EcoFlow RIVER Pro Solar Generator (PV60W) | EcoFlow South Africa
R 7,299.00 ZAR
Regular price R 7,299.00 ZAR
Sale price R 7,299.00 ZAR Regular price R 9,498.00
Save up to R 2,199
This portable power station is equipped with South African standard plugs.
VERSATILE & LIGHT It's portable electricity for your essential devices; nine at a time if you want. Draw 720Wh through RIVER Pro’s wall outlets, USB outlets, and DC outlets, and at just 7.6 kg, it’s one of the best portable power supply alternatives for camping, off-grid living, and professional work.
WORLD’S FASTEST RECHARGE Our patented X-Stream feature takes RIVER Pro’s battery from 0–80% within one hour and fully charged in just 1.6 hours.
OPT FOR DOUBLE CAPACITY Add a RIVER Pro Extra Battery to double the capacity to 1440Wh. This makes it a great backup power supply for refrigerators or as part of an off-grid power system.
HIGHER OUTPUT With X-Boost enabled, RIVER Pro’s 600W output can power some devices up to 1800W. That’s enough for 80% of devices, tools, and appliances, though it works mostly as a safety net.
UPGRADE HIGH EFFICIENCY Compared with other solar panels, the chainable feature enables you to chain solar panels together with the parallel cable which gives you ample power for your power station
    PORTABLE & FOLDABLE KICKSTAND PANEL Designed with a rubber handle and flexible bracket stand, our solar panel can be used to adjust the angle from 0-45 degrees.
      WATERPROOF & DURABLE The solar panel is waterproof to endure all weather conditions, ideal for outdoor activities.
      Product
      EcoFlow Solar Parallel Connection Cable
      R 399 ZAR
      EcoFlow Solar Extension Cable
      R 399 ZAR
      EcoFlow RIVER Bag
      R 1,099 ZAR
      R 399 ZAR
      R 399 ZAR
      EcoFlow RIVER Bag
      R 1,099 ZAR
      R 7,299 ZAR R 9,498 -R 2,199
      Pay over 3 EQUAL zero-interest instalments of R 2,433.00 with PayJustNow.
      Find out how...
      Payment method
      Payment method
      Payment method
      Payment method
      Payment method
      Payment method
      Payment method
      Payment method
      Payment method
      Payment method
      Ideal solar power source for RIVER Series
      With its compact design and lightweight, a 60W portable solar panel is the ideal
      companion for RIVER Series power stations, providing a simple and convenient charging experience.
      Up to 25% conversion rate
      Charge faster with an even smaller panel.
      With the introduction of TOPCon solar technology, a first in the mini portable solar panel industry,we've set a new standard for conversion efficiency, achieving 25%. This enables faster charging in a more compact form. Fully charge RIVER 2 in X hours during peak sunlight hours, and power your electronics and essential camping appliances for a longer adventure.
      More benefits of adopting TOPCon
      EcoFlow 60W Solar Panel with TOPCon vs traditional solar panel with PERC material
      Extremely compact
      Easily fit into any compact space,
      With its folding four-panel structure, the portable solar paneI significantly reduces in size when folded, allowing it to easily fit into compact spaces such as backpacks, SUVs, or minivans.
      Built to last
      Always be ready for unexpected weather
      Featuring robust PCB fiberglass and a durable ETFE coating, our panels are designed to withstand challenging weather conditions. Whether it's a sudden impact, beling pulled by the wind, or evenexposure to salty ocean spray and water droplets, they remain undamaged and strong, serving as your reliable outdoor companion.*
      Designed for hanging
      Charging on the go
      In addition to being laid flat on the ground or tilted using a stand, the 45W portable solar panel can be hung using the four pre-cut eyelets and hooks included. Whether hung on your car or backpack,save time by charging while you're heading to your next destination.
      Product Details
      Rated Power
      60W
      Cell Type
      N Type TOPCon monocrystalline silicon
      Efficiency
      25%
      Open Circuit Voltage
      25.6V
      Short Circuit Current
      3.1A
      Weight (Solar Panel)
      2.0 kg
      Unfolded Dimensions
      1356x309x25mm
      folded Dimensions
      317x309x45 mm
      Waterproof Certification
      Never miss a sale🎉
