EcoFlow 220W Bifacial Portable Solar Panel | EcoFlow South Africa
Regular price R 5,599.00 ZAR
Sale price R 5,599.00 ZAR Regular price R 7,999.00
Save up to R 5,500
  • Ultra-Light & Portable: Single panel weighs just 7kg+, making it easy to carry, set up, and store.
  • Versatile Applications: Ideal for home backup, off-grid cabins, and outdoor adventures alike.
  • 25% Solar Efficiency: Bifacial design captures sunlight from both sides for up to 25% more energy
  • All-Day Energy from One Panel: A full day of sun can cover your daily outdoor power needs.
Size
Accessories
R 399 ZAR
XT60 | XT60i
EcoFlow Solar Extension Cable
R 399 ZAR
R 399 ZAR
R 399 ZAR
XT60 | XT60i
R 5,599 ZAR R 7,999 -R 2,400
Pay over 3 EQUAL zero-interest instalments of R 1,866.33 with PayJustNow.
Find out how...
Capture more energy with a dual-sided design
With a 220W primary side, and a 175W side on the back for ambient light, you can capture up to 28% more solar energy and charge your portable power station even faster.
Generate even more energy
With the portable solar panel industry's first use of TOPCon solar technology,
we've raised the bar on conversion efficiency, reaching 25%.
Charge faster with a more compact panel.
Capture more solar with an adjustable angle
With a newly integrated solar angle guide and stand,
adjust the angle of the panel by 30 degrees in seconds to get the most sunshine at all times.
Durable and waterproof
Built to weather the storm
With an IP68 waterproof rating, our NextGen 220W Bifacial Solar Panel maintains its high performance even when it's in contact with water. So you can recharge near a lake or take it out on your boat without worry!
Never too hot
Designed to withstand high temperatures while still ensuring high levels of solar generation.
Lightweight and portable
Generate solar energy anywhere with our compact-designed panels. Fold away to store in your van or closet, pull them out in seconds to start using.
EcoFlow Solar Panel Comparison
NextGen vs. Original
NEW
EcoFlow NextGen Portable Solar Panel
EcoFlow Portable Solar Panel
Cell Type
N Type TOPCon
monocrystalline silicon
P Type PERC
Conversion Efficiency
Weight
(5.1 kg-7.2 kg)
(5.6 kg-9.5 kg)
Stand Type
30-60° Integrated Adjustable Stand
Separate Kickstand Case
Additional Feature
Integrated Solar Angle Guide
No Solar Angle Guide
What’s in the box
XT60i Charging Cable
Protective Bag
Protective Bag
Quick Start Guide, Safety Instructions & Warranty Card
Rated Power
220W (±5W) Front/175W Rear
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25.00%
Weight (Solar Panel)
Approx. 15.4 lb (7.0 kg)
Unfolded: 24.2×84.8×1.0 in/615×2155×25 mm
Folded: 24.2×23.2×1.3 in/615×590×32 mm
Connector Type
Photovoltaic connectors
Warranty (US)
12 months
Open Circuit Voltage
21.5V (Vmp 18.4V)
Short Circuit Current
12.4A (Imp 11.9A) Front Side/ 9.9A (Imp 9.5A) Rear Side
Waterproof & Dustproof
Customer Reviews
Based on 8 reviews
50%
(4)
38%
(3)
0%
(0)
13%
(1)
0%
(0)
W
Werner Van Heerden
Not built to last!!!
I bought the Delta 2 Max with 220 bifacial solar panel a week ago. The Delta 2 Max works exactly like promised, but the bifacial solar panel is a huge disappointment. Please don’t put in the advertising that it’s built to last! For a portable solar panel that will be handled by setting it up, moving it around and folding it back up it’s a very poorly designed and constructed panel. I have been very careful setting it up and moving it around, but by the second time trying to adjust the flimsy legs one of the four panels cracked. There’s no dedicated or reinforced area to hold or handle the panel. If I knew the panel are going to be so flimsy I would never have bought it. Ecoflow should really look into the design and construction of this “ built to last “ portable panel.
C
Customer
220 solar panel
I’ve got this up and running quickly. I will say that it’s most likely a better unit for traveling. As it is foldable it travels well however that does make it awkward to set up and adjust as the sun moves. I’ve been pleased with the 190 watts I’ve been able to get from it. That’s without setting it up with 100% efficiency ….. doing do is slightly laborious .
I actually have 2 of these. I have not run them together yet.
I really like these for traveling purposes but I think I would rather have solid panels for home.
B
Bill D
Good purchase
High quality product that is well thought out. The packaging was great and the panel is exactly as advertised.
R
Rain
Received Damaged/ 5 Stars for Customer Service
Unfortunately we didn't get a chance to experience the bifacial solar panel. As it was damaged during delivery. What I can say regarding the transaction is Ecoflow customer service was wonderful in assisting with the return and refund of this purchase. The 5 stars is for their customer service not the broken panel.
J
Jamesw
220w solar panels
Awesome product. I bought 2 of this panels and the setup is easy and they very good product.
Never miss a sale🎉
