This portable power station is equipped with South African standard plugs.
EcoFlow DELTA Power Station represents the new standard of battery-powered generators. Compatible with a wide range of devices, you can stay powered for hours whenever and wherever.
The World’s Fastest Charging Power Station Charges at 2 to 3 times the speed of most portable power stations in the market. 0—80% in under one hour.
Power Almost Anything DELTA’s large inverter load can even support heavy-duty DIY tools up to 1800W (3300W Surge, Pure Sine Wave). That makes it the best portable power station at this size for output.
Power 11 Devices At Once All the ports you’d ever need for your gear. Power up to 11 devices all at the same time via AC, DC or USB outlets. Ideal as a battery generator for blackouts.
Fast Solar Panel Recharging The DELTA can be fully recharged from three EF 160W Solar Panels in 3-7 hours, depending on sunlight conditions. An MC4 to XT60 Solar Cable is included.
Intelligent Solar Power The EcoFlow 160W Solar Panel is designed to produce maximum power at any time of the day when paired with an EcoFlow power station. The solar panel has a high conversion efficiency of 21-22%, and the EcoFlow MPPT power station algorithm delivers improved performance in cold and cloudy environments within the operation range.
Customer reviews
5 star
4 star
3 star
2 star
1 star
The world's fastest charging portable power stations
EcoFlow have the world's fastest charging power stations. DELTA charges from 0-80% in under an hour, giving you a quick boost of power even during the worst situations.
So Much More Sun
Premium monocrystalline silicon cells provide a high conversion efficiency of 21-22%. Recharge even faster by chaining multiple panels in a series or in parallel.
Better Together
Recharge freely and naturally when you link EcoFlow's 160W Solar Panel to a DELTA portable power station.
What's in the bundle
1. EcoFlow DELTA 2. DELTA Bag 3.Solar Panel Charging Cable 4. 1.5m AC Charging Cable 5. 1.5m Car Charging Cable 6. User Manual of DELTA 7. 160W Solar Panel 8. 160W Solar Panel Bag 9. User Manual of 160W Solar Panel
30.9lbs (14kg)
Dimension
15.7 x 8.3 x 10.6 in (40 x 21 x 27 cm)
Charge Temperature
32 to 113°F (0 to 45°C)
Discharge Temperature
-4 to 113°F (-20 to 45°C)
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel
Full Recharge Time
1.6 Hours (AC) 13.5 Hours (12V Car Charger)10.5-21 Hours (Using 1x 160W Solar Panel)5-10 Hours (Using 2x 160W Solar Panels)3.5-7 Hours (Using 3x 160W Solar Panels)
1260Wh (50.4V)
Cell Chemistry
Lithium-ion
Life Span
800 Cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection.
Testing and certification
UL CE FCC RoHS PSE
Cell Type
18650
AC Charge Input Power
X-Stream charge (1200W max)
AC Charge Input Voltage
220-240Vac
Solar Charge Input
400W 10-65V DC 10A max
Car Charger
12V/24V DC 8A max
AC Output (x4)
1800W (Surge 3300W) total, 230ac (50Hz)
USB-A Output (x2)
5V DC, 2.4A, 12W Max, per port
USB-A Fast Charge (x2)
5V/2.4A,9V/2A,12V/1.5A 18W Max, per port
USB-C Output (x2)
5V DC, 9V DC, 15V DC, 20V DC, 3A, 60W Max, per port
Car Power Output (x1)
108.8W, 13.6V DC, 8A max
