EcoFlow RIVER Pro Solar Generator (PV160W) | EcoFlow South Africa
R 11,999.00 ZAR
☃️Winter Sale
Regular price R 11,999.00 ZAR
Sale price R 11,999.00 ZAR Regular price R 21,998.00
Save up to R 9,999
Up to EcoCredits for cash deduction
This portable power station is equipped with South African standard plugs.
Portable electricity Your very own mobile power source for up to 9 devices. Leverage 720Wh with RIVER Pro’s selection of AC outlets, USB slots and DC ports. Weighing in at just 7.6kg, you can easily take it with you when you’re on the go.
Industry-leading recharge speeds Charge in record time with our X-Stream tech. Recharge RIVER Pro’s battery from 0-80% in less than an hour and to 100% in 1.6 hours.
Double up on capacity Link up a RIVER Pro Extra Battery to take your capacity from 720Wh to 1440Wh. A great backup option to power larger appliances such as fridge freezers.
More output with X-Boost Out the box, RIVER Pro sports a 600W output. By switching on X-Boost mode, you can supply devices up to 1800W. That covers almost all home essentials, power tools and appliances.
Products
EcoFlow RIVER Bag
R 1,099 ZAR
EcoFlow RIVER Bag
R 1,099 ZAR
R 11,999 ZAR R 21,998 -R 9,999
Pay over 3 EQUAL zero-interest instalments of R 3,999.66 with PayJustNow.
Find out how...
The centerpiece of your adventure
Power up to 9 devices at once with all the ports you'll need.
So Much More Sun
Premium monocrystalline silicon cells provide a high conversion efficiency of 21-22%. Recharge even faster by chaining multiple panels in a series or in parallel.
Better Together
Recharge freely and naturally when you link EcoFlow's 160W Solar Panel to a RIVER Pro portable power station.
Yes. You can control RIVER Pro using your phone. Just link to it in the EcoFlow app to control it from afar.
Yes. RIVER Pro can power devices up to 1800W with our proprietary technology, X-Boost. *X-Boost can run devices that require up to 1800W, however, it's best to test before use. Some 600W–1800W appliances with strict voltage requirements may not function (e.g. air compressors).
It can be an emergency power source (EPS), which will have the same result as UPS for most electronics. Here's the difference. When your RIVER Pro is plugged into the wall, anything plugged into it gets power from the grid, not its battery. If power from the grid stops, RIVER Pro automatically switches to its battery supply mode within 30 milliseconds. That means anything connected will not have power for 30 milliseconds, which may mean sensitive electronics like desktop computers and data servers turn off. Test your devices individually to see if they need UPS to stay powered.
Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
Yes, if the only thing between it and the sun is transparent, but it won't charge as well compared to being outside. You can compare the difference by looking at the input section of your power station's LCD screen.
What's in the bundle
1. EcoFlow RIVER Pro Portable Power Station 2. DC5521-DC5525 Cable 3. Solar to XT60 Charging Cable 4. 1.5m AC Charging Cable 5. 1.5m Car Charging Cable 6. User Manual 7. Warranty Card 8. 160W Solar Panel 9. 160W Solar Panel Bag 10. 160W Solar Panel User Manual
Net Weight *
16.8 lbs (7.6kg)
Dimensions *
11.4 x 7.1 x 9.3in (28.9 x 18.0 x 23.5cm)
Charge Temperature
32 to 113°F ± 5°F (0 to 45°C ± 3°C)
Discharge Temperature
-4 to 113°F ± 5°F (-20 to 45°C ± 3°C)
24 months
Charging Method
AC Wall Outlet, 12V Car Adapter, Solar Panel(s)
Full Recharge Time
1.6 Hours (AC) 8 Hours (12V Car Charger)
6-12 Hours (Using 1x 160W Solar Panel)
720Wh (28.8V)
Cell Chemistry
Lithium-ion
800 cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and Certifications
UL Standard, CE, FCC, RoHS, RCM
AC Charge Input Power
X-Stream Charge 660W Max
AC Charge Input Voltage
220-240Vac (50Hz/60Hz)
Solar Charge Input
200W 10-25Vdc 12A Max
Car Charger
12Vdc 8A Max
AC Output (x2)
600W (Surge 1200W) total, 230Vac (50Hz/60Hz)
USB-A Output (x2)
5Vdc, 2.4A, 12W Max per port
USB-A Fast Charge (x1)
5V/2.4A,9V/2A,12V/1.5A 18W Max
USB-C Output (x1)
5Vdc, 9Vdc, 12Vdc, 15Vdc, 20Vdc, 5A, 100W Max
Car Power Output (x1)
136W, 13.6Vdc, 10A Max
DC5521 Output (x2)
13.6Vdc, 3A Max per port
Customer Reviews
Based on 18 reviews
100%
(18)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
M
Mike Lambert
Meets expectations
Very happy with the product. It was easy to follow the instructions and use. It lives up to the claims made in the product's advertisement.
P
Paul
EcoFlow River Pro
A great product at a good price
S
Sheehan
Great for car camping and emergencies
Thus far- great performance, easy to use. Use case: extended car camping, home emergency. Worked well and quick charging for headlamps and other camp lighting with internal rechargeable batteries or aa/aaa etc. Able to recharge phones, bluetooth speaker, and keep everything topped off and running at peak. Allowed us to stay in camp enjoy the peace and solitude without having to turn the car on to recharge, or go through a ton of batteries. Already paying for itself. Solar charging of the unit was easy and quick as well. Very quiet- can't tell it's on. Easy to use interface and set up is very clear right from the start.
A
Anon907
Fantastic Product
Top of the line and fantastic product. The fast charge is the best on the market and from my experience over the last few months using this product almost every day, it holds true. My ONLY gripe with this product is the lack of dust cover plugs on the unit. I've had to source those through 3rd parties. You could completely get rid of the hinged cover for the solar plug(s) for removable dust covers and would allow you plug in the according connector and still maintain a sealed unit. The lack of dust covers is constantly worrying as I keep this unit outside and exposed to the elements in order to charge. Now that I have those covers though, it will outlast any normal unit without them for sure. Would be a great addition to newer models or even if you just include a bag of assorted dust covers with the sale of future units.
A
Anthony P Jakob III
Rocks!
So far so great! I charged 2 shimano ep8 ebikes in the field. Thought I would need the booster battery, and still might, but so far so good.
Never miss a sale🎉
