EcoFlow DELTA Solar Generator (PV160W) | EcoFlow South Africa
EcoFlow DELTA 1300 Solar Generator (PV160W)
R 15,999.00 ZAR
Regular price R 15,999.00 ZAR
Sale price R 15,999.00 ZAR Regular price R 33,998.00
Save up to R 17,999
DELTA 1300 has been discontinued. Discover the next-generation DELTA 2 960 here>>
This portable power station is equipped with International standard plugs. Adapters will be needed to use the product.
EcoFlow DELTA Power Station represents the new standard of battery-powered generators. Compatible with a wide range of devices, you can stay powered for hours whenever and wherever.
The World’s Fastest Charging Power Station Charges at 2 to 3 times the speed of most portable power stations in the market. 0—80% in under one hour.
Power Almost Anything DELTA’s large inverter load can even support heavy-duty DIY tools up to 1800W (3300W Surge, Pure Sine Wave). That makes it the best portable power station at this size for output.
      Power 11 Devices At Once All the ports you’d ever need for your gear. Power up to 11 devices all at the same time via AC, DC or USB outlets. Ideal as a battery generator for blackouts.
      Fast Solar Panel Recharging The DELTA can be fully recharged from three EF 160W Solar Panels in 3-7 hours, depending on sunlight conditions. An MC4 to XT60 Solar Cable is included.
      Intelligent Solar Power The EcoFlow 160W Solar Panel is designed to produce maximum power at any time of the day when paired with an EcoFlow power station. The solar panel has a high conversion efficiency of 21-22%, and the EcoFlow MPPT power station algorithm delivers improved performance in cold and cloudy environments within the operation range.
      Products
      EcoFlow Solar Parallel Connection Cable
      R 399 ZAR
      EcoFlow Solar Extension Cable
      R 399 ZAR
      R 499 ZAR
      XT60 | XT60i
      R 499 ZAR
      XT60 | XT60i
      R 15,999 ZAR R 33,998 -R 17,999
      Pay over 3 EQUAL zero-interest instalments of R 5,333.00 with PayJustNow.
      Find out how...
      Payment method
      Payment method
      Payment method
      Payment method
      The world's fastest charging portable power stations
      EcoFlow have the world's fastest charging power stations. DELTA charges from 0-80% in under an hour, giving you a quick boost of power even during the worst situations.
      So Much More Sun
      Premium monocrystalline silicon cells provide a high conversion efficiency of 21-22%. Recharge even faster by chaining multiple panels in a series or in parallel.
      Better Together
      Recharge freely and naturally when you link EcoFlow's 160W Solar Panel to a DELTA portable power station.
      DELTA can be recharged to 0%~80% in 1 hour, and be fully recharged within 1.6 hours.
      Yes. During this situation, DELTA will prioritise AC charging, and default to DC charging when AC charging is not used.
      DELTA supports an entry-level UPS function. We recommended testing your devices case-by-case.
      DELTA can power essential devices whether you're at home or outdoors. Devices include lights, microwave ovens, fridges, hairdyers, laptops, phones, electric frying pans, and more.
      DELTA does not support EcoFlow App.
      Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
      Yes, if the only thing between it and the sun is transparent, but it won't charge as well compared to being outside. You can compare the difference by looking at the input section of your power station's LCD screen.
      What's in the bundle
      1. EcoFlow DELTA 2. DELTA Bag 3. Solar Panel Charging Cable 4. 1.5m AC Charging Cable 5. 1.5m Car Charging Cable 6. User Manual of DELTA 7. 160W Solar Panel 8. 160W Solar Panel Bag 9. User Manual of 160W Solar Panel
      30.9lbs (14kg)
      Dimension
      15.7 x 8.3 x 10.6 in (40 x 21 x 27 cm)
      Charge Temperature
      32 to 113°F (0 to 45°C)
      Discharge Temperature
      -4 to 113°F (-20 to 45°C)
      24 months
      Charge Method
      AC Wall Outlet, 12V Car Adaptor, Solar Panel
      Full Recharge Time
      1.6 Hours (AC) 13.5 Hours (12V Car Charger)
      10.5-21 Hours (Using 1x 160W Solar Panel)
      5-10 Hours (Using 2x 160W Solar Panels)
      3.5-7 Hours (Using 3x 160W Solar Panels)
      1260Wh (50.4V)
      Cell Chemistry
      Lithium-ion
      Life Span
      800 Cycles to 80%+ capacity
      Management Systems
      BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection.
      Testing and certification
      UL CE FCC RoHS PSE
      Cell Type
      18650
      AC Charge Input Power
      X-Stream charge (1200W max)
      AC Charge Input Voltage
      220-240Vac
      Solar Charge Input
      400W 10-65V DC 10A max
      Car Charger
      12V/24V DC 8A max
      AC Output (x4)
      1800W (Surge 3300W) total, 230ac (50Hz)
      USB-A Output (x2)
      5V DC, 2.4A, 12W Max, per port
      USB-A Fast Charge (x2)
      5V/2.4A,9V/2A,12V/1.5A 18W Max, per port
      USB-C Output (x2)
      5V DC, 9V DC, 15V DC, 20V DC, 3A, 60W Max, per port
      Car Power Output (x1)
      108.8W, 13.6V DC, 8A max
      Never miss a sale🎉
