EcoFlow RIVER Pro Portable Power Station
R 16,098.00 ZAR
Hot
Video
Hot
Regular price R 16,098.00 ZAR
Sale price R 16,098.00 ZAR Regular price R 16,098.00
The RIVER Pro has been discontinued. We recommend the RIVER 2 Max (512Wh, 500W output) as a suitable alternative.
This portable power station is equipped with South African standard plugs.
• 2 x 600W AC OUTLETS AND 720Wh CAPACITY
• RECHARGE FROM 0-80% WITHIN 1 HOUR
• DOUBLE CAPACITY FROM 720Wh to 1440Wh
• POWER A WIDE RANGE OF APPLIANCES
Warning: To protect the battery please charge it through a surge protector plug. Due to high surges between load-shedding cycles the surge can damage the battery. To further protect the battery please do not keep the unit plugged in when power is scheduled to go back on.
Style
EcoFlow RIVER Bag
R 1,099 ZAR
R 399 ZAR
XT60 | XT60i
EcoFlow RIVER Bag
R 1,099 ZAR
R 16,098 ZAR
Pay over 3 EQUAL zero-interest instalments of R 5,366.00 with PayJustNow.
Find out how...
Payment method
Payment method
Payment method
Payment method
A transfer switch is a device that switches a load between Grid Power and Backup Power, simply connect EcoFlow Portable Power Station to your main panel via a Transfer Switch for instant home backup (Transfer Time 1~2s).
*Picture for reference only, subject to our available products.
*AC Plug Cable is needed to connect Power Station with Transfer Switch, and be provided by the electrician.
Learn more about how to backup your home with our Portable Power Station and Transfer Switch: Whole-Home Backup Kit User Guide
Step into the wild with a massive 720Wh of battery capacity. RIVER Pro is the powerhouse for your off-grid adventure. Keep multiple devices powered on at once and recharge in record times via car, solar, or standard AC outlets.
X-Stream Fast Charge
Expandable Capacity
X-Boost Output
Power Multiple Devices
The world's fastest charging power stations
EcoFlow has the world's fastest charging power stations. RIVER Pro charges from 0-80% in under an hour, or to full in 96 minutes.
The centerpiece of your adventure
Power up to 9 devices at once with all the ports you'll need.
Go further
Out for the long haul? Double RIVER Pro's capacity up to 1440Wh with an extra battery that links right to your unit.
More power to you
EcoFlow's proprietary X-Boost technology is a game-changer. Switch it on to power high-wattage appliances up to a whopping 1800W. That's enough to power a hairdryer, a vacuum cleaner.
Title
Light 10W
Refrigerator 150W
Blender 300W
Television 110W
Projector 65W
Hair Dryer 1200W
Coffee Maker 1000W
Phone 11Wh
Macbook Air 49.9Wh
GoPro 7.7Wh
Switch 16Wh
Drone 60Wh
Electric Kettle 1200W
Electric Frying Pan 1200W
Rice Cooker 1000W
Solar charging
Harness the power of the sun by linking up to two 110W solar panels. You'll be fully charged in 4-8 hours.
Car charging
Heading on a road trip? Charge to full in just 8 hours by plugging right into your car with the car adapter.
Wall outlet
Plug into any standard AC wall outlet to fast charge from 0-80% in under 1 hour with X-Stream charging.
1. EcoFlow RIVER Pro Portable Power Station 2. DC5521-DC5525 Cable 3. 1.5m AC Charging Cable 4. 1.5m Car Charging Cable 5. User Manual 6. Warranty Card
Each of the RIVER Series has its advantages. RIVER is ideal for lightweight, grab-and-go power, which you can expand with the extra battery. RIVER Max includes the extra battery by default, which you can remove to go lightweight. RIVER Pro is made for those that need even more capacity for off-grid, long haul adventures.
Yes. You can control RIVER Pro using your phone. Just link to it in the EcoFlow app to control it from afar.
Yes. RIVER Pro can power devices up to 1800W with our proprietary technology, X-Boost. *X-Boost can run devices that require up to 1800W, however, it's best to test before use. Some 600W-1800W appliances with strict voltage requirements may not function (e.g. air compressors).
Yes. You can connect up to 2 sets of 110W solar panels to sustainably charge your RIVER Pro in under 3 hours.
It can be an emergency power source (EPS), which will have the same result as UPS for most electronics. Here's the difference. When your RIVER Pro is plugged into the wall, anything plugged into it gets power from the grid, not its battery. If power from the grid stops, RIVER Pro automatically switches to its battery supply mode within 30 milliseconds. That means anything connected will not have power for 30 milliseconds, which may mean sensitive electronics like desktop computers and data servers turn off. Test your devices individually to see if they need UPS to stay powered.
