Your Power Ally for Whole Home Comfort
EcoFlow DELTA 2 Max
Durable, Safe, Lightweight
LFP Battery Chemistry
Advanced BMS Protection
Robust Design
Upgraded Tech, Lighter Weight
Power pretty much anything with up to 3400W Output
DELTA Max powers almost all the devices you need with a large 2400W AC output. With X-Boost proprietary technology, run appliances with an output of up to 3400W. Compared with similar portable power stations, DELTA 2 Max can power more devices while also preventing overloading and overheating.
Works in Sync with EcoFlow PowerStream Balcony Solar System
Transform your power station into a grid-tied solar energy solution that combines solar panels, a power station, and a microinverter. Power your home and save on energy bills day and night.
Expandable up to 6kWh
Triple the power
Fuel Up 80% in Only 43 Mins*
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 1.1 hours.
Up to 1000W Solar Input
Solar Charging Times
880W Charge approx. 2.6 hours
800W Charge approx. 2.8 hours
As Quiet as 30 dB
Peaceful charging
DELTA 2 Series
DELTA 2 Max
AC Charging Cable
User manual & warranty card
2048Wh
Extra Battery
6 outlets, 2400W total (Surge 4800W)
X-Boost 3100W
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
AC Charging
X-Stream Fast Charge 2300W, 10A
AC Input Voltage
Car Charging
Support 12V/24V battery, 8A
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Net weight (lbs)
50 lbs
Net weight (kg)
23 kg
