EcoFlow WAVE Portable Air Conditioner with Add-On Battery
R 23,999.00 ZAR
The fastest cooling.
The longest running time.
Sustainable charging.
Smart controls & customization.
Wave Portable Air Conditioner Specs
Net weight
17.5 kg
51.8 x 30.98 x 41.61 cm
Wi-Fi
Supported
Bluetooth
Supported
AC input voltage/frequency
115V 60Hz
AC input power
Max 700W
Add-On Battery power
Max 600W
Solar charging input
11-35V Max 12A Max 200W
Car charging input
12 V/24V Max 8A Max 200W
Ambient temperature
5°C ~ 50°C (41°F ~ 122°F)
Cooling temperature settings
16°C ~ 30°C (60.8°F ~ 86°F)
Cooling capacity
1200W
Circulation air volume
290m"3"/h
Refrigerant/amount
R134a/14.1oz
Rated cooling power (AC/DC)
460W/410W
Max. cooling power
600W
Noise
<55dB
No-Drain Function
Supported
Shut Down When Full Function
Supported
Wave Add-on Battery Specs
Net weight
7.9 kg
1008Wh
Terms & Conditions
1. The Pre-order campaign starts from May 12th to June 13th, 2022, PST.
2. The Pre-order campaign only applies in Canada and the United States.
3. There are three prices for each bundle (Super-early bird, early bird, and pre-order). Each price is subject to a quantity limit. Therefore, a price match guarantee is not provided.
4. The shipment of DELTA Pro/DELTA Max(2000) will be scheduled once they are in stock.
The shipment of AC/AC extra battery/accessories will be scheduled in late June.
5. If you have any questions, please contact our Aftersales Service team at support@ecoflow.com
6. AC/AC extra battery/accessories come with a 12-month limited warranty counting from when you receive the physical goods. For more details about the warranty, please check the EcoFlow Warranty Policy Page.
7. After pre-ordering, you can request a full refund as long as the item has not been shipped. If you return your order within 30 days of receiving purchased items without any reason, we'll charge the initial transaction fee and shipping cost. To learn more about our Return & Refund Policy, please check here.
*Note: EcoCredits are redeemable for gifts and discounts
Your preferences are saved.
We’ll personalize your experience from here.