The EcoFlow transfer switch comes with a 1-year warranty.
There are wiring diagrams and a how-to video of the installation and operating instructions for reference.
Firstly, installation of the transfer switch should be done by a licensed electrician or a qualified professional who will issue you a Certificate of Compliance (COC) afterward so that the insurance company won't repudiate any electrical-linked claims in the future. Secondly, to avoid the unit tripping out, you can discuss with your electrician which circuits or appliances should be excluded based on your electricity consumption and the power station capacity you own, such as the stove, geyser, and pool pump. Last, be aware of putting the transfer switch into a box to prevent electric shock. It is only viable with indoor circuit breaker panels.
Generally, the installation costs include labour, traveling, cabling, protection box, and COC. It varies with many factors like traveling distance and the length of cable. The exact installation cost will need to be estimated by an electrician based on the specifics of your home's electrical circuits. We highly recommend that you source different electricians and get comparative quotes.
We have authorized some qualified installers in most of Johannesburg and Cape Town. Please contact us Monday to Friday, 8:30 a.m. to 5 p.m. GMT+2 at +27 80 088 0002 (toll-free) or support.za@ecoflow.com for more information. If you live elsewhere or aren't satisfied with the installation price, you can also go to our Facebook community and leave your question. There are many enthusiastic EcoFlow users who can help you.
Installation of the transfer switch should be done by a licensed electrician or a qualified professional.
EcoFlow Portable Power Stations have safety mechanisms to prevent overloads. And it's also crucial to exclude high-power appliances or circuits.
The transfer time is about 1 second. This transfer time may seem long, but it actually provides two important benefits. Firstly, it helps to prevent voltage surges that could otherwise harm your household appliances during sudden power fluctuations, which is crucial for protecting your appliances. Secondly, this transfer time is crucial for our products' longevity and safe operation.
a.Transfer Switch is divided into MTS and ATS, MTS is a manual switch, ATS is an automatic switch; SHP is an automatic smart switch, which can monitor the power consumption of each open circuit and control it remotely at the same time;Understand the situation of each line more accurately
b.Capacity difference: SHP has two ports and can be connected to 2 groups of DP (each group of DP can be connected to 2*DP EB); TS can be connected to a group of DP or a whole group of Power hub+LFP.
c.Different cables: SHP uses EF's unique Infinity cable (Delta Pro ONLY); TS uses Generator cord;
d. SHP can only connect to DELTA Pro, Transfer Switch can connect to all power stations (if power is satisfied).
Net Weight *
16.8 lbs (7.6kg)
Dimensions *
11.4 x 7.1 x 9.3in (28.9 x 18.0 x 23.5cm)
Charge Temperature
32 to 113°F ± 5°F (0 to 45°C ± 3°C)
Discharge Temperature
-4 to 113°F ± 5°F (-20 to 45°C ± 3°C)
Color
Black
24 months
Charging Method
AC Wall Outlet, 12V Car Adapter, Solar Panel(s)
Full Recharge Time
1.6 Hours (AC) 8 Hours (12V Car Adapter) 4-8 Hours (Using 2x 110W Solar Panels in parallel with direct sunlight) 6-12 Hours (Using 1x 160W Solar Panel with direct sunlight)
720Wh (28.8V)
Cell Chemistry
Lithium-ion
800 cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and Certifications
UL Standard, CE, FCC, RoHS, RCM
AC Charge Input Power
X-Stream Charge 660W Max
AC Charge Input Voltage
220-240Vac (50Hz/60Hz)
Solar Charge Input
200W 10-25Vdc 12A Max
Car Charger
12Vdc 8A Max
AC Output (x2)
600W (Surge 1200W) total, 230Vac (50Hz/60Hz)
USB-A Output (x2)
5Vdc, 2.4A, 12W Max per port
USB-A Fast Charge (x1)
5V/2.4A,9V/2A,12V/1.5A 18W Max
USB-C Output (x1)
5Vdc, 9Vdc, 12Vdc, 15Vdc, 20Vdc, 5A, 100W Max
Car Power Output (x1)
136W, 13.6Vdc, 10A Max
DC5521 Output (x2)
13.6Vdc, 3A Max per port
Specs of Transfer Switch
Operation Mode
Auto/Manual
Poles
2P
Rated Current
63A
Transfer Time
1Sec
Electrical Life
1,500 times
Short-circuit switching (breaking) capacity
5kA
Phase
Single phase
Operating Frequency
50HZ/60HZ
Rated Voltage
AC 230V
Operating Temperature
-5℃~40℃
Mechanical Life
6,000 times
Short-circuit switching (making) capacity
7.65kA
The RIVER Pro Extra Battery is sold separately.
Never miss a sale🎉
