EcoFlow 110W Portable Solar Panel – EcoFlow South Africa website
R 6,199.00 ZAR
Regular price R 6,199.00 ZAR
Sale price R 6,199.00 ZAR Regular price R 6,199.00
-R 0
• Portable and lightweight
• Up to 23% conversion rate
• Self-supporting
• One-piece folding design
Size
EcoFlow Solar Extension Cable
R 399 ZAR
R 499 ZAR
XT60 | XT60i
R 399 ZAR
R 499 ZAR
XT60 | XT60i
R 6,199 ZAR
Get off the grid with EcoFlow's 110W Solar Panel for renewable energy wherever you end up.
Universal
Seamless
Foldable
Portable
Powerfully portable
With an industry-leading 23% conversion rate, it's far lighter and approx. 10% smaller than similar portable solar panels on the market. That means a faster, easier charge wherever you are.
Self-supportable
Take it camping, on a road trip or in your backyard with a case that doubles as a stand. Unzip and prop up your panel at just the right angle to ensure maximum solar coverage.
Waterproof & Durable
Designed to withstand your adventurous lifestyle, this panel is IP68 certified. That means we dunked it underwater for 72hrs in lab conditions. Just to make sure*. Built with a high-strength composite, it can take a beating too. That's an all-weather ready panel designed to stand the test of time.
* Water and dust resistance were tested under controlled laboratory conditions with a rating of IP68 under IEC standard 60529 (maximum water depth of 1 meter for up to 72 hours.)
It comes with a carry case too.
On the go? Keep your panel folded up and protected while you hit the road. Save valuable trunk space and go easy knowing your panel is safe. Once you arrive, simply unfold, prop up and start generating clean, green electricity.
1.110W Solar Panel 2.110W Solar Panel Bag 3. Solar to XT60 Charging Cable 4. User Manual
Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
Yes, if the only thing between it and the sun is transparent, but it won't charge as well compared to being outside. You can compare the difference by looking at the input section of your power station's LCD screen.
Unfolded Dimensions
178.5 × 42.0 × 2.5 cm
Folded Dimensions
42.0 × 48.0 × 2.5 cm
Weight
6 kg (Solar Panel 4 kg)
12 months
Rated Power
110W (±5W)
Efficiency
22%–23%
Open Circuit Voltage
21.8V (Vmp 18.4V)
Short Circuit Current
6.5A (Imp 6.0A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−20°C to 85°C
Customer Reviews
Based on 58 reviews
88%
(51)
12%
(7)
0%
(0)
0%
(0)
0%
(0)
A
Amoré Nel
Haven't been able to test it yet for review
I didn't know it doesn't include a cable to connect to power station
P
Paul 241
110W solar panel
Easy to carry. Easy to set up. Easy to connect Works great
J
JohnP
Excellent Product
As expected a little smaller than my 160 Watt panel I got with my generator but the two connected together will work fine. VERY impressed with Ecoflow and would highly recommend them for your back up power needs. Works so well we're considering Solar for our house.
M
Mary B
Would have given 5 stars but order was not complet
Perfect except that I ordered the suction cups as well as the parallel MC4 connector and did not receive them
W
Walt H.
Met the expectations -new.
Just ordered second set of panels for charging a battery generator and perfirmance is as advertised. Panels seem rugged enough, design to keep them up correctly might need some work, but funtional.
Never miss a sale🎉
Save Up to 47% | Black Friday Sale
Stay ahead of the crowd on Black Friday deals and surprises!
Browse the Black Friday Sale
Thanks for subscribing!
We will notify you in advance of any latest information regarding Black Friday Sale.
