EcoFlow RIVER 2 Max Solar Generator (PV160W) | EcoFlow South Africa
R 9,999.00 ZAR
Regular price R 9,999.00 ZAR
Sale price R 9,999.00 ZAR Regular price R 12,299.00
Save up to R 2,300
• Generates up to 1.2kWh daily.
• A 500W AC output.
• Lightweight and travel-friendly at 13.2 lbs.
• A high conversion rate guarantees a fast solar charging speed: 0-100% in 4 hours (1 set).
• LiFePO4 battery and IP68 dust and water resistance.
• Smart remote control with EcoFlow app.
• 5-year warranty for RIVER 2 Max and 24-month warranty for 160W Portable Solar Panel.
EcoFlow Solar Parallel Connection Cable
R 399 ZAR
R 399 ZAR
XT60 | XT60i
R 399 ZAR
R 399 ZAR
XT60 | XT60i
R 9,999 ZAR R 12,299 -R 2,300
Pay over 3 EQUAL zero-interest instalments of R 3,333.00 with PayJustNow.
Find out how...
Power. Never Been This Easy
Charge 0-100% in 1 Hour
Fastest charging speeds ever.
RIVER 2 Max beats the industry charging speed standard, fully charging in only 60 minutes. That's 5x faster than other portable power stations on the market and 38% quicker than previous generations. Fully charge RIVER 2 Max while you pack your bags, so you'll always be ready for a last-minute trip.
LiFePO4 Battery Chemistry
With upgraded long-lasting LFP battery chemistry at its core, charge and empty RIVER 2 Series over 3000 times. That's pretty much 10 years of everyday use1 and 6x longer than the industry average. With LFP cells, RIVER 2 Series is safe, durable, and highly efficient, even in warm temperatures.
5-year Warranty
Our state-of-the-art Battery Management System (BMS) constantly monitors the voltage, current, and temperature of RIVER 2 Series with multiple aspects of protection, extending its life to the max.2
4 Ways to Charge
Charge anywhere.
With 4 different ways to top up the RIVER 2 Series, there's a recharge option no matter what.3 From fast AC to in-car charging when you're on the go.
AC ChargingCar ChargingSolar ChargingUSB-C Charging
Why not harness renewable energy while you camp or head off on a trip? Plug in a couple of portable solar panels to fully recharge off-grid in as fast as 3 hours.
X-Boost Up to 1000W
Small size. Big power.
RIVER 2 Max has an AC output of up to 500W. Need to power a vacuum cleaner or sandwich maker? Crank it up to 1000W with X-Boost mode to run up to 80% of essential appliances.
Lightweight at only 6 kg
With a compact portable design, taking travel-friendly power off-grid has never been this easy. With a light-weight that's 22% lighter than the previous generation, RIVER 2 Max is ready to power all your outdoorsy escapades, from boondocking to BBQs at the beach.
<30ms EPS Auto-switch
Ultra-fast home backup switchover.
With a switchover speed of less than 30ms, you won't even know the power was down. Use RIVER 2 Series as an emergency power supply for overnight outages to keep essentials running from a light to your fish tank.
EcoFlow App
Control at your fingertips.
Use the EcoFlow app to control and monitor RIVER 2 Series, even from afar. View charging levels, customize settings, and adjust charging speeds, all from the convenience of your phone.
Power. Anywhere. Anytime.
1. RIVER 2 Max2. AC Charging Cable3. Car Charging Cable
4. DC5521 Connection Cable5. Quick Start Guide6. 160W Solar Panel7. Solar Charging Cable
*The solar charging cable is sent together with the solar panel.
512Wh
Approximately 6kg
270 x 260 x 196mm
AC Input
220-240V~ 50Hz/60Hz, 660W Max
Solar Input
11-50V 13A, 220W Max
Car Input
12V/24V, 8A, 100W Max
USB-C Input/Output
5/9/12/15/20V, 5A, 100W Max
DC Output
12.6V, 10A/3A/3A, 126W Max
5V, 2.4A, 12W Max
Pure Sine Wave, 500W total (surge 1000W), 230V ~ 50Hz/60Hz
Cell Chemistry
Discharge Temperature
-10°C to 45°C
Charge Temperature
0°C to 45°C
Optimal Operating Temperature
20°C to 30°C
Storage Temperature
-10°C to 45°C (20°C to 30°C is best)
DC5521 Output
13.6V, 3A, 36W Max
App Control
Wi-Fi, Bluetooth
1. Using RIVER 2 Max six times a week, 3000 full 100% cycles will last 9.6 years until it drops to 80%.
3. When charging and discharging at high wattage, RIVER 2 Max may make a noise up to 62db.
Customer Reviews
Based on 1 review
100%
(1)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
M
Matthew Dickason
Great product.
Granted, the unit only arrived today.
Ordered online on Sunday the 11th of August, arrived Friday the 16th. All packaging in perfect condition, all cables included. (I see on previous reviews on other products that the solar cable was not included, it's in cardboard that you could deam as packaging if you don't look and read)
WiFi and bluetooth connected in seconds. Firmware updated took less than 5 minutes.
Solar panels in perfect condition. A quick test charge and it's as fast as they say.
I'm looking forward to doing a full slow charge tomorrow and testing out the solar.
When I phoned today to double check on the solar charging cable the lady that answered the support call was amazing. In good spirits and we had a good laugh. She even double checked to ensure the cable was packed in.
Highly recommended so far, and judging from other reviews, ensure you know 100% what your power needs are and you will not be disappointed.
Thank you for the great service so far.
Kind regards
Matt
Never miss a sale🎉
