EcoFlow DELTA 3 Ultra Plus + Alternator Charger Plus 1000 | EcoFlow ZA – EcoFlow South Africa
R 43,399.00 ZAR
Vendor EcoFlow South Africa
Regular price R 43,399.00 ZAR
Sale price R 43,399.00 ZAR Regular price R 44,499.00
Save R 1,100
- The DELTA 3 Ultra Plus + Alternator Charger Plus 1000 bundle includes the Smart Generator Adapter.
- Charge while driving, no need to bring home your power station
- 3kWh Capacity, 3600W AC output. Recharge with 1000W alternator charger while driving in 3.3 hrs
- 10×faster on-the-go charging, charge 1kWh in 1 hour
- Solar input available*, support up to 1000W alternator+solar combined input
A 3-in-1 fast charger, maintainer, and jump start
* Solar input requires an Alternator Charger Plus 1000 Solar Input Cable (sold separately).
** Recommended to bundle with the 1-2kWh portable power station featured with XT150 extra battery port (2-pin type). Power stations without an XT150 port are not directly compatible with the Alternator Charger Plus 1000. For specific compatibility questions, please contact the EcoFlow ZA support team.
Contact Us via Either of the Below Methods:
+27 80 088 0002(Mon-Fri, 8:30 - 17:00)
Products
R 43,399 ZAR R 44,499 -R 1,100
Pay over 3 EQUAL zero-interest instalments of R 14,466.33 with PayJustNow.
Find out how...
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
* To reach 1000W input, DELTA 3 Ultra/DELTA Pro 3 / DELTA Pro must use the Smart Generator Adapter or Alternator Charger Custom Fit Output Cable. Included free in bundles.
*To enable solar charging, the EcoFlow Alternator Charger Plus 1000 Solar Input Cable (12AWG, 5m) is required. Coming soon.
Traditional vs EcoFlow's Portable Dual Battery System
Faster - Top Up 1kWh in Just 1Hour*
Charge as you drive – 10× faster than a traditional car cigarette lighter. Power up 1kWh in only 1 hour and arrive with a fully charged portable power station.
* Tested using a 12V car charging system at 25 ℃ ambient temperature. Actual performance may vary by vehicle and environment.
Alternator + Solar Flexible Dual Charging
By connecting solar directly to the alternator charger port, you free up the XT60 port on your portable power station. This allows you to use both the alternator charger and solar panels at the same time.
* To enable solar charging, the EcoFlow Alternator Charger Plus 1000 Solar Input Cable (12AWG, 5m) is required. Coming soon.
Cloudy or Low-Sunlight Days
Turn off solar charging in the app to draw up to 1000W from the alternator alone.
Sunny Days
Turn on solar charging in the app to combine 700W from the alternator + up to 300W from solar, reaching a maximum of 1000W input.
Charge While You Drive, Power Anywhere
*To reach 1000W input, DELTA 3 Ultra /DELTA Pro 3 /DELTA Pro must use the Smart Generator Adapter or Alternator Charger Custom Fit Output Cable. Included free in bundles.
DELTA 2/ DELTA 3 Plus support 1000W input directly.
Car Camping
RV Living
Vehicle Conversions
Disaster Evacuation
For power stations of 2kWh and above, the Alternator Charger frees you from heavy lifting. Charge your high-capacity unit to full while driving—no more hauling it back home for AC charging. Just leave it in your car and let the alternator do the work.
Perfect for RV and pickup conversions with high-power appliances. Enable dual-unit charging with two Alternator Charger Plus 1000s to fully charge DELTA Pro 3 in just 2.7 hours*—45% faster than a single unit.
Skip traditional hardwired 12V batteries and DC-to-DC chargers. With a power station + alternator charger setup, you get ultimate flexibility: power onboard systems while driving, then take your power outdoors for lighting, cooking, or tools.
When emergencies hit, restore your power station to full during the evacuation drive—even if it’s been sitting unused and partially discharged.
Reverse Charging for Car Battery Protection
Supports reverse charging* to the starter battery via the power station or solar panels. This helps maintain vehicle battery health and prevents draining.
