EcoFlow DELTA Max Portable Power Station | EcoFlow South Africa
R 24,999.00 ZAR
Video
Regular price R 24,999.00 ZAR
Sale price R 24,999.00 ZAR Regular price R 44,999.00
Save up to R 24,498
Up to EcoCredits for cash deduction
This portable power station is equipped with International standard plugs. Adapters will be needed to use the product.
Level up with the EcoFlow PowerStream Balcony Solar System:
Pair with an EcoFlow PowerStream Microinverter and gain a grid-tied solar energy solution that powers your home day and night.
• 2-6kWh expandable capacity for home backup
• Power heavy-duty devices with 2400W output
• Charge 0-80% in just 65 minutes
• Solar charge in as fast as 2.5 hours
• Up to 3400W fast dual charging
• Smart app control
Model
EcoFlow DELTA Max Cover
R 1,699 ZAR
R 14,999 ZAR R 20,999 ZAR
23% Conversion Rate
EcoFlow Smart Plug
R 499 ZAR
Wi-Fi-Operated Plug
EcoFlow 400W Rigid Solar Panel
R 8,999 ZAR R 10,999 ZAR
23% Conversion Rate
EcoFlow Super Flat Cable
R 499 ZAR
R 499 ZAR
EcoFlow Smart Plug
R 499 ZAR
Wi-Fi-Operated Plug
23% Conversion Rate
R 1,699 ZAR
23% Conversion Rate
R 1,699 ZAR
R 24,999 ZAR R 44,999 -R 20,000
Pay over 3 EQUAL zero-interest instalments of R 8,333.00 with PayJustNow.
Find out how...
A transfer switch is a device that switches a load between Grid Power and Backup Power, simply connect EcoFlow Portable Power Station to your main panel via a Transfer Switch for instant home backup (Transfer Time 1~2s).
*Picture for reference only, subject to our available products.
*AC Plug Cable is needed to connect Power Station with Transfer Switch, and be provided by the electrician.
Learn more about how to backup your home with our Portable Power Station and Transfer Switch: Whole-Home Backup Kit User Guide
Expandable Capacity
Dual Charging
Power multiple devices
800W max Solar Input
Expandable home backup power.
DELTA Max charges up safely and rapidly from 0-80% in just 1 hour. And it gets even better. If you're looking for an even faster way to charge up DELTA Max, you can combine AC with the Smart Generator, AC with solar, or the Smart Generator with solar.
With EcoFlow's X-Boost technology, DELTA Max can power heavy-duty devices up to 3000W. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That's the industry gold standard for a portable power station of this size and capacity.
Harness the power of the sun.
DELTA Max connects with up to 2x 400W EcoFlow solar panels to deliver 800W Max solar charging speeds. With a voltage range from 11-100V and the solar connector, you can also connect other solar panels to your DELTA Max. Even during cold or cloudy days, our smart maximum power point tracking (MPPT) algorithm automatically detects voltage and current in real time to give you optimum solar generation throughout the day.
Emergency backup power.
Multiple ways to charge.
1.DELTA Max 2.AC Charging Cable 3.Car Charging Cable 4.DC5521 to DC5525 cable 5.User Manual
It depends on the total voltage and watts of solar panels you choose. As long as the solar panels use MC4 connector and its voltage and current are under 11-100V, 13A max range.
When charging DELTA Max and its extra battery together, you can reach 3600W max charging speeds by combining any two methods of AC, solar and Smart Generator. For DELTA Max single unit, you can recharge it at standard wall outlets (1800W max), or combine AC and solar charging to reach max 2000W charging speeds.
When your portable power station is plugged into the wall, any electronics plugged into it are powered from the grid and not its battery. When power from the grid stops, as in a blackout, the power station automatically switches to battery power within 30ms.
DELTA Max is not water-resistant, so it should be kept away from liquids. Or if you're looking for water-resistance solution, you can purchase the DELTA Max case to water-resistance protection.
The EcoFlow transfer switch comes with a 1-year warranty.
There are wiring diagrams and a how-to video of the installation and operating instructions for reference.
