DELTA 2 Max Solar Generator | EcoFlow ZA – EcoFlow South Africa
R 28,799.00 ZAR
Regular price R 28,799.00 ZAR
Sale price R 28,799.00 ZAR Regular price R 32,598.00
Save up to R 5,899
DELTA 2 Max is currently out of stock. Upgrade to the new DELTA 3 Max for powerful 2kWh backup. Shop Now
  • Complete Solar Setup: Pair DELTA 2 Max with a 220W or 400W Lightweight Solar Panel.
  • Home & Work Backup: Power larger essentials such as fridges, TVs, routers, and office setups.
  • Reliable Stored Power: 2kWh capacity and 2400W AC output support higher backup power needs.
  • Recommended Solar Recharge: Recharge DELTA 2 Max in approx. 6.4 hours with the recommended 400W panel.
  • Easy Solar Setup: The 400W panel includes a built-in 3.5m XT60 cable and an adjustable stand.
  • Built for Outdoors: IP68-rated solar panel protection helps guard against water and dust.
Note: Extension cables and parallel/series connection accessories for lightweight solar panels will be available later in 2026.
Size
EcoFlow Solar Parallel Connection Cable
R 399 ZAR
R 28,799 ZAR R 32,598 -R 3,799
Pay over 3 EQUAL zero-interest instalments of R 9,599.66 with PayJustNow.
Find out how...
Payment method
Payment method
Payment method
Payment method
Your Power Ally for Whole Home ComfortEcoFlow DELTA 2 Max
Durable, Safe, Lightweight
LFP Battery Chemistry
Advanced BMS Protection
Robust Design
Upgraded Tech, Lighter Weight
DELTA Max powers almost all the devices you need with a large 2400W AC output. With X-Boost proprietary technology, run appliances with an output of up to 3100W. Compared with similar portable power stations, DELTA 2 Max can power more devices while also preventing overloading and overheating.
Works in Sync with EcoFlow PowerStream Balcony Solar System
Transform your power station into a grid-tied solar energy solution that combines solar panels, a power station, and a microinverter. Power your home and save on energy bills day and night.
Power for the entire family
2048Wh Capacity
Home Backup
RVing & Outdoors
DIY Projects
Filmmaking & Photography
Expandable up to 6kWh
Triple the power
Fuel Up 80% in Only 43 Mins*
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 1.1 hours.
Up to 1000W Solar Input
Solar Charging Times
880W Charge approx. 2.6 hours
800W Charge approx. 2.8 hours
Take control of your power
Smart Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
Save more on electricity bills. Customize the working time of DELTA 2 Max to avoid peak rates.
Experience peace of mind during power outages. With our all-new AC Always On Mode, the AC power button stays on, even during a power outage or after the grid power is back, keeping your appliances powered no matter what.
Easily adjust AC or Solar input to fit your needs: backup power reserve or energy savings.Prioritize solar energy input via the EcoFlow app when using X-Stream AC + solar dual charging.
As Quiet as 30 dB
Peaceful charging
DELTA 2 Series
Learn More About DELTA 2
DELTA 2 Max
DELTA 2 Max
AC Charging Cable
AC Charging Cable
User manual & warranty card
2048Wh
Extra Battery
X-Boost 3100W
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
AC Charging
X-Stream Fast Charge 2300W, 10A
AC Input Voltage
Car Charging
Support 12V/24V battery, 8A
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Net weight (lbs)
50 lbs
Net weight (kg)
23 kg
Never miss a sale🎉
