, without causing battery damage due to vehicle-grade cells and trickle charge technology.
Power up RIVER 3 in as fast as 2.6 hours with 110W solar input. Go even more portable with our 45W Portable Solar Panel (Type-C), which folds to the size of a laptop and charges electronics directly.
Charge RIVER 3 using your car battery while you drive, making it an ideal choice for on-the-go.
Recharge RIVER 3 in just 1 hour with a gas generator for a full day of quiet, safe, and efficient power.
Extremely durable for worry-free outdoor use
With IP54 battery protection, water damage is minimised.³ Its robust fire-retardant shell survives rough conditions. Even after a 1 m fall, RIVER 3 won't get damaged.
RIVER 3 has a lifespan of 3000 charging cycles. That's around 10 years of everyday use before its capacity drops to 80%.
Featuring an advanced algorithm for cloud-based battery monitoring with 40+ safety measures, RIVER 3 protects against various current, voltage, temperature, and circuit risks.
Power up to 600W appliances
Your reliable companion in the wild or during an outage
RIVER 3 keeps 90% of your must-have appliances running smoothly with 300W of power. With X-Boost technology, it can power 600W heating devices without breaking a sweat.
<20 ms UPS solution for uninterrupted daily living
When a power outage occurs, your AC outlet will switch to the RIVER 3 supply in a barely noticeable 20 ms. It keeps vital home appliances running, maintaining food storage, security, and communication. Experience a seamless, automatic switchover for continuous peace of mind
Upgraded smart control
Convenient, intelligent, customized power control
Product Details
245Wh
255 x 212 x 113 mm
3.55 kg
UPS
<20 ms
Noise
<30 dB
1 outlets, 300W total (Surge 600W, X-Boost 600W)
2 ports, 5V=2.4A, 12W max per port, total 24W
1 port, 5/9/12/15⎓3A max, 20V⎓5A Max,100W max per port
Car Output
AC Input
200~240V, 3A, 50/60Hz, 305W, 0-100% in 60 min
Solar Input
11~30V, 8A, 110W, 0-100% in as fast as 2.6 hr
Car Input
11~30V, 8A, 100W, 0-100% in 2.8 hr
Generator Input
200~240V, 3A, 50/60Hz, 300W, 0-100% in 60 min
Optimal Operating Temperature
20℃-30℃ (68°F-86°F)
Charge Temperature
0℃-45℃ (32°F-113°F)
Discharge Temperature
-10℃-45℃ (14°F-113°F)
Storage Temperature
20℃-30℃ (68°F-86°F)
Footnote:
The RIVER 3 Series revolutionizes energy efficiency, delivering up to double runtime for light-wattage appliances, extending use at home and in the great outdoors. Data was tested in a controlled laboratory environment and actual user experience may vary.
1. The "double runtime" claim specifically refers to tests using a 3W light or Wi-Fi router.
3. The IP54 water-proof rating applies only to the battery pack, not the entire package. It does not prevent water immersion but can prevent fire or explosion in the event of a short circuit if the battery is splashed with water or rain, ensuring user safety and property protection
Never miss a sale🎉
