Portable Power Station DELTA Max Refurbished | EcoFlow ZA – EcoFlow South Africa
EcoFlow DELTA Max Portable Power Station (Refurbished)
R 15,999.00 ZAR
Video
Regular price R 15,999.00 ZAR
Sale price R 15,999.00 ZAR Regular price R 44,999.00
Save up to R 29,000
DELTA Max(2000) has been discontinued. Discover the next-generation DELTA 2 Max here>>
Refurbished devices are available in Grade A, Grade B, and Grade C
Grade A: Nearly new, with the same warranty as a brand-new device.
Grade B: Minor signs of use, at least 70% new; comes with a 2-year warranty.
Grade C: Noticeable signs of use; includes a 6-month warranty.
This portable power station is equipped with International standard plugs. Adapters will be needed to use the product.
Level up with the EcoFlow PowerStream Balcony Solar System:
Pair with an EcoFlow PowerStream Microinverter and gain a grid-tied solar energy solution that powers your home day and night.
• 2-6kWh expandable capacity for home backup
• Power heavy-duty devices with 2400W output
• Charge 0-80% in just 65 minutes
• Solar charge in as fast as 2.5 hours
• Up to 3400W fast dual charging
• Smart app control
Model
EcoFlow DELTA Max Cover
R 1,699 ZAR
EcoFlow 400W Lightweight Portable Solar Panel
R 8,499 ZAR R 10,999 ZAR
25% Conversion Rate
5 Year-Warranty
IP68 Waterproof
R 15,999 ZAR R 44,999 -R 29,000
Pay over 3 EQUAL zero-interest instalments of R 5,333.00 with PayJustNow.
Find out how...
Payment method
Payment method
Payment method
Payment method
A transfer switch is a device that switches a load between Grid Power and Backup Power, simply connect EcoFlow Portable Power Station to your main panel via a Transfer Switch for instant home backup (Transfer Time 1~2s).
*Picture for reference only, subject to our available products.
*AC Plug Cable is needed to connect Power Station with Transfer Switch, and be provided by the electrician.
Learn more about how to backup your home with our Portable Power Station and Transfer Switch: Whole-Home Backup Kit User Guide
Expandable Capacity
Dual Charging
Power multiple devices
800W max Solar Input
Expandable home backup power.
DELTA Max charges up safely and rapidly from 0-80% in just 1 hour. And it gets even better. If you're looking for an even faster way to charge up DELTA Max, you can combine AC with the Smart Generator, AC with solar, or the Smart Generator with solar.
With EcoFlow's X-Boost technology, DELTA Max can power heavy-duty devices up to 3000W. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That's the industry gold standard for a portable power station of this size and capacity.
Harness the power of the sun.
DELTA Max connects with up to 2x 400W EcoFlow solar panels to deliver 800W Max solar charging speeds. With a voltage range from 11-100V and the solar connector, you can also connect other solar panels to your DELTA Max. Even during cold or cloudy days, our smart maximum power point tracking (MPPT) algorithm automatically detects voltage and current in real time to give you optimum solar generation throughout the day.
Emergency backup power.
Multiple ways to charge.
1.DELTA Max 2.AC Charging Cable 3.Car Charging Cable 4.DC5521 to DC5525 cable 5.User Manual
It depends on the total voltage and watts of solar panels you choose. As long as the solar panels use MC4 connector and its voltage and current are under 11-100V, 13A max range.
When charging DELTA Max and its extra battery together, you can reach 3600W max charging speeds by combining any two methods of AC, solar and Smart Generator. For DELTA Max single unit, you can recharge it at standard wall outlets (1800W max), or combine AC and solar charging to reach max 2000W charging speeds.
When your portable power station is plugged into the wall, any electronics plugged into it are powered from the grid and not its battery. When power from the grid stops, as in a blackout, the power station automatically switches to battery power within 30ms.
DELTA Max is not water-resistant, so it should be kept away from liquids. Or if you're looking for water-resistance solution, you can purchase the DELTA Max case to water-resistance protection.
The EcoFlow transfer switch comes with a 1-year warranty.
There are wiring diagrams and a how-to video of the installation and operating instructions for reference.
Firstly, installation of the transfer switch should be done by a licensed electrician or a qualified professional who will issue you a Certificate of Compliance (COC) afterward so that the insurance company won't repudiate any electrical-linked claims in the future. Secondly, to avoid the unit tripping out, you can discuss with your electrician which circuits or appliances should be excluded based on your electricity consumption and the power station capacity you own, such as the stove, geyser, and pool pump. Last, be aware of putting the transfer switch into a box to prevent electric shock. It is only viable with indoor circuit breaker panels.
Generally, the installation costs include labour, traveling, cabling, protection box, and COC. It varies with many factors like traveling distance and the length of cable. The exact installation cost will need to be estimated by an electrician based on the specifics of your home's electrical circuits. We highly recommend that you source different electricians and get comparative quotes.
