EcoFlow DELTA Max Solar Generator (PV400W) | EcoFlow South Africa
R 20,999.00 ZAR
Regular price R 20,999.00 ZAR
Sale price R 20,999.00 ZAR Regular price R 42,499.00
Save up to R 39,999
DELTA Max(2000)/(1600) has been discontinued. Discover the next-generation DELTA 2 Max here>>
This portable power station is equipped with International standard plugs. Adapters will be sent together with the product.
The solar to XT60 charging cable is excluded in EcoFlow rigid solar panels. Buy Now
Home emergency power DELTA Max expands up to 6kWh with smart extra batteries, keeping your home powered on in any emergency.
Rapid dual charging Charge up from 0-80% in 65 minutes. Or get up to 3400W speeds by combining AC charging and the EcoFlow Smart Generator.
Power multiple devices Looking for something to power heavy-duty devices like your fridge and dryer? With X-Boost, DELTA Max handles devices up to 3400W with ease.
Learn more about DELTA Max >>
Fast Solar Panel Recharging The DELTA Max can be fully recharged from two EF 400W Solar Panels in 2.5-5 hours, depending on sunlight conditions. An MC4 to XT60 Solar Cable is included.
Smart Solar Energy The EcoFlow 400W solar panel has a conversion efficiency of 22.4%, and when paired with an EcoFlow portable solar generator, can extract the most power throughout the day. The solar generator adjusts its efficiency using the Maximum Power Point Tracking (MPPT) algorithm, to deliver a constant power supply.
Self-supporting The protective case conveniently turns into a stand that adjusts from 40-90° allowing the solar panels to capture the most rays.
Learn more about 400W Portable Solar Panel >>
Learn more about 400W Rigid Solar Panel >>
Model
R 399 ZAR
XT60 | XT60i
EcoFlow DELTA Max Cover
R 1,699 ZAR
R 399 ZAR
XT60 | XT60i
R 1,699 ZAR
R 1,699 ZAR
Rigid Solar Panel Mounting Feet
R 299 ZAR
R 1,699 ZAR
R 20,999 ZAR R 42,499 -R 21,500
Pay over 3 EQUAL zero-interest instalments of R 6,999.66 with PayJustNow.
Find out how...
Payment method
Payment method
Payment method
Payment method
Expandable Capacity
Dual Charging
Power Multiple Devices
Solar Power
Expandable home backup power.
DELTA Max charges up safely and rapidly from 0-80% in just 65 minutes. And it gets even better. If you're looking for an even faster way to charge up DELTA Max, you can combine AC with the smart generator to get up to 3600W, AC with solar to get up to 2600W, or the Smart Generator with solar to get up to 2600W.
With EcoFlow's X-Boost technology, DELTA Max can power heavy-duty devices up to 3400W. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That's the industry gold standard for a portable power station of this size and capacity.
Harness the power of the sun.
DELTA Max connects with up to 2x 400W EcoFlow solar panels to deliver 800W Max solar charging speeds. With a voltage range from 11-100V and the MC4 connector, you can also connect other solar panels to your DELTA Max. Even during cold or cloudy days, our smart maximum power point tracking (MPPT) algorithm automatically detects voltage and current in real time to give you optimum solar generation throughout the day.
Emergency backup power.
Multiple ways to charge.
It depends on the total voltage and watts of solar panels you choose. As long as the solar panels use MC4 connector and its voltage and current are under 11-100V, 10A max range.
When charging DELTA Max and its extra battery together, you can reach 3600W max charging speeds by combining any two methods of AC, solar and Smart Generator. For DELTA Max single unit, you can recharge it at standard wall outlets (1800W max), or combine AC and solar charging to reach max 2000W charging speeds.
When your portable power station is plugged into the wall, any electronics plugged into it are powered from the grid and not its battery. When power from the grid stops, as in a blackout, the power station automatically switches to battery power within 30ms.
DELTA Max is not water-resistance, so it should be kept away from liquids. Or if you're looking for water-resistance solution, you can purchase the DELTA Max case to water-resistance protection.
Specs of DELTA Max (2000)
2016Wh
Extra Battery
Support up to two DELTA Max Smart Extra Battery/Smart Generator
AC Output (x4)
Pure Sine Wave, 2400W total (surge 4600W), 230V~ (50Hz/60Hz)
3000W
USB-A Output (x2)
5V 2.4A, 12W max, per port
USB-A Fast Charge (x2)
5V/2.4A, 9V/2A, 12V/1.5A, 18W Max
USB-C Output (x2)
5/9/12/15/20V 5A, 100W max
Car Charger Output (x1)
12.6V/10A, 126W max
DC5521 Output (x2)
AC Charging Input
2000W Max, 10A
Solar Charging Input
11-100V 13A Max, 800W max
Car Charging Input
Supports 12V/24V Battery, Default 8A
NCM
800 cycles to 80% capacity
Shelf Life
1 year (after a full charge)
Connection
Wi-Fi
Approx. 22 kg
Dimension
49.7 x 24.2 x 30.5 cm
Specs of DELTA Max (1600)
1612Wh
Extra Battery
AC Output (x4)
Pure Sine Wave, 2000W total (surge 4600W), 230V~ (50Hz/60Hz)
2500W
USB-A Output (x2)
USB-C Output (x2)
12.6V/10A, 126W max
DC5521 Output (x2)
AC Charging Input
1600W Max, 10A
Car Charging Input
NCM
500 cycles to 80% capacity
Shelf Life
Connection
Wi-Fi
Approx. 22 kg
Dimension
Specs of 400W Solar Panel
Rated Power
400W
Cell Type
Monocrystalline silicon
Efficiency
22.40%
41.7*93.1*1.0 in (105.8*236.5*2.4cm)
Connector Type
MC4
Open Circuit Voltage
48V (Vmp 41V)
Short Circuit Current
11A (Imp 9.8A)
Weight(Solar Panel)
Approx. 27.6lbs (12.5Kg)
Weight (with Kickstand Case)
34.2lbs / 15.5kg
*DELTA Max needs to be connected to the DELTA Max Smart Extra Battery for dual charging.
Never miss a sale🎉
