R 10,999.00 ZAR
Video
Regular price R 10,999.00 ZAR
Sale price R 10,999.00 ZAR Regular price R 23,999.00
Save up to R 13,000
Note: This is an extra battery and cannot be used independently. Must be connected to a compatible DELTA 2 Max, DELTA 2, DELTA 3, or DELTA 3 Plus,
· Expandable capacity - Increase the capacity of DELTA 2, DELTA Max(2000) and DELTA 2 Max with an extra 2048Wh.
· Triple power at up to 30% lower cost - 2-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to gain a capacity of 6144Wh. And it's up to 30% more affordable than a power station of the same capacity.
· 10-year lifespan with an LFP battery - Get 10 years of daily use until it hits 80% of its original capacity. Embrace the 3000+ charging cycles enabled by the LFP battery chemistry.
· Easy to use - Plug-and-play without setup. And use the EcoFlow app to monitor and control the DELTA 2 Max Smart Extra Battery.
· 5-Year Full Warranty - With one of the most comprehensive warranties in the industry, we go the extra mile to give you peace of mind.
Style
R 10,999 ZAR R 23,999 -R 13,000
Pay over 3 EQUAL zero-interest instalments of R 3,666.33 with PayJustNow.
Find out how...
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
With its upgraded LFP battery chemistry, the DELTA 2 Max Smart Extra Battery has a lifespan of 3000 complete cycles until it reduces to 80% capacity. You'll get pretty much 10 years of power, even if you use it every day. That's 6× longer than other power stations with a similar capacity and output.
Expandable up to 6kWh
Triple the power
Easy to use
There's no setup. Just plug it into your power station for more energy storage. Using the EcoFlow app, you can charge and monitor the DELTA 2 Max Smart Extra Battery with ease.
Stackable, space-saving design
Featuring an ergonomic, compact design, the DELTA 2 Max Smart Extra Batteries can be securely stacked on top of power stations and each other to save space and minimize clutter.
DELTA 2 Max Smart Extra Battery Specs
2048Wh
Input Port
51.2V, 2000W Max
Output Port
51.2V, 3200W Max
Battery
LFP chemistry, 3000 cycles to >80% capacity
Dimension
464 × 235 × 283 mm (18 × 9 × 11 in)
Weight
19kg (42lbs)
What’s in the box
Extra Battery Cable
User Manual Warranty Card
Compatible with
DELTA 2 / DELTA Max 2000/ DELTA 2 Max
Never miss a sale🎉
