EcoFlow DELTA Pro Portable Power Station | EcoFlow South Africa
R 59,999.00 ZAR
Video
Regular price R 59,999.00 ZAR
Sale price R 59,999.00 ZAR Regular price R 59,999.00
This product is equipped with European standard plugs. Adapters will be needed to use the product.
• Recharge your RV and EV anytime, anywhere
R1000 OFF
CODE: DPadapter
Style
EcoFlow DELTA Pro Bag
R 1,799 ZAR
EV X-Stream Adapter (EcoFlow DELTA Pro)
R 2,199 ZAR
R 2,199 ZAR
R 1,799 ZAR
R 2,199 ZAR
R 59,999 ZAR
Pay over 3 EQUAL zero-interest instalments of R 19,999.66 with PayJustNow.
Find out how...
Power for any situation.
All the AC output you’ll need.
A single DELTA Pro unit packs a 3600W AC output, which can be expanded up to 4500W with X-Boost technology. Power 99.99% heavy-duty devices at home, outdoors, or at work. You can even pair two units together to achieve 7200W.
Works in Sync with EcoFlow PowerStream Balcony Solar System
Transform your power station into a grid-tied solar energy solution that combines solar panels, a power station, and a microinverter. Power your home and save on energy bills day and night.
Learn More
Smart home battery ecosystem.
DELTA Pro's expandable ecosystem provides you with uninterrupted power during blackouts, customizable smart energy around the clock for critical loads, and lower energy bills.
Prepare your home for power outages.
When a blackout hits, the Smart Home Panel immediately switches to your 10 integrated circuits and draws power from your DELTA Pro(s). You'll barely notice a loss of power as your chosen circuits stay powered with a mere 20ms switchover time.
Expand capacity and output.
The Smart Home Panel supports and fast charges up to two DELTA Pro(s) at a time, alongside their extra batteries + smart generator(s). That gives you a potential 7200W output and 25kWh of capacity at your control, enough to power pretty much anything in your home, delivering days of power during blackouts.
Smart energy management.
Control each of your integrated home circuits via the EcoFlow app and get a birds-eye view of your energy consumption habits. Dive into the settings to customize your power use. You can optimize for home backup, saving money, or custom options to schedule your energy use based on your needs. Once you're set, you can even control which power source your house uses, all from your phone.
Draw power from your DELTA Pro(s) to power your home during peak energy use hours, this lowers your bills and reduces pressure on the grid during peak hours. During off-peak hours, use low-cost/renewable energy to charge your DELTA Pro(s) back to full.
Reduce your reliance on the grid and prepare for blackouts. Opt for EcoFlow's range of portable solar panels to store energy at any time, or charge from your AC coupled rooftop solar panels while the grid is on-line. No sun? We're working on a wind turbine. No sun or wind? Charge via the grid. No sun, no wind, and a blackout hits? You're still good. Lean on the EcoFlow Smart Generator as a last resort to charge your batteries.
Travel without limits.
Connect DELTA Pro with an Extra Battery for a huge capacity of 7.2kWh, and stay powered for up to a week*. Run daily essentials such as a fridge, laptop, coffee maker, and even the air conditioner. You'll have the power to experience all that nature has to offer.
EV backup charging solution.
Power that means business.
Unleash your creativity.
Take energy on the go and get the creative juices flowing. Whether you're a filmmaker capturing precious moments or just want to work on the go, DELTA Pro's impressive output and large capacity can power all your equipment, ensuring a smooth workflow no matter where you are.
1. DELTA Pro 2. AC Charging Cable 3. Car Charging Cable 4. DC5521 to DC5525 cable 5. Handle Cover 6. User Manual
*EcoFlow DELTA Pro to Smart Generator Adapter (sold separately) is necessary when the DELTA Pro is connected to the Smart Generator.
What's the max input DELTA Pro can achieve?
When charging DELTA Pro and its extra battery together, you can reach 6500W max charging speeds by combining AC, solar and Smart Generator methods. For DELTA Pro single unit, you can recharge it at standard wall outlets (2900W max), at EV station (3400W max)/Smart Home Panel (3000W max).
How many solar panels can I use at the same time?
It depends on the combined voltage and current of the solar panels you choose. It's fine as long as the solar panels use solar connectors and their combined voltage and current are within 11-150 volts and under 15 amps.
How do I update the firmware?
First of all, make sure your DELTA Pro is connected to the EcoFlow App using Internet mode. Secondly, go to the Firmware section in the Setting of the DELTA Pro you're looking to upgrade. Check for the latest firmware and follow the steps to finish the upgrade.
Approx. 99lbs/45kg
Dimension
3600Wh
Extra Battery
4500W
4500W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
Anderson Port
12.6V, 30A
AC Charging Input
2900W Max, 230V~12.5A
Solar Charging Input
1600W Max, 11-150V, 15A
Car Charging Input
Support 12V/24V battery, 8A
Connection
Wi-Fi, Bluetooth
Customer Reviews
Based on 294 reviews
93%
(273)
7%
(20)
0%
(1)
0%
(0)
0%
(0)
S
Salome Masetla
Lack of information from Ecoflow to SA
I’m in SA. Had to buy the SA matching plugs to connect the ecoflow. I’m now concerned if I’ll be able to connect my main switch to ecoflow if I buy the delta pros. Ecoflow is not giving enough information. SA is not just concerned about saving electricity but more frustrated about daily power cuts. I want to buy more but I’m not sure what I’m buying or how I will install it. Who are the registered electricians who know how to install the product in SA? etc
G
George Ivanisevic
The Delta pro is Amazing and yes its everything and more
I had a generator connected to my house , all the plugs the lights , fridges x 2 (one freezer sand up ) and fridge , two Led Tvs 75" and 65 " my wifi and about 60 x 5 watt globes !!!!!!
Here's the magic the Delta pro runs it all and says it gives me about 5 hours of use. I boiled a kettle (3000 watts ) no extra boost the unit handled it while everything else was on , boiled perfectly and afterwards still gave about the same time left . I was concerned about run time and if it could handle the kettle my coffee machine etc but it's fantastic. Im including a pic , this was after the kettle boil and running for 1hour 20 minutes
J
Janet Burr
Ecoflow
No mention is make about the make of Ecoflow and secondly no mention is made about time - how many hours will 3600W last for?
G
Goodwill Sibanyoni
Excellent 👌
I gave the ecoflow a 99%, very excellent job
P
Pieta Geyser
Delta Pro
RSA Customers should be supplied with adapters.
Seriously consider an alternative to Buffalo carriers.They are not doing good to Ecoflow's reputation
Never miss a sale🎉
