*Picture for reference only, subject to our available products.
*AC Plug Cable is needed to connect Power Station with Transfer Switch, and be provided by the electrician.
Step into the wild with a massive 720Wh of battery capacity. RIVER Pro is the powerhouse for your off-grid adventure. Keep multiple devices powered on at once and recharge in record times via car, solar, or standard AC outlets.
X-Stream Fast Charge
Expandable Capacity
X-Boost Output
Power Multiple Devices
The world's fastest charging power stations
EcoFlow has the world's fastest charging power stations. RIVER Pro charges from 0-80% in under an hour, or to full in 96 minutes.
The centerpiece of your adventure
Power up to 9 devices at once with all the ports you'll need.
Go further
Out for the long haul? Double RIVER Pro's capacity up to 1440Wh with an extra battery that links right to your unit.
More power to you
EcoFlow's proprietary X-Boost technology is a game-changer. Switch it on to power high-wattage appliances up to a whopping 1800W. That's enough to power a hairdryer, a vacuum cleaner.
Title
Light 10W
Refrigerator 150W
Blender 300W
Television 110W
Projector 65W
Hair Dryer 1200W
Coffee Maker 1000W
Phone 11Wh
Macbook Air 49.9Wh
GoPro 7.7Wh
Switch 16Wh
Drone 60Wh
Electric Kettle 1200W
Electric Frying Pan 1200W
Rice Cooker 1000W
Three easy ways to charge
Solar charging
Harness the power of the sun by linking up to two 110W solar panels. You'll be fully charged in 4-8 hours.
Car charging
Heading on a road trip? Charge to full in just 8 hours by plugging right into your car with the car adapter.
Wall outlet
Plug into any standard AC wall outlet to fast charge from 0-80% in under 1 hour with X-Stream charging.
1. EcoFlow RIVER Pro Portable Power Station 2. DC5521-DC5525 Cable 3. 1.5m AC Charging Cable 4. 1.5m Car Charging Cable 5. User Manual 6. Warranty Card
b.Capacity difference: SHP has two ports and can be connected to 2 groups of DP (each group of DP can be connected to 2*DP EB); TS can be connected to a group of DP or a whole group of Power hub+LFP.
c.Different cables: SHP uses EF's unique Infinity cable (Delta Pro ONLY); TS uses Generator cord;
d. SHP can only connect to DELTA Pro, Transfer Switch can connect to all power stations (if power is satisfied).
Net Weight *
16.8 lbs (7.6kg)
Dimensions *
11.4 x 7.1 x 9.3in (28.9 x 18.0 x 23.5cm)
Charge Temperature
32 to 113°F ± 5°F (0 to 45°C ± 3°C)
Discharge Temperature
-4 to 113°F ± 5°F (-20 to 45°C ± 3°C)
Color
Black
24 months
Charging Method
AC Wall Outlet, 12V Car Adapter, Solar Panel(s)
Full Recharge Time
1.6 Hours (AC) 8 Hours (12V Car Adapter) 4-8 Hours (Using 2x 110W Solar Panels in parallel with direct sunlight) 6-12 Hours (Using 1x 160W Solar Panel with direct sunlight)
720Wh (28.8V)
Cell Chemistry
Lithium-ion
800 cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and Certifications
UL Standard, CE, FCC, RoHS, RCM
AC Charge Input Power
X-Stream Charge 660W Max
AC Charge Input Voltage
220-240Vac (50Hz/60Hz)
Solar Charge Input
200W 10-25Vdc 12A Max
Car Charger
12Vdc 8A Max
AC Output (x2)
600W (Surge 1200W) total, 230Vac (50Hz/60Hz)
USB-A Output (x2)
5Vdc, 2.4A, 12W Max per port
USB-A Fast Charge (x1)
5V/2.4A,9V/2A,12V/1.5A 18W Max
USB-C Output (x1)
5Vdc, 9Vdc, 12Vdc, 15Vdc, 20Vdc, 5A, 100W Max
Car Power Output (x1)
136W, 13.6Vdc, 10A Max
DC5521 Output (x2)
13.6Vdc, 3A Max per port
Specs of Transfer Switch
Operation Mode
Auto/Manual
Poles
2P
Rated Current
63A
Transfer Time
1Sec
Electrical Life
1,500 times
Short-circuit switching (breaking) capacity
5kA
Phase
Single phase
Operating Frequency
50HZ/60HZ
Rated Voltage
AC 230V
Operating Temperature
-5℃~40℃
Mechanical Life
6,000 times
Short-circuit switching (making) capacity
7.65kA
The RIVER Pro Extra Battery is sold separately.
- Choosing a selection results in a full page refresh.
- Press the space key then arrow keys to make a selection.
Subscribe to our emails and receive a free camping package with your first order over R5,000
Your Camping Gift Package is unlocked in your inbox.
Sign Up For EcoFlow text updates and offers
Thank you for signing up for our text messages!
*Note: EcoCredits can be redeemed for discounts and gifts. Learn More
