Get off the grid with EcoFlow's 110W Solar Panel for renewable energy wherever you end up.
Universal
Seamless
Foldable
Portable
Powerfully portable
With an industry-leading 23% conversion rate, it's far lighter and approx. 10% smaller than similar portable solar panels on the market. That means a faster, easier charge wherever you are.
Self-supportable
Take it camping, on a road trip or in your backyard with a case that doubles as a stand. Unzip and prop up your panel at just the right angle to ensure maximum solar coverage.
Waterproof & Durable
Designed to withstand your adventurous lifestyle, this panel is IP68 certified. That means we dunked it underwater for 72hrs in lab conditions. Just to make sure*. Built with a high-strength composite, it can take a beating too. That's an all-weather ready panel designed to stand the test of time.
* Water and dust resistance were tested under controlled laboratory conditions with a rating of IP68 under IEC standard 60529 (maximum water depth of 1 meter for up to 72 hours.)
It comes with a carry case too.
On the go? Keep your panel folded up and protected while you hit the road. Save valuable trunk space and go easy knowing your panel is safe. Once you arrive, simply unfold, prop up and start generating clean, green electricity.
1.110W Solar Panel 2.110W Solar Panel Bag 3. Solar to XT60 Charging Cable 4. User Manual
Unfolded Dimensions
178.5 × 42.0 × 2.5 cm
Folded Dimensions
42.0 × 48.0 × 2.5 cm
Weight
6 kg (Solar Panel 4 kg)
12 months
Rated Power
110W (±5W)
Efficiency
22%–23%
Open Circuit Voltage
21.8V (Vmp 18.4V)
Short Circuit Current
6.5A (Imp 6.0A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−20°C to 85°C
- Choosing a selection results in a full page refresh.
- Press the space key then arrow keys to make a selection.
Subscribe to our emails and receive an R500 discount on your first order over R5,000.
Your R500 voucher is waiting in your inbox. Spend R5,000 and save R500!
Sign Up For EcoFlow text updates and offers
Thank you for signing up for our text messages!
*Note: EcoCredits can be redeemed for discounts and gifts. Learn More
