EcoFlow DELTA Pro 3 Smart Extra Battery | EcoFlow ZA – EcoFlow South Africa
Regular price R 40,703.00 ZAR
Sale price R 40,703.00 ZAR Regular price R 52,999.00
Save up to R 12,296
  • Compatibility – Works seamlessly with EcoFlow DELTA Pro 3 (The EcoFlow DELTA Pro Smart Extra Battery is compatible with the EcoFlow DELTA Pro 3.)
  • Scalable Power – Expandable up to 12kWh for increased capacity.
  • Long-Lasting Battery – LFP battery with 4000 life cycles to 80% capacity.
  • Easy to Use – Plug-and-play design for straightforward operation.
  • Stackable Design – Perfect for home or indoor power backup applications.
Style
R 40,703 ZAR R 52,999 -R 12,296
Pay over 3 EQUAL zero-interest instalments of R 13,567.66 with PayJustNow.
Find out how...
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Payment method
Plug and Play
The smart extra batteries are easy to connect with the main unit of EcoFlow DELTA Pro 3.
Enjoy a seamless, plug-and-play setup. The compact and portable design adds
convenience to your power management.
Explore the Secure Feeling EcoFlow Brings to You
Built with state-of-the-art automotive-grade LFP cells for safe and reliable service. Our
strong 5-year warranty ensures peace of mind.
Energize Every Moment That Needs Electricity
Power almost all your essential home appliances with the robust 4000W and 230V capabilities of a
single unit. Add extra batteries to extend the convenience even further.
Off-grid
RV
Jobsite
Effortless All-in-One Command With the EcoFlow App
0 Ms Downtime, 0 dB Silent BackupControl and monitor your home's power remotely with ease using the EcoFlow app. Track
every watt and customize your power usage for optimal efficiency.
What's In The Box?
4096Wh
Output Port
40V-58.4V=100A Max
Weight
33 kg
Compatible with
EcoFlow DELTA Pro 3
Discharge Temperature
-10°C ~ 45°C
Storage Temperature
-10°C ~ 45°C
Charge Temperature
0°C ~ 45°C
Input Port
40V-58.4V=80A Max
Dimension
694mm×295mm×215mm
Dispaly
LED Array
What’s in the box
1. EcoFlow Delta Pro 3 Smart Extra Battery
2. Quick Start Guide
3. Safety Guide
4. Warranty Card
5. EcoFlow Extra Battery Cable
Is the EcoFlow DELTA Pro Smart Extra Battery compatible with the EcoFlow DELTA Pro 3?
Yes, supported. Please note that all devices need to be upgraded to the latest firmware version to ensure compatibility.
Can the EcoFlow DELTA Pro 3 Smart Extra Battery and the EcoFlow DELTA Pro Smart Extra Battery be mixed and plugged into the EcoFlow DELTA Pro 3?
Supported. However, due to the different capacities of the EcoFlow DELTA Pro Extra Battery and the EcoFlow DELTA Pro 3 Extra Battery, there will be some SOC imbalance.
Never miss a sale🎉
