EcoFlow 400W Portable Solar Panel | EcoFlow South Africa
EcoFlow 400W Portable Solar Panel(for showroom)
R 9,999.00 ZAR
Regular price R 9,999.00 ZAR
Sale price R 9,999.00 ZAR Regular price R 10,999.00
Save up to R 1,000
  • High-Capacity Backup: Supports home backup, off-grid cabins, and high-demand outdoor appliances with ease.
  • Single Panel, Big Power: One 400W panel provides enough energy for short-term charging needs.Outdoor-Ready Design: Operates across a wide temperature range, built to handle diverse outdoor conditions.
  • IP68 Waterproof & Weatherproof: Durable enough for permanent outdoor placement—no daily setup required.
  • Compact & Foldable: Despite its power, the panel folds for easy storage and transport.
Size
EcoFlow Solar Extension Cable
R 399 ZAR
R 399 ZAR
XT60 | XT60i
R 399 ZAR
R 399 ZAR
XT60 | XT60i
R 9,999 ZAR R 10,999 -R 1,000
Pay over 3 EQUAL zero-interest instalments of R 3,333.00 with PayJustNow.
Find out how...
Convert sunlight into clean, renewable energy using 400W portable solar panels, perfect for camping, RVs, and home use.
Universal
Seamless
Foldable
Portable
Travel-friendly
With a compact, folding design and shoulder strap, easily carry a 400W portable solar panel to your campsite or store in your RV while you're on the move.
Stands & Delivers
Protect your panels with a lightweight case that turns into a practical stand. Prop up your solar panels anywhere you go and get just the right angle to capture the sun.
Durable & Waterproof
Made from layers of robust materials that offer both flexibility and strength, take your portable solar panels into the wildest terrain. An IP68 waterproofed surface protects solar cells from debris, dust, and water.
Works with all EcoFlow Portable Power Stations
Plug into any EcoFlow solar generators to instantly collect the sun's rays. With the universal solar connector, they also work with most third-party generators.
Stable & Reliable Energy
Pair your 400W portable solar panels with an EcoFlow power station for a reliable power supply. Using MPPT technology, the generator adjusts its efficiency levels to offer a high 22% conversion rate.
Compare The Models
110W Solar Panel
Rated Power : 110W (±5W)
Unfolded : 178.5 x 42.0 x 2.5 cm
Efficiency : 22-23%
Warranty : 12 Months
R 6,199.00
160W Solar Panel
Rated Power : 160W (±5W)
Unfolded : 157 x 68 x 2.4 cm
Efficiency : 21-22%
R 6,999.00
400W Solar Panel
Rated Power : 400W (±5W)
Unfolded : 236.5 x 105.8 x 2.5 cm
Efficiency : 22.6%
R 20,999.00
1. 400W Solar Panel 2. Kickstand Case 3. Solar to XT60 Charging Cable 4. User Manual
Portable solar panels are an extremely effective, clean, and renewable way to charge a portable power station. EcoFlow 400W portable solar panels have a larger wattage than typical solar panels and are more efficient due to their monocrystalline cells. Additionally, EcoFlow portable power stations use an MPPT algorithm that ensures a constant energy supply. Unlike static solar panels, portable solar panels are easily moved and adjusted depending on where the sun is in the sky.
Positioning portable solar panels at an angle between 30-45 degrees, facing the direction of the sun, is best. EcoFlow portable solar panels have a built-in stand that can be adjusted, depending on where the sun is in the sky.
Solar panels that are portable, foldable, and lightweight are the best kind for camping.
Rated Power
400W
Cell Type
Monocrystalline silicon
Efficiency
22.60%
41.7*93.1*0.98 in (105.8*236.5*2.5cm)
Open Circuit Voltage
48V (Vmp 41V)
Short Circuit Current
11A (Imp 9.8A)
Weight(Solar Panel)
Approx. 35.3lbs (16.0Kg)
Weight (with Kickstand Case)
Approx. 41.9 (19kg)
Customer Reviews
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
Never miss a sale🎉
