Portable Power Station EcoFlow DELTA Pro Smart Generator | EcoFlow ZA – EcoFlow South Africa
EcoFlow DELTA Pro + Smart Generator
R 49,999.00 ZAR
Regular price R 49,999.00 ZAR
Sale price R 49,999.00 ZAR Regular price R 75,998.00
Save R 25,999
This plug is equipped with European standard plugs. Adapters will be needed to use the product.
Please NOTESmart Generator requires DELTA Pro to Smart Generator Adapter to work with DELTA Pro.
The portable home battery DELTA Pro sports a 3.6kWh capacity that can be expanded all the way to 25kWh. You can integrate it directly with your home circuits via the Smart Home Panel. Ideal for home backup.
Power pretty much anything DELTA Pro leads the industry when it comes to AC output. With 3600W you can power heavy-duty appliances such as dryers, AC units and more. Need even more power? Pair two units together to hit a massive 7200W with Smart Home Panel.
An expandable ecosystem DELTA Pro is more than a portable power station. It can be expanded with extra batteries, Smart Generators and even the Smart Home Panel. Control it all via DELTA Pro Remote Control or your phone with the EcoFlow app.
The world’s fastest charging portable power station DELTA Pro can charge via one of 6 methods. It is the first that can be charged from an EV station, and can even Multicharge by combining methods to achieve a rapid 6500W charge. That’s the industry gold standard.
Integrates with DELTA Pro/Max Link with your DELTA Pro or Max to charge up during extended blackouts.
Efficiency First Compared to traditional gas generators, the EcoFlow Smart Generator charges directly with DC, saving you fuel and charge time.
Charge & Power Features an AC output so you can power devices during emergencies while your power station charges up.
Smart, Really Smart Auto-start at your set charge level. Control & monitor via the app. Auto shutdown. That’s smart.
EcoFlow DELTA Pro to Smart Generator Adapter
R 1,999 ZAR
EcoFlow Infinity Cable
R 1,099 ZAR
R 49,999 ZAR R 75,998 -R 25,999
Pay over 3 EQUAL zero-interest instalments of R 16,666.33 with PayJustNow.
Find out how...
Payment method
Payment method
Payment method
Payment method
When disasters strike, such as extended blackouts and severe storms, everyone needs a last-standing power supply to stay safe. The EcoFlow Smart Generator serves as an emergency option that integrates with your DELTA Pro or DELTA Max.
Emergency Backup
App control
More efficient
LCD display
Built for any emergency.
Compared to a traditional gas generator, the EcoFlow Smart Generator offers better fuel efficiency and less energy loss when you charge DELTA Pro or DELTA Max. It achieves this by directly charging your portable power station through a simple and efficient DC charging process.
Charge and power devices at the same time.
In emergencies, sometimes things don't go to plan. Not only does the EcoFlow Smart Generator give you last-standing emergency power, it also features an AC output to power other devices while recharging your unit with an extra battery.
Four easy ways to start.
Stay powered on at any time, using four easy ways to start the EcoFlow Smart Generator. If you're close to the unit, you can turn it on via electric or manual start. In emergencies, when you can't go outdoors, you can turn the smart generator on with the EcoFlow app. And for an added layer of power security and efficiency, the smart generator automatically turns on and off when your unit reaches a designated battery limit.
Control and monitor with the EcoFlow app.
The EcoFlow app gives you complete control over the EcoFlow Smart Generator at the touch of a button. You can control, monitor, and access your smart generator settings, such as choosing when it autostarts during an emergency.
Smart emergency power.
The EcoFlow Smart Generator simplifies emergency power, featuring an LCD screen, CO alert, fuel alert, and an auto shutdown – giving you everything you need to stay safe during a power outage or emergency.
1.Smart Generator 2.Extra Battery Connection Cable 3.Oil Funnel 4.Screwdriver 5.Spark Plug Socket 6.Breaker Bar 7.Double-Ended Spanner 8.User Manual and Warranty Card
The EcoFlow Smart Generator is smarter than traditional generators. It works with the EcoFlow app so that you can control & monitor from afar. It features an LCD screen for when you're nearby & you can even pre-define an auto-start when your power station depletes to a certain level.
The Smart Generator charges your power station directly with DC, unlike other generators. This leads to an approx. 10% increased efficiency, saving you time and money.
While we designed the Smart Generator as a compliment to DELTA Pro or DELTA Max, it also works as a traditional gas generator for when you need it to work alone.
To tide you over during extended blackouts, you can charge up your DELTA Pro or Max using the Smart Generator. In this case, one full tank adds 5.4kWh to your ecosystem.
Generator specs
Dimension
59.7*29.6*47.5cm / 23.5*11.7*18.7 in
Weight
29.3 kg / 64.6 lbs
Type
Inverter generator
Frequency
50Hz
Rated Power
1800W (1900W peak)
DC Output Voltage
42-58.8V
DC Current
32A Max
Engine specs
Model
R80-i
Type
Single cylinder, four-stroke, forced-air cooling, overhead value
Displacement
79.7cc
Fuel type
Unleaded fuel
Fuel Tank Capacity
4 L / 1.06 gal.
Engine Oil Capacity
0.38 L / 0.1 gal.
Noise Level (at a 7m distance)
56~67dB (full load)
Continuous Working Time
3.5 hrs (full load)
Online 24 hours
Never miss a sale🎉