We have authorized some qualified installers in most of Johannesburg and Cape Town. Please contact us Monday to Friday, 8:30 a.m. to 5 p.m. GMT+2 at +27 80 088 0002 (toll-free) or support.za@ecoflow.com for more information. If you live elsewhere or aren't satisfied with the installation price, you can also go to our Facebook community and leave your question. There are many enthusiastic EcoFlow users who can help you.
Installation of the transfer switch should be done by a licensed electrician or a qualified professional.
EcoFlow Portable Power Stations have safety mechanisms to prevent overloads. And it's also crucial to exclude high-power appliances or circuits.
The transfer time is about 1 second. This transfer time may seem long, but it actually provides two important benefits. Firstly, it helps to prevent voltage surges that could otherwise harm your household appliances during sudden power fluctuations, which is crucial for protecting your appliances. Secondly, this transfer time is crucial for our products' longevity and safe operation.
a.Transfer Switch is divided into MTS and ATS, MTS is a manual switch, ATS is an automatic switch; SHP is an automatic smart switch, which can monitor the power consumption of each open circuit and control it remotely at the same time;Understand the situation of each line more accurately
b.Capacity difference: SHP has two ports and can be connected to 2 groups of DP (each group of DP can be connected to 2*DP EB); TS can be connected to a group of DP or a whole group of Power hub+LFP.
c.Different cables: SHP uses EF's unique Infinity cable (Delta Pro ONLY); TS uses Generator cord;
d. SHP can only connect to DELTA Pro, Transfer Switch can connect to all power stations (if power is satisfied).
Specs of DELTA Max (2000)
Approx. 48 lbs (22 kg)
Dimension
19.6 x 9.5 x 12 in (49.7 x 24.2 x 30.5 cm)
Charge Temperature
32 to 113°F (0 to 45°C)
Discharge Temperature
-4 to 113°F (-20 to 45°C)
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel, Smart Generator, Smart Extra Battery
Full Recharge Time
1.6 Hours (AC) 21 Hours (12V Car Charger) 5.6-11.2 Hours (Using 4x 110W Solar Panels) 4.2-8.4 Hours (Using 4x 160W Solar Panels) 3.2-6.3 Hours (Using 2x 400W Solar Panels)
2016Wh
Cell Chemistry
NCM
Cycle life
800 cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and Certification
CE WEEE CTP RCM KC
AC Charge Input (Power)
X-Stream charge (2000W max)
AC Charge Input (Voltage and Amperage)
220-240V~50Hz/60Hz, 10A
Solar Charge Input
11-100V 13A Max, 800W max
Car Charge Input
Supports 12V/24V Battery, Default 8A
AC Output (x4)
Pure Sine Wave, 2400W total (surge 4600W), 230V~ (50Hz/60Hz)
3000W
USB-A Output (x2)
5V 2.4A, 12W max, per port
USB-A Fast Charge (x2)
5V/2.4A, 9V/2A, 12V/1.5A, 18W Max
USB-C Output (x2)
5/9/12/15/20V 5A, 100W max
Car Charger Output (x1)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Smart Extra Battery
Supports up to 2 DELTA Max Smart Extra Batteries (sold separately)
Smart Generator
Supported (sold separately)
Wi-Fi
Supported
Specs of DELTA Max (1600)
Dimension
Charge Temperature
24 months
Charge Method
Full Recharge Time
1.6 Hours (AC) 16.8 Hours (12V Car Charger) 4.5-9 Hours (Using 4x 110W Solar Panels) 3.4-6.8 Hours (Using 4x 160W Solar Panels) 2.5-5 Hours (Using 2x 400W Solar Panels)
1612Wh
Cell Chemistry
NCM
Cycle life
500 Cycles to 80%+ capacity
Management Systems
CE WEEE CTP RCM KC
X-Stream charge (1600W max)
Solar Charge Input
Car Charge Input
AC Output (x4)
Pure Sine Wave, 2000W total (surge 4600W), 230V~ (50Hz/60Hz)
2500W
USB-A Output (x2)
USB-C Output (x2)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Smart Extra Battery
Smart Generator
Wi-Fi
Supported
Specs of Transfer Switch
Operation Mode
Auto/Manual
Poles
2P
Rated Current
63A
Transfer Time
1Sec
Electrical Life
1,500 times
Short-circuit switching (breaking) capacity
5kA
Phase
Single phase
Operating Frequency
50HZ/60HZ
Rated Voltage
AC 230V
Operating Temperature
-5℃~40℃
Mechanical Life
6,000 times
Short-circuit switching (making) capacity
7.65kA
Car charger shares power with the DC5521 output port offering maximum output of 126W.
Whether the product can be charged or discharged depends on the actual temperature of the battery pack
DELTA Max (2000) needs to be connected to the DELTA Max Smart Extra Battery for dual charging.
Never miss a sale🎉
