EcoFlow RIVER Pro Portable Power Station (Refurbished)
R 2,999.00 ZAR
Step into the wild with a massive 720Wh of battery capacity. RIVER Pro is the powerhouse for your off-grid adventure. Keep multiple devices powered on at once and recharge in record times via car, solar, or standard AC outlets.
X-Stream Fast Charge
Expandable Capacity
X-Boost Output
Power Multiple Devices
EcoFlow has the world's fastest charging power stations. RIVER Pro charges from 0-80% in under an hour, or to full in 96 minutes.
Power up to 9 devices at once with all the ports you'll need.
Out for the long haul? Double RIVER Pro's capacity up to 1440Wh with an extra battery that links right to your unit.
EcoFlow's proprietary X-Boost technology is a game-changer. Switch it on to power high-wattage appliances up to a whopping 1800W. That's enough to power a hairdryer, a vacuum cleaner.
Three easy ways to charge
Harness the power of the sun by linking up to two 110W solar panels. You'll be fully charged in 4-8 hours.
Heading on a road trip? Charge to full in just 8 hours by plugging right into your car with the car adapter.
Plug into any standard AC wall outlet to fast charge from 0-80% in under 1 hour with X-Stream charging.
1. EcoFlow RIVER Pro Portable Power Station 2. DC5521-DC5525 Cable 3. 1.5m AC Charging Cable 4. 1.5m Car Charging Cable 5. User Manual 6. Warranty Card
16.8 lbs (7.6kg)
11.4 x 7.1 x 9.3in (28.9 x 18.0 x 23.5cm)
32 to 113°F ± 5°F (0 to 45°C ± 3°C)
-4 to 113°F ± 5°F (-20 to 45°C ± 3°C)
Black
24 months
AC Wall Outlet, 12V Car Adapter, Solar Panel(s)
1.6 Hours (AC) 8 Hours (12V Car Adapter) 4-8 Hours (Using 2x 110W Solar Panels in parallel with direct sunlight) 6-12 Hours (Using 1x 160W Solar Panel with direct sunlight)
720Wh (28.8V)
Lithium-ion
800 cycles to 80%+ capacity
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
UL Standard, CE, FCC, RoHS, RCM
X-Stream Charge 660W Max
220-240Vac (50Hz/60Hz)
200W 10-25Vdc 12A Max
12Vdc 8A Max
600W (Surge 1200W) total, 230Vac (50Hz/60Hz)
5Vdc, 2.4A, 12W Max per port
5V/2.4A,9V/2A,12V/1.5A 18W Max
5Vdc, 9Vdc, 12Vdc, 15Vdc, 20Vdc, 5A, 100W Max
136W, 13.6Vdc, 10A Max
13.6Vdc, 3A Max per port
Auto/Manual
2P
63A
1Sec
1,500 times
5kA
Single phase
50HZ/60HZ
AC 230V
-5℃~40℃
6,000 times
7.65kA
The RIVER Pro Extra Battery is sold separately.
*Note: EcoCredits are redeemable for gifts and discounts
Your preferences are saved.
We’ll personalize your experience from here.
