EcoFlow DELTA Pro Solar Generator (PV400W) | EcoFlow South Africa
R 53,999.00 ZAR
Regular price R 53,999.00 ZAR
Sale price R 53,999.00 ZAR Regular price R 68,499.00
Save up to R 14,500
This plug is equipped with European standard plugs. Adapters will be needed to use the product.
The solar to XT60 charging cable is excluded in EcoFlow rigid solar panels. Buy Now
The world's fastest charging portable power station DELTA Pro can charge via one of 6 methods. It is the first that can be charged from an EV station, and can even Multicharge by combining methods to achieve a rapid 6500W charge. That's the industry gold standard.
The portable home battery DELTA Pro sports a 3.6kWh capacity that can be expanded all the way to 25kWh. You can integrate it directly with your home circuits via the Smart Home Panel. Ideal for home backup.
Power pretty much anything DELTA Pro leads the industry when it comes to AC output. With 3600W you can power heavy-duty appliances such as dryers, AC units and more. Need even more power? Pair two units together to hit a massive 7200W with Smart Home Panel. Learn more about DELTA Pro >>
Fast Solar Panel Recharging The DELTA can be fully recharged from three EF 400W Solar Panels in 4-8 hours, depending on sunlight conditions.
Self-supporting The protective case conveniently turns into a stand that adjusts from 40-90° allowing the solar panels to capture the most raysLearn more about 400W Solar Panel >>
Size
EcoFlow Solar Extension Cable
R 399 ZAR
EcoFlow Solar to XT60i Charging Cable
R 399 ZAR
XT60 | XT60i
Rigid Solar Panel Mounting Feet
R 299 ZAR
Suction Cups for Solar Panel
R 599 ZAR
R 53,999 ZAR R 68,499 -R 14,500
Pay over 3 EQUAL zero-interest instalments of R 17,999.66 with PayJustNow.
Find out how...
Introducing the world's first portable home battery with an expandable ecosystem for home backup, smart energy management, lower energy bills, and more. The EcoFlow DELTA Pro is the next leap in portable power technology, offering you power security and independence, wherever you are.
Expandable Capacity
Power Pretty Much Anything (3600W-7200W Output)
World's Fastest Charging (MultiCharge 6500W)
Home Integration
What's in the box - DELTA Pro
1.DELTA Pro 2.AC Charging Cable 3.Car Charging Cable 4.DC5521 to DC5525 cable 5.Handle Cover 6.User Manual
What's in the Box - 400W Solar Panel
1. 400W Solar Panel 2. Kickstand Case 3. User Manual
When charging DELTA Pro and its extra battery together, you can reach 6500W max charging speeds by combining AC, solar and Smart Generator methods. For DELTA Pro single unit, you can recharge it at standard wall outlets (2900W max), at EV station (3400W max)/Smart Home Panel (3000W max).
It depends on the combined voltage and current of the solar panels you choose. It's fine as long as the solar panels use MC4 connectors and their combined voltage and current are within 11-150 volts and under 15 amps.
First of all, make sure your DELTA Pro is connected to the EcoFlow App using Internet mode. Secondly, go to the Firmware section in the Setting of the DELTA Pro you're looking to upgrade. Check for the latest firmware and follow the steps to finish the upgrade.
Specs of DELTA Pro
Approx. 99lbs/45kg
Dimension
3600Wh
Extra Battery
4500W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
Anderson Port
12.6V, 30A
AC Charging Input
2300W Max, 230V~10A eb
Solar Charging Input
1600W Max, 11-150V, 15A
Car Charging Input
Support 12V/24V battery, 8A
Connection
Wi-Fi, Bluetooth, wired
Specs of 400W Solar Panel
Rated Power
400W
Cell Type
Monocrystalline silicon
Efficiency
22.40%
41.7*93.1*1.0 in (105.8*236.5*2.4cm)
Connector Type
MC4
Open Circuit Voltage
48V (Vmp 41V)
Short Circuit Current
11A (Imp 9.8A)
Weight(Solar Panel)
Approx. 27.6lbs (12.5Kg)
Weight (with Kickstand Case)
34.2lbs / 15.5kg
Customer Reviews
Based on 5 reviews
80%
(4)
0%
(0)
0%
(0)
0%
(0)
D
David Tabb
After more than two months' experience with our Delta Pro and 400W solar panel, we are very grateful to have purchased the combo. The solar panel, in particular, offers very impressive efficiency; we have been able to "refill" our Delta Pro from 70% up to 100% in a morning session of charging. The Delta Pro capacity is particularly useful when Eskom takes us to level 6 load-shedding, when we have been able to power our refrigerator overnight without a thought (it places a maximum load of 90W on the inverter when the compressor is running). I can power my research workstation for a twelve-hour compute session at full load without worry. We have begun shifting toward powering our laptops via USB-C rather than AC plugs when possible to avoid turning on the inverter. I would point to some minor criticisms: 1) Our Delta Pro came with Type G / USA combo AC plugs rather than ZA plugs; we compensated by purchasing a ZA plug adapter with fuse to accommodate our refrigerator. 2) Our Delta Pro came with an American charging cable; we substituted a heavy-duty ZA cable with standard kettle plug. 3) The firmware installed on our Delta Pro was pretty old, preventing me from connecting my phone via Bluetooth; we were able to update it by connecting the Delta Pro to our home wifi.
C
Customer
Owner of a companey
Very wel
J
John S.
So far so good! I ran a deep freeze and a water pump for a few days with just the solar panel for recharge. When there were no clouds, the input was more than the output. I plan on running my office with the Delta Pro and have installed a lockout and 30 amp plug on my breaker panel for emergencies. If a problem arises, I will post again. God Bless!
N
Not powerful enough
Great but not enough power runs out and can’t power small air conditioner
W
Wal2022
System works as described. Solid. Heavy (very). Panels are great quality. Heavy. Wish they had a better/easier way to angle the panels. Using the panel cover is a little wonky. The panels don't stay completely flat when you angle them because of the folding joints. Learned that 800 W of panels doesn't mean you will get that. Happy to get 680. Angle with sun is critical for optimum power generation but impossible to continuously achieve without the ridiculously expensive holder that automatically rotates and follows the sun. Still love the system.
Never miss a sale🎉
