DELTA 2 Max Solar Generator (PV400W) | EcoFlow ZA – EcoFlow South Africa
EcoFlow DELTA 2 Max Solar Generator (PV400W)
R 30,799.00 ZAR
Regular price R 30,799.00 ZAR
Sale price R 30,799.00 ZAR Regular price R 36,998.00
Save up to R 6,899
Adapters are required for products marked with European Plug. A R500 coupon is provided below to help cover the cost of adapters.
 • Expandable capacity: 2-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit a capacity of 6144Wh. Ideal for home backup, RVing, outdoors or even everyday use.
• Built to last 6× longer: Get 10 years of daily use until hitting 80% of its original capacity. That's down to its LFP battery chemistry giving you 3000+ cycles.
• Huge AC output: With X-Boost mode, get up to 3400W output power to run 99% of home appliances. Power 15 devices at once, including 6 AC outlets.
• Fastest recharging: World's fastest AC recharging and X-Stream dual AC+Solar charging speeds. Up to 1000W solar input to charge in as fast as 2.3 hours.
• Capture more energy: 99% MPPT efficiency maximizes solar generation during the daytime.
• High conversion efficiency rating - guarantees a faster solar charging speed. 0-100% in 2.8 hours (2 sets) or 0-100 in 5.4 hours (1 set).
• Customized in-app energy management: Prioritize solar or AC charging, view input and output power, battery levels and more.
• 5-Year warranty: 5 years for DELTA 2 Max, 12 months for 400W Portable Solar Panel.
Plug Type
Size
EcoFlow Solar Extension Cable
R 399 ZAR
EcoFlow Solar Parallel Connection Cable
R 399 ZAR
R 499 ZAR
XT60 | XT60i
R 499 ZAR
XT60 | XT60i
R 399 ZAR
R 399 ZAR
R 399 ZAR
R 399 ZAR
R 499 ZAR
XT60 | XT60i
R 30,799 ZAR R 36,998 -R 6,199
Pay over 3 EQUAL zero-interest instalments of R 10,266.33 with PayJustNow.
Find out how...
Payment method
Payment method
Payment method
Payment method
Your Power Ally for Whole Home ComfortEcoFlow DELTA 2 Max
Durable, Safe, Lightweight
LFP Battery Chemistry
Advanced BMS Protection
Robust Design
Upgraded Tech, Lighter Weight
DELTA Max powers almost all the devices you need with a large 2400W AC output. With X-Boost proprietary technology, run appliances with an output of up to 3100W. Compared with similar portable power stations, DELTA 2 Max can power more devices while also preventing overloading and overheating.
Works in Sync with EcoFlow PowerStream Balcony Solar System
Transform your power station into a grid-tied solar energy solution that combines solar panels, a power station, and a microinverter. Power your home and save on energy bills day and night.
Power for the entire family
2048Wh Capacity
Home Backup
RVing & Outdoors
DIY Projects
Filmmaking & Photography
Expandable up to 6kWh
Triple the power
Fuel Up 80% in Only 43 Mins*
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 1.1 hours.
Up to 1000W Solar Input
Solar Charging Times
880W Charge approx. 2.6 hours
800W Charge approx. 2.8 hours
Take control of your power
Smart Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
Save more on electricity bills. Customize the working time of DELTA 2 Max to avoid peak rates.
Experience peace of mind during power outages. With our all-new AC Always On Mode, the AC power button stays on, even during a power outage or after the grid power is back, keeping your appliances powered no matter what.
Easily adjust AC or Solar input to fit your needs: backup power reserve or energy savings.Prioritize solar energy input via the EcoFlow app when using X-Stream AC + solar dual charging.
As Quiet as 30 dB
Peaceful charging
DELTA 2 Series
Learn More About DELTA 2
DELTA 2 Max
DELTA 2 Max
AC Charging Cable
AC Charging Cable
User manual & warranty card
2048Wh
Extra Battery
6 outlets, 2400W total (Surge 4800W)
X-Boost 3100W
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
AC Charging
X-Stream Fast Charge 2300W, 10A
AC Input Voltage
Car Charging
Support 12V/24V battery, 8A
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Net weight (lbs)
50 lbs
Net weight (kg)
23 kg
Never miss a sale🎉