*Requires an output cable with communication function (XT150 or 4+8 supported; XT60 not supported). The Alternator Charger Plus 1000 includes one XT150 output cable in the box.
Use when multiple 12V loads are connected to the vehicle battery. Provides supplemental power from the power station through the alternator charger to keep the starter battery from draining.
Charging Mode – up to 1000W
Reverse Charging Mode – up to 1000W
Battery Maintenance Mode – up to 100W
Use when battery voltage is healthy. Charges the power station while driving.
- Pure Solar Charging Mode – up to 300W: Use without a power station connected. Supplies power directly from solar panels to the starter battery.
- Emergency Charging Mode – approx. 15A: Use when the vehicle battery is depleted and the engine won’t start. Functions as an alternative to a jump starter by slowly restoring the battery to normal voltage.
Use when starter battery voltage is low. Works as a battery maintainer, delivering steady current to extend starter battery lifespan.
Fully Utilize 3 Charging Modes Across Scenarios
Car Camping
RV Living
Overlanding & Van Conversions
Simpler – Smart Control via App or Infotainment
An industry first: supports car infotainment connectivity, compatible with Apple CarPlay and Android Auto interfaces.
Monitor real-time starter battery voltage, portable power station SOC, and remaining charging time directly on your vehicle’s infotainment screen. Adjust charging modes on the go to manage power station status—everything at your fingertips.
Five Layers of Protection with Advanced Quality Standards
Safer – Enhanced Alternator & Starter Battery Protection
The Alternator Charger harnesses surplus alternator power without disrupting normal vehicle operation or adding extra load while driving.
Plug-and-Play Design for Easy Installation
Braided Input Cable – Easy Routing
Direct Plug-In Terminals – Quick Transfers
Ignition Start – Automatic Power-On
A braided-sleeve input cable reduces friction for smoother firewall passage during installation. Its abrasion-resistant design prevents sheath damage and meets automotive industry standards for long-term durability.
No screws, no tools. The charger’s direct plug-in terminals make it easy to connect or disconnect your portable power station—perfect for owners who use multiple vehicles.
Once the ignition cable is connected, the alternator charger powers on automatically with the engine. No need to press a button or activate it in the app each time.
Quick 10-Minute Installation
Follow the step-by-step guide and get set up in minutes.
How to Choose Your Alternator Charger
Buy a DELTA 3 Max Plus / DELTA 3 Ultra Plus / DELTA Pro / DELTA Pro 3 with an 800W or 1000W Alternator Charger bundle, get Custom Output Cable or Smart Generator Adapter for free.
* DELTA 2/DELTA 3/ DELTA 3 Plus/DELTA 3 1500 support 1000W input directly.
*When Using 1000W Alternator Charger or 800W Alternator Charger, DELTA 3 Max must use the EcoFlow Alternator Charger XT60 Output Cable (1m). Included free in bundles.
*When connected to 1000W Alternator Charger or 800W Alternator Charger, the DELTA 3 Max can only reach 500W input, and does not provide reverse charging to the vehicle’s battery.
Alternator Charger Plus 1000 Specs
Approx. 1.7 kg
276×187×38 mm
ALT IN Port Input
12V/24V⎓(11V-31V⎓), 75A Max
Charging Mode
ALT IN Port Input: 12V/24V⎓(11V-31V⎓), 75A Max
Battery Port Output: 24V⎓/40V-60V⎓, 20A Max, 1000W Max
Charging Mode (Solar Only)
Input: 11–60V, 15A max, 300W max (SOLAR port)
ALT IN Port Output: 13.8V/27.6V⎓, 100W Max
Battery Port Input: 40V-60V⎓, 3A Max
Reverse Charge Mode
ALT IN Port Output: 13.8V/27.6V⎓, 75A Max
Battery Port Input: 40V-60V⎓, 20A Max
Rated Current of Fuse
125A
Operating Temperature
–10℃ to 45℃ (14℉ to 113℉)
Storage Temperature
–30℃ to 70℃ (–22℉ to 158℉)
Protection Type
Reverse polarity protection/ Overcurrent protection/ Short circuitprotection/ Overvoltage and undervoltage protection/ Storage Battery Over-discharge Protection (Provided with integral protection against overloads)
Never miss a sale🎉
