EcoFlow DELTA Max Solar Generator (PV220W) | EcoFlow South Africa
R 21,999.00 ZAR
Regular price R 21,999.00 ZAR
Sale price R 21,999.00 ZAR Regular price R 50,999.00
Save up to R 31,000
DELTA Max(2000)/(1600) has been discontinued. Discover the next-generation DELTA 2 Max here>>
This portable power station is equipped with International standard plugs. Adapters will be sent together with the product.
Home emergency power: DELTA Max expands up to 6kWh with smart extra batteries, keeping your home powered on in any emergency.
Rapid dual charging: Charge up from 0-80% in 1 hour. Or get up to 3600W speeds by combining AC charging and the EcoFlow Smart Generator.
Power multiple devices: Looking for something to power heavy-duty devices like your fridge and dryer? With X-Boost, DELTA Max handles devices up to 3000W with ease.
Portable solar generator: Stay powered on no matter what. DELTA Max connects with up to 4x 220W EcoFlow solar panels to deliver fast solar charging speeds.
Model
R 21,999 ZAR R 50,999 -R 29,000
Pay over 3 EQUAL zero-interest instalments of R 7,333.00 with PayJustNow.
Find out how...
Payment method
Payment method
Payment method
Payment method
Expandable Capacity
Dual Charging
800W max Solar Input
With EcoFlow's X-Boost technology, DELTA Max can power heavy-duty devices up to 3000W. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That's the industry gold standard for a portable power station of this size and capacity.
Harness the power of the sun.
DELTA Max connects with up to 4x 220W EcoFlow solar panels to deliver fast solar charging speeds. With a voltage range from 11-100V and the solar connector, you can also connect other solar panels to your DELTA Max. Even during cold or cloudy days, our smart maximum power point tracking (MPPT) algorithm automatically detects voltage and current in real time to give you optimum solar generation throughout the day.
What's in the bundle - DELTA Max
1.DELTA Max 2.AC Charging Cable 3.Car Charging Cable 4.DC5521 to DC5525 cable 5.User Manual
What's in the bundle - 220W Solar Panel
1. 220W Bifacial Solar Panel 2. 220W Bifacial Solar Panel Protective Case (Kickstand) 3. Solar to XT60 Charging Cable 4. 220W Bifacial Solar Panel User Manual and Warranty Card 4. Snap Hooks
It depends on the total voltage and watts of solar panels you choose. As long as the solar panels use solaire connector and its voltage and current are under 11-100V, 13A max range.
When charging DELTA Max and its extra battery together, you can reach 3600W max charging speeds by combining any two methods of AC, solar and Smart Generator. For DELTA Max single unit, you can recharge it at standard wall outlets (1800W max), or combine AC and solar charging to reach max 2000W charging speeds.
When your portable power station is plugged into the wall, any electronics plugged into it are powered from the grid and not its battery. When power from the grid stops, as in a blackout, the power station automatically switches to battery power within 30ms.
DELTA Max is not water-resistant, so it should be kept away from liquids. Or if you're looking for water-resistance solution, you can purchase the DELTA Max case to water-resistance protection.
Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
Yes, if the only thing between it and the sun is transparent, but it won't charge as well compared to being outside. You can compare the difference by looking at the input section of your power station's LCD screen.
Specs of DELTA Max (2000)
Approx. 48 lbs (22 kg)
Dimension
19.6 x 9.5 x 12 in (49.7 x 24.2 x 30.5 cm)
Charge Temperature
32 to 113°F (0 to 45°C)
Discharge Temperature
-4 to 113°F (-20 to 45°C)
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel, Smart Generator, Smart Extra Battery
Full Recharge Time
1.6 Hours (AC)
21 Hours (12V Car Charger)
1 x 220W panel : 11.5-23 hrs
2 x 220W panels : 5.5-11 hrs
3 x 220W panels : 3.5-7 hrs
4 x 220W panels : 2.5-5 hrs
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
2016Wh
Cell Chemistry
NCM
Cycle life
800 cycles to 80%+ capacity
Testing and Certification
CE WEEE CTP RCM KC
AC Charge Input (Power)
X-Stream charge (2000W max)
AC Charge Input (Voltage and Amperage)
220-240V~50Hz/60Hz, 10A
Solar Charge Input
11-100V 13A Max, 800W max
Car Charge Input
Supports 12V/24V Battery, Default 8A
AC Output (x4)
Pure Sine Wave, 2400W total (surge 4600W), 230V~ (50Hz/60Hz)
3000W
USB-A Output (x2)
5V 2.4A, 12W max, per port
USB-A Fast Charge (x2)
5V/2.4A, 9V/2A, 12V/1.5A, 18W Max
USB-C Output (x2)
5/9/12/15/20V 5A, 100W max
Car Charger Output (x1)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Smart Extra Battery
Supports up to 2 DELTA Max Smart Extra Batteries (sold separately)
Smart Generator
Supported (sold separately)
Wi-Fi
Supported
Specs of DELTA Max (1600)
Dimension
Charge Temperature
24 months
Charge Method
Full Recharge Time
1.6 Hours (AC)
16.8 Hours (12V Car Charger)
1 x 220W panel : 9-18 hrs
2 x 220W panels : 4.5-9 hrs
3 x 220W panels : 3-6 hrs
4 x 220W panels : 2-4 hrs
1612Wh
Cell Chemistry
NCM
Cycle life
500 Cycles to 80%+ capacity
Management Systems
CE WEEE CTP RCM KC
X-Stream charge (1600W max)
Solar Charge Input
Car Charge Input
AC Output (x4)
Pure Sine Wave, 2000W total (surge 4600W), 230V~ (50Hz/60Hz)
2500W
USB-A Output (x2)
USB-C Output (x2)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Smart Extra Battery
Smart Generator
Wi-Fi
Supported
Specs of 220W Solar Panel
Rated Power
220W Front Side/155W Rear Side
Cell Type
Monocrystalline Silicon
Efficiency
22-23%
82*183*2.5cm (32.3*72.0*1.0 in)
Open Circuit Voltage
21.8V (Vmp 18.4V)
Short Circuit Current
13A (Imp 12.0A) Front Side/ 8.8A (Imp8.4A) Rear Side
Weight (Solar Panel)
Approx. 9.5kg (20.9lbs)
Car charger shares power with the DC5521 output port offering maximum output of 126W.
Whether the product can be charged or discharged depends on the actual temperature of the battery pack
DELTA Max (2000) needs to be connected to the DELTA Max Smart Extra Battery for dual charging.
Never miss a sale🎉
