EcoFlow DELTA 2 960 + DELTA 2 Smart Extra Battery – EcoFlow ZA – EcoFlow South Africa
EcoFlow DELTA 2 960 + Smart Extra Battery
R 23,999.00 ZAR
Regular price R 23,999.00 ZAR
Sale price R 23,999.00 ZAR Regular price R 29,999.00
Save up to R 11,500
Extra Battery and NextGen 220W Solar Panel (Monofacial) starts shipping in 1–2 weeks.
  • Expandable capacity - 1-3kWh expandable capacity to grow your storage to your needs. Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
  • Huge AC output - 1800W AC output means you can power more than 90% of your home appliances. Or, try plugging in up to 15 devices at once. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2200W thanks to X-Boost technology.
  • 7x Faster AC charging - X-Stream tech means that DELTA 2 charges 7 times faster than the competition. That’s 0–80% in just 50 minutes and 0-100% in 80 minutes with AC input.
  • Or go green without sacrificing speed - Plug in portable solar panels and get up to 500W input to charge from anywhere in as fast as 3 hours.
  • Built to last 6x longer - Get 10 years of daily use until hitting 80% of its original capacity. That’s down to its LFP battery chemistry giving you 3000+ cycles.
  • Control from anywhere - Use the EcoFlow app to control your DELTA 2 from anywhere using Wi-Fi. Link with Bluetooth when off-grid. Either way, you can check charging data, customize settings and adjust the charging speed with ease.
Click here to learn more about DELTA 2 Smart Extra Battery.
Click here to learn more about DELTA 2 960 Portable Power Station.
Size
EcoFlow DELTA 2 Bag
R 999 ZAR
EcoFlow DELTA 2 Bag
R 999 ZAR
R 23,999 ZAR R 29,999 -R 6,000
Pay over 3 EQUAL zero-interest instalments of R 7,999.66 with PayJustNow.
Find out how...
EcoFlow DELTA 2 is a must-have for any home that puts power security & comfort first. Ensure you're prepared with the power station made for almost any situation your family could find themselves in. All while staying green.
With a capacity of 1kWh to start with, you’ve got enough energy for your essentials for hours on end. Need even more? Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
Power pretty much anything.
A 1800W AC output means you can power more than 90% of your home appliances. That’s your microwave, fridge, or even coffee maker covered in a blackout. Or, try plugging in up to 15 devices at once for when you’re around the table with the family. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2200W thanks to X-Boost technology.
The fastest charging on the market.
X-Stream tech means that DELTA 2 charges 7 times faster than the competition. That’s 0–80% in just 50 minutes with AC input, or 0-100% in 80 minutes.
Go green without sacrificing speed.
Pair with solar panels and charge in as fast as 3-6 hours with 1x400W, 2x220W portable solar panels. With its MPPT (Maximum Power Point Tracking) smart algorithm, DELTA 2 can actively detect the voltage and current in real-time to reach the maximum power point with >98% efficiency. That means a more efficient charge than other brands.
Built to last 6x longer.
Finally… tech that’s made to last. Get years of regular use until hitting 80% of its original capacity. That’s down to its LiFePO4 battery chemistry giving you 3000+ full charge and drain cycles.
Ready for emergencies.
Portable & light.
Designed so you can take power anywhere, DELTA 2 weighs about as much as a medium-sized dog. Compared to generators, it’s portable, indoor-friendly, and light. Add on the waterproof bag and you can use it outdoors in any weather too.
You've got our word.
With a 5-year extended warranty, you can rest easy knowing you've got a unit built to last.
Specs of DELTA 2
1024 Wh
Extra Battery
6 outlets, 1800W total (Surge 2700W)
2200W
2 ports, 5V, 2.4A, 12W Max
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A, 38W Max
AC Charging
1200W
11-60V, 15A, 500W max
Car Charging
Support 12V/24V battery, 8A
DC Charging
1100W
LFP (LiFePO4 battery)
Cycle life
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Dimension
27 lbs / 12 kg
Customer Reviews
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
Never miss a sale🎉
