EcoFlow DELTA 2 960 Portable Power Station | EcoFlow South Africa
EcoFlow DELTA 2 960 Portable Power Station(Corporate Purchase)
R 15,499.00 ZAR
Video
Regular price R 15,499.00 ZAR
Sale price R 15,499.00 ZAR Regular price R 16,999.00
Save up to R 5,599
This portable power station is equipped with South African standard plugs.
Level up with the EcoFlow PowerStream Balcony Solar System:
Pair with an EcoFlow PowerStream Microinverter and gain a grid-tied solar energy solution that powers your home day and night.
• 1-3 kWh Expandable capacity
• Huge AC output
• 7x Faster AC charging
• Built to last 6x longer
• Control from anywhere
• 5-Year warranty
Accessories
EcoFlow DELTA 2 Bag
R 999 ZAR
R 399 ZAR
XT60 | XT60i
R 15,499 ZAR R 16,999 -R 1,500
Pay over 3 EQUAL zero-interest instalments of R 5,166.33 with PayJustNow.
Find out how...
Payment method
Payment method
Payment method
Payment method
A transfer switch is a device that switches a load between Grid Power and Backup Power, simply connect EcoFlow Portable Power Station to your main panel via a Transfer Switch for instant home backup (Transfer Time 1~2s).
*Picture for reference only, subject to our available products.
*AC Plug Cable is needed to connect Power Station with Transfer Switch, and be provided by the electrician.
Learn more about how to backup your home with our Portable Power Station and Transfer Switch: Whole-Home Backup Kit User Guide
EcoFlow DELTA 2 960 is a must-have for any home that puts power security & comfort first. Ensure you're prepared with the power station made for almost any situation your family could find themselves in. All while staying green.
With a capacity of 1kWh to start with, you've got enough energy for your essentials for hours on end. Add on the DELTA 2 960 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
Use an extra battery to expand capacity. Great for extended power outages, long camping trips,
or your RV.
Power pretty much anything.
A 1800W AC output means you can power more than 90% of your home appliances. That's your microwave, fridge, or even coffee maker covered in a blackout. Or, try plugging in up to 13 devices at once for when you're around the table with the family. Unlike other brands, DELTA 2 960 can prevent overloading from devices up to 2400W thanks to X-Boost technology.
Want to know how long DELTA 2 960 can support your use?
Add up the wattage of the electrical appliances you supply at the same time.
(Click here to view the wattage of common-used appliances.)
W
Estimated comprehensive runtime
Appliances
Estimated Watts
EcoFlow DELTA 2
Wi-Fi router
10W (AC)
58 hrs
Phone
11Wh (Type-C)
89 times
Fan
40W (AC)
17 hrs
50" TV
110W (AC)
7.9 hrs
Refrigerator
120W (AC)
7-14hrs
Laptop
60Wh (Type-C)
16 times
PS5
200W (AC)
4.6 hrs
PC
500W (AC)
1.8 hrs
Coffee maker
1000W (AC)
0.8 hrs
Camera
16Wh (USB)
60 times
Light
10W (AC)
58 hrs
Light
10W (DC)
98 hrs
Washer
500W (AC)
1.8 hrs
Blender
500W (AC)
1.8 hrs
Drone
40Wh (Type-C)
25 times
Speaker
10W (AC)
58 hrs
CPAP
40W (AC)
17 hrs
Electric blanket
50W (AC)
14 hrs
Mini/Car fridge
60W (DC)
16-32hrs
Projector
65W (AC)
12 hrs
Electric blanket
120W (AC)
7 hrs
Baby food maker
300W (AC)
3 hrs
Pressure cooker
900W (AC)
1 hour
Rice cooker
1000W (AC)
0.8 hrs
Electric drill
1080W (AC)
0.7 hrs
Cutting machine
1100W (AC)
0.7 hrs
Electric grill
1150W (AC)
0.7 hrs
Electric frying pan
1200W (AC)
0.7 hrs
Electric hammer
1260W (AC)
0.6 hrs
Microwave
1300W (AC)
0.6 hrs
Circular Saw
1400W (AC)
0.6 hrs
Air fryer
1500W (AC)
0.5 hrs
Electric kettle
1500W (AC)
0.5 hrs
Hair dryer
1600W (AC)
0.5 hrs
Electric oven
1650W (AC)
0.5 hrs
Air conditioner
1800W (AC)
0.4 hrs
Induction cooker
1800W (AC)
0.4 hrs
Electric heater
2200W (AC)
0.4 hrs
If you want more battery life, you can get 3X battery life with an 2kWh extra battery at most
*This battery life is for calculation reference only, and the specific battery life may vary depending on the actual situation
Go green without sacrificing speed.
Pair with solar panels and charge in as fast as 3-6 hours with 1x400W, 2x220W portable solar panels. With its MPPT (Maximum Power Point Tracking) smart algorithm, DELTA 2 960 can actively detect the voltage and current in real-time to reach the maximum power point with >98% efficiency. That means a more efficient charge than other brands.
Pick from a range of solar panels to get the speed you need (110W, 160W, 220W, 400W). With that, you've got access to free energy anywhere.
Built to last 6x longer.
Finally… tech that's made to last. Get years of regular use until hitting 80% of its original capacity. That's down to its LiFePO4 battery chemistry giving you 3000+ full charge and drain cycles.
Safety first
Ready for emergencies.
Control from anywhere.
Use the EcoFlow app to control your DELTA 2 960 from anywhere using Wi-Fi. Link with Bluetooth when off-grid. Either way, you can check charging data, customize settings and adjust the charging speed with ease.
DELTA 2 960 is just the start. Link with a wide variety of EcoFlow products such as portable solar panels, the Wave portable air conditioner, extra batteries and so much more. All to deliver a one-stop power solution for your family.
What's in the Box
1. DELTA 2 960 2. AC charging cable 3. Car charging cable 4. DC5521 to DC5525 cable 5. User manual 6. App quick start guide 7.Warranty card
*The solar to XT60 charging cable is included only with purchase of EcoFlow portable solar panels.
What is the warranty for the Ecoflow transfer switch?
The EcoFlow transfer switch comes with a 1-year warranty.
How do you install the transfer switch?
What are the issues with installation of the transfer switch cost?
How much will the installation of the transfer switch cost?
Where can I find a licensed electrician?
Can I install the transfer switch myself?
Will it cause damage to EcoFlow Potable Power Stations when overloading in powering loads in the house?
How long does the transfer switch, switch a load from utility power to backup power when load shedding occurs?
What's the difference between Transfer Switch and Smart Home Panel?
960 Wh
Extra Battery
4 outlets, 1800W total (Surge 2700W)
2200W
2 ports, 5V, 2.4A, 12W Max
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A, 38W Max
AC Charging
1200W
11-60V, 15A, 500W max
Car Charging
Support 12V/24V battery, 8A
DC Charging
1100W
LFP (LiFePO4 battery)
Cycle life
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
27 lbs / 12 kg
Specs of Transfer Switch
Controller type
Type A controller
Operating voltage
AC185V~280V
Installation method
Integrated
Working position
2 working positions
Operating mode
Automatic operation, Manual operation
Generator control
Fire linkage control
Conversion mode
Self-throwing and self-reset
Transfer delay
Fixed 0.2 seconds
Return delay
Fixed 0.2 seconds
Never miss a sale🎉
