Relay Module (Smart Home Panel) | EcoFlow South Africa
R 599.00 ZAR
🔥Black Friday
Regular price R 599.00 ZAR
Sale price R 599.00 ZAR Regular price R 599.00
Variety is key. Plug up to 10 household circuits using the Smart Home Panel for household backup, with different current ratings for different connected loads.
Simple installation. It's easy to install and replace relay modules. We do advise you to consult your electrician and evaluate your backup loads first.
Switch over without affecting other circuits. Each module has two modules and an overcurrent protection fuse for each circuit. That means you can switch one out without affecting the other circuits. If you need to change a relay module, the EcoFlow app and the on-unit LED will inform you of any faults.
Model
R 599 ZAR
Pay over 3 EQUAL zero-interest instalments of R 199.66 with PayJustNow.
Find out how...
How to Choose
-Load planning: With a Smart Home Panel, selective loads are installed where they will be the most effective during power outages or energy savings management. Consider areas that would significantly affect comfort, such as refrigerator and lights, and choose the maximum of 10 selective loads from your breaker panel based on their efficiency in load.
-Collect the load info: Determine the number and current rating of the load circuits that you plan to connect. Consult your electrician if you need support with this.
-Determine the relay modules needed: Choose the relay module that matches the current rating for the circuit breaker upstream of that load circuit. Recommended relay modules for regions: 13A, 16A for EU.
How to Install
1. Relay Module (Smart Home Panel)
Customer Reviews
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
Never miss a sale🎉
