EcoFlow RIVER Pro Solar Generator (PV110W) | EcoFlow South Africa
Regular price
Sale price Regular price
Save up to R 2,808
This portable power station is equipped with South African standard plugs.
VERSATILE‌ ‌& ‌LIGHT‌‌ ‌It's‌ ‌‌portable‌ ‌electricity‌‌ ‌for‌ ‌your‌ ‌essential‌ ‌devices;‌ ‌nine‌ ‌at‌ ‌a‌ ‌time‌ ‌if‌ ‌you‌ ‌want.‌ ‌Draw‌ ‌720Wh‌ ‌through‌ ‌RIVER‌ ‌Pro’s‌ ‌wall‌ ‌outlets,‌ ‌USB‌ ‌outlets,‌ ‌and‌ ‌DC‌ ‌outlets,‌ ‌and‌ ‌at‌ ‌just‌ ‌7.6‌ ‌kg,‌ ‌it’s‌ ‌one‌ ‌of‌ ‌the‌ ‌‌best‌ ‌portable‌ ‌power‌ ‌supply‌ ‌alternatives‌ ‌for‌ ‌camping,‌ ‌off-grid‌‌ ‌living,‌ ‌and‌ ‌professional‌ ‌work.‌ ‌
WORLD’S‌ ‌FASTEST‌ ‌RECHARGE‌ ‌‌Our‌ ‌patented‌ ‌X-Stream‌ ‌feature‌ ‌takes‌ ‌RIVER‌ ‌Pro’s‌ ‌battery‌ ‌from‌ ‌0–80%‌ ‌within‌ ‌one‌ ‌hour‌ ‌and‌ ‌fully‌ ‌charged‌ ‌in‌ ‌just‌ ‌1.6‌ ‌hours.‌ ‌
OPT‌ ‌FOR‌ ‌DOUBLE‌ ‌CAPACITY‌ ‌‌Add‌ ‌a‌ ‌RIVER‌ ‌Pro‌ ‌Extra‌ ‌Battery‌ ‌to‌ ‌double‌ ‌the‌ ‌capacity‌ ‌to‌ ‌1440Wh.‌ ‌This‌ ‌makes‌ ‌it‌ ‌a‌ ‌great‌ ‌‌backup‌ ‌power‌ ‌supply‌‌ ‌for‌ ‌refrigerators‌ ‌‌or‌ ‌as‌ ‌part‌ ‌of‌ ‌an‌ ‌‌off-grid‌ ‌power‌ ‌system‌.‌ ‌
HIGHER‌ ‌OUTPUT‌ ‌‌With‌ ‌X-Boost‌ ‌enabled,‌ ‌RIVER‌ ‌Pro’s‌ ‌600W‌ ‌output‌ ‌can‌ ‌power some devices up to ‌1800W.‌ ‌That’s‌ enough‌ ‌for‌ ‌80%‌ ‌of‌ ‌devices,‌ ‌tools,‌ ‌and‌ ‌appliances,‌ ‌though‌ ‌it‌ ‌works‌ ‌mostly‌ ‌as‌ ‌a‌ ‌safety‌ ‌net.‌
UPGRADE HIGH EFFICIENCY Compared with other solar panels, the chainable feature enables you to chain solar panels together with the parallel cable which gives you ample power for your power station; ( 4x110W Solar Panels in parallel for DELTA, 2x110W Solar Panels in parallel for RIVER)
    PORTABLE & FOLDABLE KICKSTAND PANEL Designed with a rubber handle and flexible bracket stand, our solar panel can be used to adjust the angle from 0-45 degrees.
      WATERPROOF & DURABLE The solar panel is waterproof to endure all weather conditions, ideal for outdoor activities.