Firstly, installation of the transfer switch should be done by a licensed electrician or a qualified professional who will issue you a Certificate of Compliance (COC) afterward so that the insurance company won't repudiate any electrical-linked claims in the future. Secondly, to avoid the unit tripping out, you can discuss with your electrician which circuits or appliances should be excluded based on your electricity consumption and the power station capacity you own, such as the stove, geyser, and pool pump. Last, be aware of putting the transfer switch into a box to prevent electric shock. It is only viable with indoor circuit breaker panels.
Generally, the installation costs include labour, traveling, cabling, protection box, and COC. It varies with many factors like traveling distance and the length of cable. The exact installation cost will need to be estimated by an electrician based on the specifics of your home's electrical circuits. We highly recommend that you source different electricians and get comparative quotes.
We have authorized some qualified installers in most of Johannesburg and Cape Town. Please contact us Monday to Friday, 8:30 a.m. to 5 p.m. GMT+2 at +27 80 088 0002 (toll-free) or support.za@ecoflow.com for more information. If you live elsewhere or aren't satisfied with the installation price, you can also go to our Facebook community and leave your question. There are many enthusiastic EcoFlow users who can help you.
Installation of the transfer switch should be done by a licensed electrician or a qualified professional.
EcoFlow Portable Power Stations have safety mechanisms to prevent overloads. And it's also crucial to exclude high-power appliances or circuits.
The transfer time is about 1 second. This transfer time may seem long, but it actually provides two important benefits. Firstly, it helps to prevent voltage surges that could otherwise harm your household appliances during sudden power fluctuations, which is crucial for protecting your appliances. Secondly, this transfer time is crucial for our products' longevity and safe operation.
a.Transfer Switch is divided into MTS and ATS, MTS is a manual switch, ATS is an automatic switch; SHP is an automatic smart switch, which can monitor the power consumption of each open circuit and control it remotely at the same time;Understand the situation of each line more accurately
b.Capacity difference: SHP has two ports and can be connected to 2 groups of DP (each group of DP can be connected to 2*DP EB); TS can be connected to a group of DP or a whole group of Power hub+LFP.
c.Different cables: SHP uses EF's unique Infinity cable (Delta Pro ONLY); TS uses Generator cord;
d. SHP can only connect to DELTA Pro, Transfer Switch can connect to all power stations (if power is satisfied).
Specs of DELTA Max (2000)
Approx. 48 lbs (22 kg)
Dimension
19.6 x 9.5 x 12 in (49.7 x 24.2 x 30.5 cm)
Charge Temperature
32 to 113°F (0 to 45°C)
Discharge Temperature
-4 to 113°F (-20 to 45°C)
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel, Smart Generator, Smart Extra Battery
Full Recharge Time
1.6 Hours (AC) 21 Hours (12V Car Charger) 5.6-11.2 Hours (Using 4x 110W Solar Panels) 4.2-8.4 Hours (Using 4x 160W Solar Panels) 3.2-6.3 Hours (Using 2x 400W Solar Panels)
2016Wh
Cell Chemistry
NCM
Cycle life
800 cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and Certification
CE WEEE CTP RCM KC
AC Charge Input (Power)
X-Stream charge (2000W max)
AC Charge Input (Voltage and Amperage)
220-240V~50Hz/60Hz, 10A
Solar Charge Input
11-100V 13A Max, 800W max
Car Charge Input
Supports 12V/24V Battery, Default 8A
AC Output (x4)
Pure Sine Wave, 2400W total (surge 4600W), 230V~ (50Hz/60Hz)
3000W
USB-A Output (x2)
5V 2.4A, 12W max, per port
USB-A Fast Charge (x2)
5V/2.4A, 9V/2A, 12V/1.5A, 18W Max
USB-C Output (x2)
5/9/12/15/20V 5A, 100W max
Car Charger Output (x1)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Smart Extra Battery
Supports up to 2 DELTA Max Smart Extra Batteries (sold separately)
Smart Generator
Supported (sold separately)
Wi-Fi
Supported
Specs of DELTA Max (1600)
Dimension
Charge Temperature
24 months
Charge Method
Full Recharge Time
