EcoFlow DELTA 2 Max Solar Generator (2×400W Rigid Solar Panels)
R 31,199.00 ZAR
Regular price R 31,199.00 ZAR
Sale price R 31,199.00 ZAR Regular price R 36,998.00
Save up to R 5,799
  • Complete Solar Setup: Includes DELTA 2 Max and two 400W Rigid Solar Panels for fixed solar backup.
  • Home & Workshop Backup: Suitable for home essentials, workshops, small businesses, and fixed backup points.
  • Reliable Stored Power: 2kWh capacity and 2400W AC output support higher-demand backup needs.
  • Solar Recharge: Recharge DELTA 2 Max in approx. 2.6 hours with two 400W rigid panels.
  • Fixed Solar Design: 400W rigid panels are suitable for longer-term placement and fixed solar setups.
  • Built for Outdoor Use: 23% conversion efficiency and IP68 protection support fixed outdoor installation.
Note: The solar to XT60 charging cable is excluded and needs to be purchased separately. Mounting accessories are sold separately; each 400W rigid panel requires one mounting set.
EcoFlow 50” Tilt Mount Bracket (2 Sets)
R 3,998 ZAR
For Angled Installations to Optimize Sun Exposure
R 399 ZAR
XT60 | XT60i
R 3,998 ZAR
R 399 ZAR
XT60 | XT60i
R 31,199 ZAR R 36,998 -R 5,799
Pay over 3 EQUAL zero-interest instalments of R 10,399.66 with PayJustNow.
Find out how...
Payment method
Payment method
Payment method
Payment method
Your Power Ally for Whole Home ComfortEcoFlow DELTA 2 Max
Durable, Safe, Lightweight
LFP Battery Chemistry
Advanced BMS Protection
Robust Design
Upgraded Tech, Lighter Weight
DELTA Max powers almost all the devices you need with a large 2400W AC output. With X-Boost proprietary technology, run appliances with an output of up to 3100W. Compared with similar portable power stations, DELTA 2 Max can power more devices while also preventing overloading and overheating.
Works in Sync with EcoFlow PowerStream Balcony Solar System
Transform your power station into a grid-tied solar energy solution that combines solar panels, a power station, and a microinverter. Power your home and save on energy bills day and night.
Power for the entire family
2048Wh Capacity
Home Backup
RVing & Outdoors
DIY Projects
Filmmaking & Photography
Expandable up to 6kWh
Triple the power
Fuel Up 80% in Only 43 Mins*
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 1.1 hours.
Up to 1000W Solar Input
Solar Charging Times
880W Charge approx. 2.6 hours
800W Charge approx. 2.8 hours
Take control of your power
Smart Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
Save more on electricity bills. Customize the working time of DELTA 2 Max to avoid peak rates.
Experience peace of mind during power outages. With our all-new AC Always On Mode, the AC power button stays on, even during a power outage or after the grid power is back, keeping your appliances powered no matter what.
Easily adjust AC or Solar input to fit your needs: backup power reserve or energy savings.Prioritize solar energy input via the EcoFlow app when using X-Stream AC + solar dual charging.
As Quiet as 30 dB
Peaceful charging
DELTA 2 Series
Learn More About DELTA 2
DELTA 2 Max
DELTA 2 Max
AC Charging Cable
AC Charging Cable
User manual & warranty card
2048Wh
Extra Battery
X-Boost 3100W
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
AC Charging
X-Stream Fast Charge 2300W, 10A
AC Input Voltage
Car Charging
Support 12V/24V battery, 8A
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Net weight (lbs)
50 lbs
Net weight (kg)
23 kg
Never miss a sale🎉
