EcoFlow RIVER Portable Power Station | EcoFlow South Africa
R 3,999.00 ZAR
Video
Regular price R 3,999.00 ZAR
Sale price R 3,999.00 ZAR Regular price R 8,999.00
Save up to R 5,000
This portable power station is equipped with International standard plugs. Adapters will be needed to use the product.
  • 2 x 600w ac outlets and 288wh capacity
  • Recharge from 0% to 80% within 1 hour
  • Compatible with 80% home appliances
  • Fit your needs, now and later
Warning: To protect the battery please charge it through a surge protector plug. Due to high surges between load-shedding cycles the surge can damage the battery. To further protect the battery please do not keep the unit plugged in when power is scheduled to go back on.
Size
EcoFlow RIVER Bag
R 1,099 ZAR
R 4,299 ZAR R 6,999 ZAR
25% Conversion Rate
EcoFlow 220W Bifacial Portable Solar Panel
R 6,999 ZAR R 11,499 ZAR
23% Conversion Rate
R 3,999 ZAR R 8,999 -R 5,000
Pay over 3 EQUAL zero-interest instalments of R 1,333.00 with PayJustNow.
Find out how...
Hit the outdoors with RIVER and keep all your devices powered on at once. With a 288Wh capacity that charges to full in a record-breaking 96 minutes flat, you'll have ease of mind to focus on your adventures.
X-Stream Fast Charging
Power Multiple Devices
Portable
The world's fastest charging power stations
EcoFlow have the world's fastest charging power stations. RIVER charges from 0-80% in under an hour, or to full in 96 minutes flat.
The centerpiece of your adventure
Power up to 9 devices at once with all the ports you'll need. Sporting a 288Wh capacity, you'll have enough juice to charge your phone 21 times, triple your drone's charge, or make 12 cups of coffee with a coffee maker. Just don't drink them all at once
More power to you
EcoFlow's proprietary X-Boost technology is a game-changer. Switch it on to power high-wattage appliances up to a whopping 1800W. That's enough to power a hairdryer, a vacuum cleaner, or even a lawnmower.
Grab and go
With a sturdy handle on the top of the unit, RIVER is made for when you're on-the-go.
Title
Light 10W
Refrigerator 150W
Blender 300W
Television 110W
Projector 65W
Hair Dryer 1200W
Coffee Maker 1000W
Phone 11Wh
Macbook Air 49.9Wh
GoPro 7.7Wh
Switch 16Wh
Drone 60Wh
Electric Kettle 1200W
Electric Frying Pan 1200W
Rice Cooker 1000W
Solar charging
Harness the power of the sun by linking up to two 110W solar panels. You'll be fully charged in 1.6-3 hours.
Car charging
Heading on a road trip? Charge to full in just 3-hours by plugging right into your car with the car adapter.
Wall outlet
Plug into any standard AC wall outlet to fast charge from 0-80% in under 1 hour with X-Stream charging.
1. EcoFlow RIVER Portable Power Station 2. DC5521-DC5525 Cable 3. 1.5m AC Charging Cable 4. 1.5m Car Charging Cable 5. User Manual 6. Warranty Card
Each of the RIVER Series has its advantages. RIVER is ideal for lightweight, grab-and-go power, which you can expand with the extra battery. RIVER Max includes the extra battery by default, which you can remove to go lightweight. RIVER Pro is made for those that need even more capacity for off-grid, long haul adventures.
Yes. RIVER can power devices up to 1200W with our proprietary technology, X-Boost. *X-Boost can run devices that require up to 1200W, however, it's best to test before use. Some 600W-1200W appliances with strict voltage requirements may not function (eg. air compressors).
Yes. You can control RIVER using your phone. Just connect to the EcoFlow app to control from afar. Here's how: Step 1: Make sure the EcoFlow App is connected to RIVER. Step 2: Make sure RIVER is on. Step 3: Make sure your device's WiFi is turned on Step 4: Find your device in the app. Then, you can start controlling your RIVER remotely.
Yes. You can connect up to 2 sets of 110W solar panels to sustainably charge your RIVER in under 3 hours.
RIVER supports entry-level UPS functionality. Make sure to perform multiple tests to confirm compatibility before connecting devices such as data servers and workstations with RIVER.
Net Weight *
11 lbs (5kg)
Dimension *
11.3 x 7.3 x 7.7 in (28.8 x 18.5 x 19.4 cm)
Charge Temperature
32 to 113°F ± 5°F (0 to 45°C ± 3°C)
Discharge Temperature
-4 to 113°F ± 5°F (-20 to 45°C ± 3°C)
Color
Black
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel
Full Recharge Time
1.6 Hours (AC) 3 Hours (12V Car Adaptor) 1.6-3 Hours (Using 2x110W Solar Panels simultaneously with full sun) 2.4-4.8 Hours (Using 1x160W Solar Panel with full sun)
288Wh - 576Wh (With RIVER Extra Battery)
Cell Chemistry
Lithium-ion
500 Cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and certification
UL Standard CE FCC RoHS RCM
AC Charge Input Power
X-Stream Charge 250W max/500W Max (With RIVER Extra Battery)
AC Charge Input Voltage
220-240Vac(50Hz/60Hz)
Solar Charge Input
200W 10-25V DC 12A max
Car Charger
12V DC 8A max
AC Output (x2)
600W (Surge 1200W) total, 230Vac (50Hz/60Hz)
USB-A Output (x2)
5V DC,2.4A,12W Max, per port
USB-A Fast Charge (x1)
5V/2.4A,9V/2A,12V/1.5A 18W Max
USB-C Output (x1)
5V DC,9V DC,12V DC,15V DC,20V DC,5A,100W Max
Car Power Output (x1)
136W, 13.6V DC, 10A Max
DC5521 Output (x2)
13.6V DC, 3A Max, per port
The RIVER Extra Battery is sold separately.
Customer Reviews
Based on 109 reviews
83%
(90)
17%
(18)
0%
(0)
0%
(0)
1%
(1)
L
Leoni Gobey
Dont buy this product
It only lasted 3 years and they have no repair service (they have but they don't really repair) -- I have phoned multiple times - wrote mails - not worth the money
W
Wim Jansen
River
Excellent product.
Y
Yolandie van der Vyvet
River Portable Power Station
Excellent product. can recommend this product
C
Customer
The Ecoflow is great.
We got the ecoflow river it is a pity that it isn't compatable with South-african electrical points but my hasband made a plan with that. The battery also doesn't last as long as we expected. But othed than that we make it through the load shedding so we are happy. & planning on buying an extra battery
M
MelB
River review
Expectations were met. Thank you very much
Never miss a sale🎉