1.6 Hours (AC) 16.8 Hours (12V Car Charger) 4.5-9 Hours (Using 4x 110W Solar Panels) 3.4-6.8 Hours (Using 4x 160W Solar Panels) 2.5-5 Hours (Using 2x 400W Solar Panels)
1612Wh
Cell Chemistry
NCM
Cycle life
500 Cycles to 80%+ capacity
Management Systems
CE WEEE CTP RCM KC
X-Stream charge (1600W max)
Solar Charge Input
Car Charge Input
AC Output (x4)
Pure Sine Wave, 2000W total (surge 4600W), 230V~ (50Hz/60Hz)
2500W
USB-A Output (x2)
USB-C Output (x2)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Smart Extra Battery
Smart Generator
Wi-Fi
Supported
Specs of Transfer Switch
Operation Mode
Auto/Manual
Poles
2P
Rated Current
63A
Transfer Time
1Sec
Electrical Life
1,500 times
Short-circuit switching (breaking) capacity
5kA
Phase
Single phase
Operating Frequency
50HZ/60HZ
Rated Voltage
AC 230V
Operating Temperature
-5℃~40℃
Mechanical Life
6,000 times
Short-circuit switching (making) capacity
7.65kA
Car charger shares power with the DC5521 output port offering maximum output of 126W.
Whether the product can be charged or discharged depends on the actual temperature of the battery pack
DELTA Max (2000) needs to be connected to the DELTA Max Smart Extra Battery for dual charging.
Customer Reviews
Based on 195 reviews
86%
(168)
13%
(26)
0%
(0)
0%
(0)
1%
(1)
R
Riaan Hollenbach
Worst Delivery and customer experience of all time!
I have bought a Delta2 and portable PV panel bundle more than a week ago. I have received an email the following day confirming my bundle has been handed over to the courier. A few days later only the portable PV panel was delivered. I tried to follow up via the email address provided as I was concerned that my entire order has not been delivered. I only received a generic automated response from Ecoflow. I then tried to contact the courier company who confirmed they would get back to me. I am still waiting for that phone call. I then followed up with Ecoflow again, who assured me they will have the problem solved, and that the Delta 2 will be delivered separately. I have from then followed up with Ecoflow and the courier company daily with zero results. Today marks a week and a day since I have placed my order with NO Delta2 Delivered. It is extremely concerning that buy a product in excess of R35k on an online purchase and you are never sure where your parcel is. I have bought items for R30 online and have been kept informed on the whereabouts of my parcel the entire route. It is shocking that you pay this kind of money, and there is almost ZERO after sales support from Ecoflow! If this is the kind of support given just to get the parcel delivered then I have major concerns with technical support in the future. I am on the brink of cancelling my order and buying from a supplier that actually cares about their customers and do not merely rely on the name of the product they sell to keep them in business. Customer retention lies in the relationship you cultivate, not merely in the product.
R
Riaan Hollenbach
Y
Yusuf Jacobs
How to buy
There is a store where you can view the products at Canal Walk in Cape Town, not sure about other locations. I was there this last Friday. But to purchase you have to buy from the EcoFlow online store.
I
If the product is so good as claimed,why dont they have a sales outlet already?
How to buy?
How can it be bought?
M
Marnus Prinsloo
Delta Max 1600 - South African customer
Out of the box the product does what is says. I have used it mainly on a camping trip thus far. I camp with a Jurgens Penta, the Delta max runs EVERYTHING we have in the caravan. It runs my 55l camping fridge, it runs the main fridge, all lights, no problem starting and running the microwave. If you switch off some items it has no problem starting up and running my 12000btu Jetair inverter aircon. Charging the unit form the 220v really is as fast as advertised.
The only criticism I have on the unit is really from a South African point of view. The AC outlets is not the standard south african 3 prong plugs. It is universal plug which means you need to go and buy universal plug adapters to run SA plugs. At the price you are paying for this unit one would have expected this to be sold market ready.
Never miss a sale🎉