      Product
      EcoFlow Solar Parallel Connection Cable
      R 399 ZAR
      EcoFlow Solar Extension Cable
      R 399 ZAR
      EcoFlow RIVER Bag
      R 1,099 ZAR
      R 399 ZAR
      R 399 ZAR
      EcoFlow RIVER Bag
      R 1,099 ZAR
      Pay over 3 EQUAL zero-interest instalments of R 0.00 with PayJustNow.
      Find out how...
      Payment method
      Payment method
      Payment method
      Payment method
      The centerpiece of your adventure
      Power up to 9 devices at once with all the ports you'll need.
      So Much More Sun
      Premium monocrystalline silicon cells provide a high conversion efficiency of 21-22%. Recharge even faster by chaining multiple panels in a series or in parallel.
      Better Together
      Recharge freely and naturally when you link EcoFlow's 110W Solar Panel to a RIVER Pro portable power station.
      Yes. You can control RIVER Pro using your phone. Just link to it in the EcoFlow app to control it from afar.
      Yes. RIVER Pro can power devices up to 1800W with our proprietary technology, X-Boost. *X-Boost can run devices that require up to 1800W, however, it's best to test before use. Some 600W–1800W appliances with strict voltage requirements may not function (e.g. air compressors).
      It can be an emergency power source (EPS), which will have the same result as UPS for most electronics. Here's the difference. When your RIVER Pro is plugged into the wall, anything plugged into it gets power from the grid, not its battery. If power from the grid stops, RIVER Pro automatically switches to its battery supply mode within 30 milliseconds. That means anything connected will not have power for 30 milliseconds, which may mean sensitive electronics like desktop computers and data servers turn off. Test your devices individually to see if they need UPS to stay powered.
      Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
      Yes, if the only thing between it and the sun is transparent, but it won't charge as well compared to being outside. You can compare the difference by looking at the input section of your power station's LCD screen.
      What's in the bundle
      1. EcoFlow RIVER Pro Portable Power Station 2. DC5521-DC5525 Cable 3. Solar to XT60 Charging Cable 4. 1.5m AC Charging Cable 5. 1.5m Car Charging Cable 6. User Manual 7. Warranty Card 8. 110W Solar Panel 9. 110W Solar Panel Bag 10. 110W Solar Panel User Manual
      Net Weight *
      16.8 lbs (7.6kg)
      Dimensions *
      11.4 x 7.1 x 9.3in (28.9 x 18.0 x 23.5cm)
      Charge Temperature
      32 to 113°F ± 5°F (0 to 45°C ± 3°C)
      Discharge Temperature
      -4 to 113°F ± 5°F (-20 to 45°C ± 3°C)
      24 months
      Charging Method
      AC Wall Outlet, 12V Car Adapter, Solar Panel(s)
      Full Recharge Time
      1.6 Hours (AC) 8 Hours (12V Car Charger)
      9-18 Hours (Using 1x 110W Solar Panel)
      4-8 Hours (Using 2x 110W Solar Panels, in parallel)
      720Wh (28.8V)
      Cell Chemistry
      Lithium-ion
      800 cycles to 80%+ capacity
      Management Systems
      BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
      Testing and Certifications
      UL Standard, CE, FCC, RoHS, RCM
      AC Charge Input Power
      X-Stream Charge 660W Max
      AC Charge Input Voltage
      220-240Vac (50Hz/60Hz)
      Solar Charge Input
      200W 10-25Vdc 12A Max
      Car Charger
      12Vdc 8A Max
      AC Output (x2)
      600W (Surge 1200W) total, 230Vac (50Hz/60Hz)
      USB-A Output (x2)
      5Vdc, 2.4A, 12W Max per port
      USB-A Fast Charge (x1)
      5V/2.4A,9V/2A,12V/1.5A 18W Max
      USB-C Output (x1)
      5Vdc, 9Vdc, 12Vdc, 15Vdc, 20Vdc, 5A, 100W Max
      Car Power Output (x1)
      136W, 13.6Vdc, 10A Max
      DC5521 Output (x2)
      13.6Vdc, 3A Max per port
      Never miss a sale🎉
